900W H-class PA Amp with Limiter
apex,
please help me figure out how to use tlo step driver to b500
apex,
in h900 MV+ MV- going to fuse,
here MV+ MV-no connection?
0VD+ 0VD-going to fuse
regards
MV medium voltage
HV high voltage
what is 0Vd? 0 volt_____?
OVD is output from H-class step driver, and there is MV or HV when mosfets off/on, that output going to fuse, same as H900 with different step driver. In H900 MV going to comutation diode not to fuse.
Hi Apex,
Per your schematic in post #402 +HV -HV goes to amp should it not go to the PS together with the +MV & -MV only the 0VD should go to the amp as the HV & MV should appear on it as it is switch by the controller.
Rey
From PSU goes HV and MV. HV goes together on step and to amp for supply VAS. OVD goes to output stage, which is disconeted from HV. MV goes only to step driver.
