OLD THREAD DAC End by Andrea Ciuffoli
BOM has at least one little error: Only 13 green leds for Salas, should be 15?
Few smaller mistakes which are easy to spot @ DAC End: R28 is R26 in the schematic, and there is C18 47uF/6.3V cap, should be C17. Didn't find any other when rechecked my BOM, I think I should have all the parts figured out now, if schematics & boards matches.. (and if there isn't any other errors) 🙂
* In my pcb of the Salas board there was a little problem.
* The output of single +5v was in short circuit.
* To resolve it is necessary make a little cut of the wires, see photo.
* In my case this problem has not destroyed the components but
* please check before switch on.
This evening I have finished to assemble the power supply modules.
I have found only the value 200ohm of the trimmer instead of 220ohm so to get 6.3v I have put in parallel to the R11 1Kohm 1% resistor a 2Kohm 1% to get a value about 700ohm.
Prabably I will change the R1 22K 2w with a lower value to increase a littel the power supply voltage.
I am using a 250V ac for the anodic power supply.
checked my board, no short so must be a slight fab issue.
I am only using 230v AC so will probably have to further decrease 22k, or settle for a slightly lower B+ which shouldnt be too much of an issue.
I already tried with 230VAC. It's not enough. I rejected it as there is not enough headroom for regulation, so you will see the ripple ~~ 🙁
You need at least 250 and change the 22K resistor value.
For good regulation I aim to keep Vds around 50V.
-- a t t e n t i o n ---x short
possible short circuit on Salas board
check twice for the short
under screw terminal +5 Digital output
Thanks Audiodesign!
