Amp to drive 1ohm ribbon, using Dx
Right so
Ehh...."was able to ...." , does that mean you no longer play your ribbon ?
btw, you should try to make your own DIY "graphite resistor" alike DCA
Its quite easy
I can tell you how if you like to
Yes , i still do play the ribbon ( 3 way) very much so ....
Interesting a graphite resistor ! sounds better and measure better than wire? would love to see what you have on it .
Is this it ? http://www.troelsgravesen.dk/graphite.htm
cheers .
Corrected a few mistakes and hopefully better now
I had feedback from ground, instead of output, oh boy
There may still be errors tho
changes changes changes
Any comments to the diode, marked with red arrow ?
Also, should the bootstrap cap optimally connect directly to output
No series resistor or anything ?
