F5 Listening Impressions & Discussion
Xf5
After several days, I finished two F5 balanced monoblock.
I am very very happy sound!
We compared with F5, 5 Aleph, Aleph X.
F5 balanced - is my favorite!
I very much Nelson Pass and Patrick (EUVL) for everything!
Sorry for my English🙂🙂
Vitali
Vitali
Very nice Vitali. I see your using those new invisible transformers -- saves a lot of space that way. Just kidding -- where did you put the trannys - in the case -- or outboard?
What amps do you have on the bottom?
Thanks,
Steve
vitalica,
I was wondering a few things...
what do you hear as the difference in the sound between the balanced and regular?
what did you use for the resistors in series with the Mosfets?
which mosfets did you use?
whose balance schematic did you use?
what are those three pin devices that are in the front on the bottom??
and finally, after how long did you measure the temperature of the heatsinks??
I too thought they might not be large enough and/or perhaps in that orientation they would not work so well...
Oh, you said "2A" bias - measured how?
_-_-bear
Forgot to mention - very nice looking job! 😀
I want to share some more impressions for the f5.
As I said to "F5 power amplifier" thread I use large skins, so after many hours the temperature stays to about 40oC, so after reading I started playing with the bias...
0.60v >>> 40oC >>> 65oC (mosfet)
0.71v >>> 43oC >>> 80oC (mosfet after 30min)
The weird is that the two of this positions gives a different sound!
The big difference was in the bass area and the mids (I beleive highs were the same)
So my results,
in 0.60v I had a huge, great bass (the midbass was thin), the mids were little behind and the highs were very good
in 0.71v the bass gone away but the midbass became huge, the mids left the veil and became huge (I liked them, but where is the bass), the highs also had a little better volume.
now 0.65v and here are all, perfect balance for all.
Anyone with the same experience?
