Pass "DeLite" Amp from BAF
here in Germany a great amount of music lowers believe, that the 300B sound would be the best. I have heard the Tambour 300B (SE) against the diy Zen-Version - pictures in the attachement and regarded the ZEN about
http://www.diyaudio.com/forums/pass...itional-op-amp-ultimate-sounding-phl1230.html
I have heard by direct comparison approximately 10 years ago. At this time the now integrated active tweeter crossover wasn't include.
The showed Zen version above mentioned thread outperform the Tambour 300B monos in all respects (the speaker from this time was PHL B17-1230 and Focal T120K). After finished the Zen in this first edition were sold 300B monos from the owner (please note - sound of 300B is not really bad, but less realistic (could be advantage by certainly recording techniques in some cases).
I think, also the diy devices from this project here must be outperform each tube amp, no matter, what type of triode are inside. Otherwise there are fatal errors or it was in the components due to high cost saving too much (or both).
I doubt it will be Class D, Nelson likes to build things with parts he can see - and who can argue with that ?
I forecast it will be something simple in schematic and fit for DIY but very complex and subtle in how it achieves it's outstanding performance. It will be based on power devices with outstanding properties which are most likely not available to us today.
Yes, xv will do the job too.... I didn't know about "convert", though, but for a command-line addict like me it's always good to learn new tricks 🙂
Cheers
Nigel
Imagemagic is great. I used to love xv. i wrote an explicit optimization function in one of Sun's compilers for it (think it was 96 or so). Great little program, cool to see it still being around.
i'm more into gimp these days and paint.net for creating original content).
sorry for the thread hijack -just a trip down the memory lane...
the first version is using 6N50D2, but no input cap.
the sound is good, but by-pass cap on output cap is necessary, a little bit bothering......
so I swapped some wires, add the OPT I mentioned, well,.....It sounds a LOT more better!
This OPT that you used will increase the voltage gain about 7~8dB.
So it will be louder.
But what is the maximum primary DC bias current of this OPT?
Yes, relatively low power, directly heated triodes. Very linear devices.
Many folks believe the 2A3, 45 and PX4 to be the best power tubes made.
It is my humble opinion that you can build a very good amplifier
out of 300B's, but there are not that many out there.
BTW, my absence of 300B for comparison was intentional, I've heard many, and don't care for that tube. Could it be the circuit implementation, sure.
It's interesting how people often have a preference for a
transformer over an output cap. The cap measures better.
A lot better.
I have several examples of amplifiers which put transformers
to use, none of which measure spectacularly, several of which
get very high praise from listeners. What do you suppose it is?
The transformer will sure do a much better job at blocking ps ripple and it will allow the rail voltage to swing higher.
Leve
After picking up Janneman's OPT Nemesis project with Electra
Print, we have a nice transformer that you can bias between
1 and 1.3 A, with a 64 ohm primary and an 8 ohm secondary.
This will be featured in a project to be published in Jan's new
magazine I think in June, and I believe that Jack at Electra
Print will be offering it at a reasonable price.
Hi Wensan Ya,
How are you?
the OPT is at about 1.5A, so it is somewhat saturated ay low frequency.
Kenchen said he will build larger OPTs for me.
cheers
Coffin
Hi, Coffin,
How are you?
I'm still receiving the unemployment benefit now.
It seems like I live in retirement for a year in advance.
My family have a good time in this period.
The 48Ω:8Ω OPT has a voltage ratio about 2.4:1 .
Do you figure out why the voltage gain of the amplifier doesn't reduce but increase?
Wensan
Hi Wensan Ya,
How are you?
cheers
Coffin
Hi, Coffin,
I notice that if the output of the Single-End OPT is open,
The Single-End OPT just like a huge inductor.
The counter-electromotive force may damage the transistor.
Do you add any protection to protect the transistor?
Wensan
Hi, Coffin,
How are you?
Wensan
Hi
The voltage gain does decrease when I compared the output signal and signal present at drain. About 2.5/1.
Gee....I'm unemployed now. At least glad to hear you had a good time with your family.
cheers
Coffin
