OLD THREAD Simplistic Mosfet HV Shunt (The Simpler Simplistic Design by Salas)
Hi quanghao,
I did not register before.
Is it possible to join the GB for 2 PCB?
Cheers
TS
welcome! provided that you like it!
Please Update the list yourselves when you type:
1. Jogi = 2PCB
2. qusp= 2-3PCB
3. Bas Horneman = 2 PCB
4. hihopes = 2PCB
5. guglielmope = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 4PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
12.jameshillj = 2 pcb
13.dodo = 1 pcb (one)
14.normundss = 2-3 PCB
15. stoolpigeon 4 PCB
16. Nikon1975 = 2 PCB
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 1 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
22. av-trouvaille = 6-8 pcb
23. Jean-Charles = 4 pcb
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
27. Joshua_G = 1 PCB
28. ernesternest 2 PCB
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 3 pcb
32. housing = 2 pcb
33. h-wan = 1 pcb
34. ichiban = 2 pcb
35. Adamus = 1 pcb
36. mikel_ann = 2 pcb
37. flyboi = 2 pcb
38. ims = 1 pcb
39. touchdown = 1 PCB
40. grufti = 2 PCB
41. tassosk = 1 PCB
42.....
Hi quanghao
Item added
Cheers
TS
1. Jogi = 2PCB
2. qusp= 2-3PCB
4. hihopes = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 4PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 1 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 3 pcb
32. housing = 2 pcb
33. h-wan = 1 pcb
34. ichiban = 2 pcb
35. Adamus = 1 pcb
37. flyboi = 2 pcb
38. ims = 1 pcb
40. grufti = 2 PCB
41. tassosk = 1 PCB
42. TS Lo = 2 PCB
43.....
Hi quanghao
Item added
Cheers
TS
1. Jogi = 2PCB
2. qusp= 2-3PCB
4. hihopes = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 4PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 1 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 3 pcb
32. housing = 2 pcb
33. h-wan = 1 pcb
34. ichiban = 1 pcb
35. Adamus = 1 pcb
37. flyboi = 2 pcb
38. ims = 1 pcb
40. grufti = 2 PCB
41. tassosk = 1 PCB
42. TS Lo = 2 PCB
43.....
1. Jogi = 2PCB
2. qusp= 2-3PCB
4. hihopes = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 4PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
17. Back out
18. boudy = 2 PCB
19. Yunick = 1 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 3 pcb
32. housing = 2 pcb
33. h-wan = 1 pcb
34. ichiban = 1 pcb
35. Adamus = 1 pcb
37. flyboi = 2 pcb
38. ims = 1 pcb
40. grufti = 2 PCB
41. tassosk = 1 PCB
42. TS Lo = 2 PCB
43.....
1. Jogi = 2PCB
2. qusp= 2-3PCB
4. hihopes = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 4PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
17. Back out
18. boudy = 2 PCB
19. Yunick = 1 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 3 pcb
32. housing = 2 pcb
33. h-wan = 1 pcb
34. ichiban = 1 pcb
35. Adamus = 1 pcb
37. flyboi = 2 pcb
38. ims = 1 pcb
40. grufti = 2 PCB
41. tassosk = 1 PCB
42. TS Lo = 2 PCB
43. samoloko = 1 pcb
44. . . . .
Test PCb is ok
Hi all!
to day I test PCB layout is ok.
Next today i will make PCB
I use 1N5383. I see long traces, when I use it straight on the D to S pins underneath board. Can be some oscillation between nH of the traces and junction capacitances. Make a good test that your PCB build is reliable for 9610 in real life without the clamp and skip it if you can not solve it either by trying the original protection part or by making a test with it short legged and straight on D,S pins. Cathode to S. If you can not make it work with the clamp, delete it from board, if there is position, people will use it and lose Mosfets. You say the gate protection Zeners give you no problems, let it work on a real application, fully using all parts that work, and go through many on/off cycles. Not my business, but just my 2 cents of advice.
