Since the topic comes up from time to time, some of you might find this post informative:
http://www.diyaudio.com/forums/twisted-pear/160782-buffalo-ii-3.html#post2078864
Cheers!
Russ
Cheers!
Russ
I did not do the tests myself yet (someone else with a Buf32S did) but I will soon.
I knew the DAC would accept the sample rate, what I was waiting to confirm was that the FIR filter would still work as designed. The datasheet was not clear to me in this respect.
ESS has confirmed to me that the OSF/FIR will operate correctly. 🙂
Soon I will try it for myself.
Cheers!
Russ
Russ
Just pulled back to ask this question first.
IC7 looks like the chip for the spdif comparator input. has this changed and what is the maximum frequency this will support. I am interested in feeding 352k via conventional player software and upcoming hardware.
Fred
Russ
Fred
I've already asked and Brian answered on another thread.
He said the SPDIF comparator they include for IC7 on the Buffalo II is a LMV7219.
The earlier Buffalo versions were supplied with a LMV7239 that worked OK. The LMV7219 was one that Leo on another site swapped out and was pleased with the improved performance at the higher sampling rates.
Actually, only the very first batch of Buffalo24 DACs had the slower comparator. Every one since then has had the faster version. (I actually did quite a few free upgrades for those early buyers as well 🙂)
You would need to use PCM input for those speeds (352kHz).
To do SPDIF at DXD speeds would require a > 130mhz master clock. Which is not supported by the ESS DAC.
Cheers!
Russ
Cheers!
Russ
Dear Russ,
will it be possible to buy the pcb for the Buffalo-II DAC alone?
I already have a ES 9018.
best regards
Bruno
best regards
Bruno
Cheers!
Russ
What is the difference between using the old Ivy and the new one? Less crosstalk???
Fred
Hi Fred,
It is a completely revised circuit. It includes a different filtering scheme and no feedback caps at all.
Cheers!
Russ
Cheers!
Russ
Cheers!
Russ
Cheers!
Russ
I am actually investigating supplying parts to allow wireless stacking. I think I am on to something, and if it works out, I will supply them in the kits.
I think I found the perfect headers. Looks like the IVY-III kits will include headers and sockets to stack the DAC without wires.
That sounds great. Much easier to assemble/disassemble and should keep everything nice and solid. 🙂
Could you please add the parts numbers to the IVY III BOM so that we who ordered the bare PCB can source these or similar.I think I found the perfect headers. Looks like the IVY-III kits will include headers and sockets to stack the DAC without wires.
Thanks,
Nic
Will DXD be the ultimate high end format for optical discs and digital downloads?
Dear Russ,
is is kinda intersting that Computer Audiophile Computer Audiophile | High-End Audiophile Music Servers
is talking about
"DXD DACs on the horizon?"
and even though there seems to be some non consenus to what DXD is, there are some interesting info there.
FIM comments that they migh release one of their recordings, the "What A Wonderful Trio", that was made in DXD, DSD, tape, and 24/192 formats,
as a DXD download.
I find the comment from Bruce at FIM "We then took the files back to our studio and listened carefully to each one and chose the DXD version to master." an indication that DXD is they to go in the future.
Dear Russ,
is talking about
as a DXD download.
Cheers!
Russ
Hi Russ and Brian,
Because the Buffalo32 is now discontinued is there any chance you'll be releasing the schematic for the B32 owners?
Dear Russ,
it's been 6 weeks and I thought I'd check with you how the testing went?
Cheers!
Russ
I have successfully played DXD files from a couple sources (both DSP based) one worked quite well, the other not very well. The bit clock has to be clean(very clean) for good results. The example that worked well used a fixed clock of 22.5792mhz and worked synchronously. It locked quite well with both 80mhz and 100mhz clocks. You actually get better DNR with 80mhz but the DAC will lock onto worse signal with 100mhz.
In the end, running at 352khz has some pretty serious drawbacks to THD and DNR(measured). And I have found that 192K samples sound much better, at least to me.
Cheers!
Russ
Cheers!
Russ
Hi Russ and Brian,
No, not yet. 🙂
Dear Russ,
thank you for testing playing DXD files. It is interesting - but not strange -that the source affects DXD playability.
100 MHz clocks! - Long time ago, audio stopped at 20 kHz...today we use 100 MHz clocks for audio! Fascinating, as Mr Spock used to sat.
Cheers!
Russ
Brian & Russ (and anybody else who has the answers!):
I am a little late to the game of building up my Buffalo 32S dac (2nd generation). The version of the circuit board is 1.1, purchased in June 2009.
1) The parallel lines marked in 4 spots on the output section of the board should be cut if using this in a standard stereo system (non-headphone system) right? I've been told that the dac sounds a lot better with the lower output impedance.
2) On the reverse side of the board, there appear to be four areas where there are pictographs of resistors at locations R47-R50, I take it this is where I would solder my 2K resistors to set the output voltage to 2V rms output balanced and 1V rms output unbalanced?
3) If I am just using this with standard SPDIF digital input, I don't need to mess with any of the DIP switches right?
Thanks,
Anand.
Thanks,
Anand.
- More Vendors...
- Twisted Pear
- Twisted Pear Audio - Buffalo32S (ES9018 DAC)
