any load required for testing the HV?
Hv you use one R 15-20K /10- 20W for testing!
it is easy!
all the power supply checks out fine, i paralelled 3300 to the 1k for R11 and 6.3v is easy to dial in with the trimmer.
problem
my relay wont engaged, it chatters and chatters but wont engage. Takes about a minute then it starts chattering.
here is the relay i used.
http://datasheet.octopart.com/MT2-C93416-Tyco-Electronics-datasheet-541690.pdf
relay code c93416
problem
relay code c93416
Set times for Relay
No problem! Times of relay. you relay is very good! The Relay 5 or 6V is ok!
Set tim for Relay use change C 12 in the Board I/v stage:
C12 = 220uf = 1 min relay start
C12= 100uf = 45 s relay start
C12 = 47uF= 30 s relay start
I think you use C12 = 47uf.
thank you!
thank you!
changed to 47uf
IT now engages quicker, but its still chattering on engagement quite badly (chattering equals on off on off very quickly for 5 seconds.
Any other ideas?
so not in relay. In the supply for filament is unstable.
1. you see that voltage is not changed continuously?
2. you measure the voltage at pin 2 of Lm311
Edit
This is not bizarre. I think i worked out whats going on.
I was messing with the 2r2's, trying different values becuase of excessive heat and i was close to dropping out of regulation with the 1085 IC.
In doing this i then needed to alter the the R11 again (which i hadnt done).
So with R11 at 700ohms, and R8 and R9 the regulation is stable and i am not getting chattering.
I should have been more methodical.
Edit
Adamus don't rush to connect the boards to the two power supply before you tested them with load.
Step by step.
First you should test the HV fully loaded. Connect 2.2R+2.2R+2.2R+2.7R 5W each series on 270V. You must check with oscilloscope if the regulator is doing its job.
At the same time connect 2 10R 10W parallel to heater DC and check with oscilloscope you must not have ripple. You don't know if you don't check with oscilloscope.
You must load both heater and HV to make sure the transformer's internal regulation can maintain the sufficient voltage for both rails.
Your relay could chatter because ripple on 6.3V or relay too high voltage.
Relay must be 5V. It can work on 125% the nominal voltage so it forgives you.
After you check all these on H/V PSU you can be confident to connect the I/V board.
Salas should be set on around 5.3V so the shunt on the DAC board can have 0.3V to work with regulation accross the 10R resistor.
Don't need to load them for testing. If you want to, connect 100R (for 5.6V out)-180R (for 5.3V out) resistor for load. In this way you simulate +/- the current through 10R resistor before the 5V shunt on DAC board.
cheers.
The salas boars look very good on the scope, no ripple.
The heater supply is fine but does take a while to come up... does yours?
The HV supply is regulating well on the scope, sitting at 273v.
There is a tiny amount of chatter for about half a second. I think its related to the heater supply coming up, because a turn off then on without much wait means no chatter.
Its either that, or i remeber people having problems in the groupbuy for the b1 dc coupled buffer with chattering relay's. I seem to remeber a darlington instead of the npn was the cure.
Step by step.
Thanks yo you and Adamus for sharing your set up procedure. I'm still waiting for a few capacitors but are bookmarking your actions. Couple of questions:
Comments about using PIO (.1microF) as cathode bypass
Inherited 4 200microF Solen caps (they are huge) Is 200 too high for C5 on IV power supply?
Bob
pic of the guts.
yes some of the components are the wrong size, its what i had in the parts bin and i got creative.
Looks very good adamus.
£40 is a great price for that transformer. Yet, i got separates over the pond for cheaper.
uk £ grumble grumble
- More Vendors...
- Quanghao Audio Design
- OLD THREAD DAC End by Andrea Ciuffoli
