Group Buy: Rectifier bridge with 4-layer pcb
Colour of the pcb
  • Red, white print and gold pads
    Votes: 16 21.3%
  • Blue, white print and gold pads
    Votes: 17 22.7%
  • Black, white print and gold pads
    Votes: 11 14.7%
  • Black, yellow print and gold pads
    Votes: 6 8.0%
  • Yellow, black print and gold pads
    Votes: 2 2.7%
  • Green, white print and gold pads
    Votes: 20 26.7%
  • White, black print and gold pads
    Votes: 7 9.3%
  • White, red print and gold pads
    Votes: 2 2.7%
  • Total voters
    75
  • Poll closed .
Thanks for your input P-A! I will try to contact him, you woulndn't have his username/avatar by any chance ?
Thing is I will be using schottkys and that leaves so much unused space on the board... would be a crime not to try to use it
Max
EDIT: Never mind, just found him...
newbie question...
I tried soldering components to one of the boards today and failed. I cannot get the solder to flow to the other side of the board. Is my soldering iron to weak? The joint also looks brittle, not good.
The iron has a label saying : 24V/48W and has a max temperature of 420 C.
Should I just get a bigger gun?
Won't I damage the MUR's with so much heat?
Thanks,
Jeroen
Ok, I bought a cheap 60W iron and that works. Solder is now flowing through.
A few of the joints looked brittle afterwards (not shiny but matt) so I removed those and redid them. Is this caused by warming the solder for too long?
I hope the MUR's survive, still have to do those.
Jeroen
results...
