ezDAC v.1.5 Builders Thread
Troubles with EZDUAL
Hi Guys,
I put together my EZDual tonite, and am having problems with it. Trafo reads 15.1v - 0v - 15.1v, the centertap is hooked to AC2, something seems to be pulling current with no load. I get 13.4V -0v - 13.4V from the trafo when hooked up to the board. With power hooked up R2A,B,C get warm. Even if I disonnect AC3 and leave AC1 hooked up R2A,B,C gets warm. I checked for obvious shorts, but so far I haven't been able to find any. I'm pretty much a newby at electronics, and any help would be appreciated. I've attached some pics of my build.
Thx,
PJN
First check the polarity of the tantalum capacitors C4,5,7,8. Especially C7 & 8, the + side of each should connect to Ground.
Then check the DC output voltage. If it's slowly decreasing after you wait a few seconds, it is probably those capacitors. I'd bet on C8 causing the problem.
Oh, yes, wear eye protection! They can explode.
If you know for sure that a tantalum capacitor has been reverse- or over-voltaged, replace it even if it seems okay.
Hi All,
I'm starting to order parts for my DAC board. On the BOM posted for the 1.5 EZDAC on Evan's site C1,2,4,5,7,8,10 & 12 are shown as 10 uF, however when I go to the digitkey number shown on the BOM they are shown as 100 uF, on the digitkey site. Could anyone please let me know the right value ?
Thanks,
PJN
They are supposed to be 10uF, tantalums originally. The 100uF are way too big to fit on the board. You can use the 399-3654-ND if you like, but anything between 10...47uF and 16V or higher is o.k.
I fitted small Rubycon ZA there, here's my BOM.
Ray
Ray
I used 0.1uF ceramics. I plan to parallel the LM337 one with something larger; the datasheet recommends >= 1 uF, I think. The LM317 should be happy with the 0.1uF. If you use something way bigger, I'd recommend parallelling it with a 0.1 ceramic, for low impedance at high frequencies.
http://www.national.com/ds/LM/LM117.pdf
http://www.national.com/ds/LM/LM137.pdf
Hi Guys,
I removed R7 and R8 and replaced them with some electrolytics that I picked up at Radio shack. The good news is that solved the heating up problem, the bad news it that I'm getting+/- 18.5 vdc on the psu outlet. It looks like something is going on in the regulator area. I've attached a pic of some voltage measurements that I've taken. I'm am a bit confused by all of the different BOM's for the PSU so I'm wondering if I used the correct choice of resistors.
PJN
Yea it is confusing especially if you don't know what you're doing like me. I'm glad I have your BOM for the EZDAC.
If you're using the LM317/37, make sure to read the datasheet. The formula for calculating voltage is very simple (assuming the adjust current is negligible). I always assume people don't take my BOM values on blind faith, but I suppose that has not been the case.
Hi All,
After watching a primer on SMD soldering on U tube I finally got the courage up to try any start populating the DAC board. It wasn't so bad after all. I do have a question on the orientation of U 4 and U5. In the picture that I've seen folks used the AD8610, but I used the LME4971 since digikey was out of the AD8610. In the attached pic I have U2 and U3 attached, but U5 is just sitting there. Is the LME4971 in the proper orientation to solder in ?
Thanks,
PJN
I'm happy to report that my ezdac is up and running. I'm working on it as lunchtimes permit at my workplace (where I have access to SMD rework equipment). I used an SPDIF output from my PC, with a small passive network to change from 'TTL' to the proper level, to test it.
Now it's time to turn my attention to the companion USB/SPDIF board that I mentioned in some previous posts. Hope to have a schematic sometime next week.
