Does anyone have a pic from a genuine AD1865N-K? From Digikey for example, not those old ones..
DAC from Digikey:
Finally the DAC End 2 are playing in my house, I am very happy of the result!
All the pcb board are ok (see previous notes).
Actually I am using 0.22uF Jensen Copper film paper in oil on output and I have changed the 2 output resistors to 1Mohm to have a 500K to ground.
Using a 100K DACT stepper attenuator I have -1dB at 20Hz.
I will add another 0.22uF in parallel to get a better frequency response.
Hi Guys... The DAC output module can be used as a preamp? I just need to change R30-R33 to 470k? Care to comment on the quality of the sound if use as a preamp? Thanks.
YES!
of course you can use as a Pre. you change the value of resistor R30-R33= 470K. Sound's nice and the impedance is below 1 k.
pic of the guts.
yes some of the components are the wrong size, its what i had in the parts bin and i got creative.
It is very nice, work well, but i dont like all suppy DAC and supply IV stage use on transformer!
You try one for DAC, one for I/V stage, the soud is better
You tested the soud of DAC?? what do you thing?
Voltage of Relay
The relay is ok???
Can you see in the image
Hi adamus!supply volatge comes up slowly, reaching 6.3v over 20 seconds or so
chattering begins when pin 2 lm311 hits 5.3v
The relay is ok???
Edit
In doing this i then needed to alter the the R11 again (which i hadnt done).
So with R11 at 700ohms, and R8 and R9 the regulation is stable and i am not getting chattering.
I should have been more methodical.
You dont use R8, R9, you conect direct is ok. No noise for filament.
Hi Quanghao,
I would like a full set of boards please... 😉
Please contact me with your preferred method of payment.
Thanks!!
Thanks!!
I agree with quanghao.
Hi Aplizzo!
You test the soud???
Not yet, the last component arrived today so I test tomorrow.
I will let you know.
Hi all!
note: all pcb are very easy to do.
The hardest work is the supply for filament of 5687, because it needs about 1.8mA.
you need make very careful!
I show some member still need PCb of DAC so ,I will make about 10 set DAC_end 2, If you like you can write please!
thank you.
1. Strosek: full set
thank you.
thank you.
2. boudy : full set
thank you.
2. boudy : full set
I did try that. Its a fine balance between too hot resistors and too hot regulator.
With no resistors the regulator was extremely hot, so come volts needed to be dropped. with r8 and r9. 1ohm in parallel worked well. P=I^2 R, P= 1.28watts... s still reasonably hot, but only 0.65 watts per resistor so the 3w rating is fine for the 1 ohm in parallel.
As for the single transformer. I agree that technically seperates are better.... but the salas shunts are so effective that I predict that in no way could you here the difference, on the scope they sit stable and flat with very very little noise. cheers salas (oh... and they look pretty too!).
The sound is different to my old transformer coupled dac. Its not broken in yet, but at the moment is warmer, with more fluid top end.
It also acts a space heater! As a caution to other builders, you must have vents in the top panel, the regulators and of course the tubes put out considerable heat. these 5687's are hot little beasts.
If i get bored listening today, i will have a play with the filter. I currently have the 2ks in place and the 120uh bourns inductor. I may go chopping.....
IF people cant get the caddocks, then i can thoroughly recommend texas components. Very nice company to deal with and with reasonable prices (much cheaper than the uk... one charcroft resistor in the uk is near enough £20, i got both texas resistors for less than that)
The sound is different??? wich you DAC???
the small version of the dac found here http://www.diyaudio.com/forums/digital-line-level/137976-experience-diy-dac-216.html#post2098345, all output stages disabled and dac is coupled driectly with sowter transformer. Very good sound, but quite different to the dac-end 2
- More Vendors...
- Quanghao Audio Design
- OLD THREAD DAC End by Andrea Ciuffoli
