900W H-class PA Amp with Limiter
Nsl32
If LDR was 10k in dark, and 100R when lighted with LED than can work in limiter. Better use NSL32.
hi engel dela pena
greetings thanks for the nice thought have managed to find
them will arrive in a week have you managed to get all parts if u need any part
after a month can send you from australia
thanking you
andrew lebon
get going with your pcb fill it will send you items needed
hi engel dela pena
thanking you
andrew lebon
h900 would be very interesting
i have to use what i already have as of now
do you have the link of this supplier from australia?
i already have the pcb for h900
and other parts
except this nsl32 and ir2117
but i'm not closing doors upon building h900
as of now since h900 and b500 parts are almost the same
its not that bad for me to go for the b500
as apex told me
b500 can give 2x450w @ 4 R
55-0-55ac pair of 20,000uf using a big torroid
good luck to your h900
i will find my way finding this ir & nsl
at the same time building b500
regards
and other parts
as apex told me
regards
Good luck with building B500, this is much superior amplifier more than look like. Using OP amps in this circuit as AC bufer and DC servo is adventage than similar design, and give beter muching, beter offset than bad descrite diff. This is PA amplifier with HI-FI sound.
