What do you mean ?
1 x 230V alternative 2 x 115V on primary side ?
Thats exactly what i mean, yes.
Will it be 2 x 115v?
No, 1 x 230V only, but 1 x 115V is as an alternative possible.
Michael
Michael
Might be interested in a all in one version for 115v.
What type of specs the L1 & L1 120µH should have? Current, tolerance, resistance, core, shielding..? Any recommentations what manufacturer / part number to use? Those are in pretty critical place in the signal path..
Output current from AD1865 is 8mA, so that won't be a limiting factor..
How about this:
Digi-Key - M9947-ND (Manufacturer - RL824-121K-RC)
I'm not completely happy with those. Audionote seems to be using their own silver wire chokes..
Ferrite core, if I remember right..
What kind of choke would be the best? Any analog filter designers here?
PartsConnexion does .01 for $1 and .1uf for $2. I dont think they have a minimum order of them.
I put an order a week ago and 0.1uf was out of stock.
Michael
Aha, ok. No thanks then, i wanted an 'all in one', which i could use currently in USA, but still use it when back home in the UK.
I'm interested too. Your previous GB on AD1865 has been executed perfectly.I talked to a guy in Germany cause the transformer. He is building perfect transformers for valve-amps.
The Anode-current is 30-36 mA per valve, ís that right ?
We can get a very good transformer for "payable money" which delivers
3 x 12v / 1 x 9V and 1 x 250V.
Hope to can tell you more next week.
regards Michael
I check my local Farnell & RS website, they selling Vishay Roederstain MKP1837 0.1uF & 0.01uF very expensive. I will find other source. Can i use Sprague Black Beauty 0.01uF/600V as input cap. at C28 & C29 on DAC-end board? Thanks
Yes! it is a good way! I had to place on the PCB for better use capacitors in the input (C28, C29) or can use the cap better if you have it. the sound is better when you choice the better cap for input! Not need 0.01uf/600V, 100V is Ok
The output capacitor (c26, c26= 0.01uf ) // R 200 Ohm you use only mica is ok
Today I got the info for that custom transformer.
It is M85 core with primery 230V
and secondary:
1) 0 - 250, 100mA
2) 0 - 8, 3A
3) 0 - 12, 500mA
4) 0 - 12, 500mA
5) 0 - 12, 500mA
Price is 76,- EUR(simple) and 84,- EUR (covered, which i would prefer).
It is : Ausführung B, vergossen mit Haube
You can have a look at Netztrafos
I ordered there before and Gerd Reinhöfer ist doing a really good job.
If anyone interested, please let me know. I would like to order mine next week, cause the delivery time is 4 - 6 weeks.
regards Michael
and secondary:
1) 0 - 250, 100mA
2) 0 - 8, 3A
3) 0 - 12, 500mA
4) 0 - 12, 500mA
5) 0 - 12, 500mA
regards Michael
Sorry, lost that link Netztrafos
Thanks! Ausführung B, vergossen mit Haube is indeed nicer.
I'm interested in 1 piece.
- More Vendors...
- Quanghao Audio Design
- OLD THREAD DAC End by Andrea Ciuffoli
