In a wrong resistor value and correct, now not operate well!
Apex Thanks, I'm ready to send the photos but I'm without internet at home will soon send you.
Ok, I'm glad to hear that, what is BIAS current?Sorry, I can say now is operete well !!!
Hi apexaudio
Thank you verymuch for all schematic and PCB for diy.
And please show project PA amplifiers new design with 2SA1943/2SC5200 bipolar output tranzistors and IRF2807 mosfets for step amplifier work in H class 0,+/-60V,+/-120V.
Thank you.
Best regards.
Thank you.
Best regards.
Hi apexaudio
And please showe project PA amplifiers new design with 2SA1943/2SC5200 bipolar output tranzistors and IRF2807 mosfets for step amplifier work in H class 0,+/-60V,+/-120V.
Thank you.
Best regards.
Thank you.
Best regards.
I share many design, some are prepared only for diy, why you interested specialy for this amplifier? This amp is based on "100w ultimate fidelity amplifier" with H-class rail. I suggest you to build "100W ulti", and hear do this sound like to you. You can use H900 with IRF2807 on 0,+/60V,+/-120V.Hi apexaudio
Thank you.
Best regards.
Hi Valenca,
I like to see photos.
Hi Valenca,
Hi apexaudio
Part high speed power MOSFET and IGBT driver (IR2117)( Use for Crown K2 & Zeck PT Series & class H other).No have on hand and to search for elctronic store shop in the country part no have (For use order part out off the country only and lose time many ).
And project PA amplifiers design with 2SA1943/2SC5200 bipolar output for step amplifier work in H class 0,+/-60V,+/-120V use for general electronic component part.
This step driver not well tested, and I will share this schematic when I'll be sure that's work ok. I suggest to use step driver with TL072.Hi apexaudio
Currently I build H900 use +/- 80 Vdc. Not use for step drive.
Next project buil B500+TL072 Step Drive great project and wait for IR2117 have in elctronic store shop in the country.
This is thread: MOSFET Amplifier IRFP240/IRFP9240,Currently I build H900 use +/- 80 Vdc. Not use for step drive.
The IR2117 could be used in conjunction with a fast PIC driving two IRFP240's for a simple class D amplifier.
Never measure the BIAS, can you help me?
I could not send the pictures because they are too big to attach ...😕
Send link for picture.Never measure the BIAS, can you help me?
Use 10R resistors series in rail and set bias to get abot 2V on 10R resistor.
Apex OK, I could send pictures of the connection setting BIAS?
You can also measure DC voltage on 0,47R 5W resistor for setting BIAS, about 10mV is OK.
What is your sound impressions compare with other amps?Sorry, I can say now is operete well !!!
I think 10mV is to little. About 35mV should be ok with good power supply and cooler.
- MOSFET Amplifier IRFP240/IRFP9240
