F5 power amplifier
I will most certainly be auditioning a pair of 1990 MG2.6/R's on a F5.
Rated for 87dB sensitivity and 4.7 ohms, I cannot imagine the ribbons will disappoint with an F5, I hear the top-end is supernatural on the F5 - that is also how I could describe those foil ribbons - what a match!
I hope so. I have a pair of them and am just starting to build an F5 for dedicated use on the foil ribbons. Bypassing the passive crossovers was the first step. And I still have trouble believing how big a difference that made. The F5 looks to me like a really good choice for the ribbons. At least I am going to find out. Crossover point is about 750 Hz and impedance is aprox. 3.2 ohms. And they are far more efficient than the bass panel. If this works out as well as I hope it does, then I will have to find the complimentary amplifier for the bass panels. Which I don't want to think about yet. But those are a whole different animal. I suspect that will ask for maybe 200 Watts into 4 Ohms to get all of the goodness out of those. Perhaps less now that the passive crossover isn't taking its tax on the supplied power.
Ex-Moderator R.I.P.
Joined 2005
Like this maybe
i am wondering, there is +24 -24 and Gnd after CRC, the picture shown above don't connect anything to Gnd after crc, is it no need to connect the Gnd from crc to the Gnd of F5 board??
here is mine.
i have a bunch of stupid questions, hope you all don't mind
my transformer used is E transformer which lead out 18 0 0 18, in before i am too stupid to connect both 0 0 together and into the Gnd of the CRC, and smoke coming out from the wires :O so end up i don't connect anything to both 0. Or is it wrong anything?
chchyong89;
On mine the F5 ground goes to speaker negative and input negative only, CRC ground goes to chassis earth, 18 0 to 1 rectifier and the other 18 0 to other rectifier with the 2 positive outs of rectifier joined together to CRC + and same with - from rectifier, hope that makes sense.
i am using the example shown by
i connect both 18Vac into one rectifier, which the 0 where to go is still a question:confused:
