Suppo Audio -- New Chinese EL84 PP amp for CHEAP.
Alright, so I think I've decided I'm going to tear down my Suppo and rebuild it into a new chassis. I've got some super nice, highly figured Bubinga that I think will make a really nice chassis.
So, while I've got it all pulled apart I figure I might as well do a little modding. I'd appreciate everyone's thoughts on my plan.
Mod:
Fuse/power switch
Switch to Triode mode (based on the thoughts here http://www.diyaudio.com/forums/tube...o-audios-first-offering-el84-push-pull-7.html)
Replace C2, C3, C14, and C15 (.1uF 400V) with some Sonic Craft .22uF 600V caps that I've got sitting around
Replace volume pot
That's what I'm sure of. I read somewhere that someone recommended replacing C4 (and I assume C16) as well but I'm not sure on that one. I don't want to replace caps just to replace them. Thoughts? I've also thought about upgrading the OPT's to the little Edcors but I'm not sure on that either. It will run me about $40-$50 for the pair but I don't know how much better they will be. I've read suggestions to replace the bridge rectifier with better diodes but I don't really know what that means. Also, I've read that a regulated power supply of some sort would be great in here as well but again, don't really know what that means. Regulated PS for dummies anyone?
One thing that really drives me crazy about this amp is that some of the tube sockets are a little crooked so I'm hoping to try and fix that while I'm at it. I've heard its a bear to remove tube sockets from a PCB but I've never tried it. Any suggestions here?
Anyway, hopefully all that makes sense. My overall goal is to do this as cheaply as possible. If I'm going to be dumping a lot of money into this I'd rather just save the cash and build the upcoming Tubelab Simple P-P. In case anyone needs it, the schematic is on the first page of this thread.
Hi everyone,
Sorry I am late for this disscution. Looks many people enjoy this little amp.
We are busy improving the EL34 and redesign the cases for the EL84.
some improvmen is easy to say and hard to accomplish. for example: dual voltage input and dual safe power switch. we tried to use dual voltage input switch (115/230) but found that it effects the sound a lot. may be just because a little bit longer wires inside. It take us a lont time to fix the problem.
I will look careful all the threads and reply all questions. but please allow me some time to do it.
Thanks you for concerning this amp.
Joe suppoaudio
Hi everyone,
Joe suppoaudio
Good to see you back on here Joe. I think we're all very curious on your EL34 amp and would really appreciate a estimated timeline and price.
G'day bigjppop,
I've already performed the following mods on my Suppo EL84:
Added a mains fuse & DPST power switch
Replaced all wire in the signal path with silver/teflon
Bypassed half the electrolytic caps
Replaced bridge rectifier with 4x discrete diodes
Replaced binding posts & RCAs
Result: noticable improvement already!
When the rest of my parts arrive I plan to upgrade the volume pot & Chinese tubes, bypass the rest of the electrolytics and change the coupling caps. I may do the triode mod too, though I may need some more detailed instructions as I'm not sure precisely what values of resistors go where.
I've thought of re-casing mine too bigjppop, the main reason being it would facilitate the upgrading of the output transformers. Most likely I'll upgrade the rest of the amp and then see where it's at.. already I like what I'm hearing!
If you do go ahead an upgrade your OPTs though, bear in mind most people say that these are the things which have the largest bearing on the sound of a tube amp, so you might want to invest the bulk of your money here.
Regarding upgrading your bridge rectifier with diodes, this page shows how it's done:
http://www.hificollective.co.uk/pdf/diode.pdf
You can also buy all the diodes mentioned here:
diodes listing page
I've never had to remove a tube socket from a PCB before (this is my first non-headphone tube amp) but I can easily imagine it being not a nice job. I personally wouldn't bother unless one of the sockets is really crooked.
That said if you're committed, you could always buy some nice teflon tube sockets and swap them in there.
Anyway, best of luck with all your mods and please keep us informed of your progress!
Oh- and just in case you might be interested you can checkout my humble review of the Suppo amp here:
Review: Suppo GV-3 EL84 ($220 delivered)
Bosk:
I read your review a few days ago and it's actually what pushed me over the edge with redoing mine. I've enjoyed it in stock form so if I can get it stepped up a little for not much money... why not?
Thanks for the links on the diodes; it doesn't appear to be that much of a challenge, what did you think?
Once I get going I'll definitely put some pictures up. My new chassis should for sure have room for bigger OPT's, I just have to decide if I want to justify forking out the dough.
Just a short message first,
We are upgrating the EL84 now they will have new case in 4days. this AMP will have fuse installed. But in our test, no fuse better than fused. that fuse will effect the sound. We don't use fuse in our own listening AMP. some one wil say dangerous. Oh yes, just depend on how you evaluate and control the risk.
Earth grounding issue: we connect the earth via the PCB to chasis and to the power socket. isn't that enough? or we should do more?
we will change the Vol pot and the power switch. should not let the machines fail just because of this two small parts.
the V2 case of EL84 would look like the EL34 shown on our website. but smaller size.
The EL34 price: we will set a good price for our DIYaudio members. special price for DIYaudio member around $360-$400. this AMP weight around 17-20KG with packge, maybe more. So the shipping cost is expensive too (around $180). If people can group-buy 3AMP, then we ship 3 together, then will be $450($150 each).
sorry, forgotten: not only the volume pot are fakes, capacitors in china, Rubycon , Wima, etc etc. brands are fakes as well. there is a long, long list which i have to deal every day. here in shenzhen huaqiang bei road, futian district. a lot of this stuff is sold. worse than that: the sell also used components after cleaning them up. ICs, capacitors, or, selling components, which fail customers request for performance and being rejected. manufacturers purchase departments will buy them and built into devices...so it comes to a cheap product. next worst: manufacturers ("engineers") even dont have suitable equipment or the knowledge to test their products. data publishing is therefore rare.....chinese companies come and go as the weather does. as a tester here in this blessed countriy, i could tell you nice stories. and tube amps are a big topic.
Do you have any specific information on this amp or is this another "all Chinese stuff is junk" comment.
there are some good manufacturers around, which are doing that vacuum tube amp business seriously. so, not all is junk, but quite a lot, to maka fast money. as an example i may tell you, that the output transformer used in this discussed ( EL84 / 6BQ5) amp costs no more than 10..12 US$, or even less. here are plenty of "NOS" tubes available, a 6P1 = 6AQ5 costs no more than 90 cent US etc. 6Nxx tubes are even more cheap, as they were mass production for the chinese army, tons here to sell.
later on, i will test this "amplifier", and if Joe wants to contact me on behalf of this, we will see. safety is for sure, to fail, as ist is presented on the internet.
to me: i am working for a big well known testing company with world wide 35000 staff operating as a tester and consultant especially in audio / video business here in china since 12 years.
you know: if these amps are not designed carefully, things may happen. i myself design tube amps since about 45 years, yea, i am over 60. i think, i know a little bit about that.
Hello Joe,
having read a few comments about "sound abuse" when using a 115-230V switch, fuse and similar "snake oil" descriptions, I guess I´ll never ever consider to buy a cheap amp and continue building my own designs.
Dont get me wrong, I dislike "snake oil" comments about simple parts influencing the sound ( being a radio-tv electrician and experienced DIY builder ). Maybe you can explain me how a fuse or switch may influence the sound ? Is it a excuse to save some parts and build the amplifiers even cheaper ?
Best regards,
George
Hi George,
I don't like that kind of "snake oil" too. We have no attend to save cost by cutting off the fuse. No.
I agree that is a stupid idea to save money. how much is cost? that is not the way building HIFI AMP. What we really concern is the sound. what you can hear from this AMP. That give you really good soun. in our own AMP we use: no fuse, one voltage only (by pass that universal switch to fix 115V/230V).
It is hard to explain in a scientific way saying why a fuse will effect the sound. If I have to answer this, I guess it is only about the resistant. all our power system use thick copper wires, to improve the efficency. But that fuse... a tiny thread inside which looks like a bottle neck. I know that is not a "scientific" reply. maybe I am wrong. But oh, when we build the amp, we just make assumption first base on our knowledge. then testify the idea by try and error. If wrong, we have to think and try other assumption again. we have never do any scientific research any way. and not in the future.
There are numberous arguement about how wires, caps, improve a hifi system. That happen every where. What we build but a AMP with good sound and potential. people take it and modify it to the best they believe. and this AMP worth more than what you pay for in compare with those you can get from other expensive amps. I believe our DIY members' commence have confirm this.
and one suggestion that expensive doesn't means good,cheap doesn't means bad. Yes, it is hard to find a cheap and good product. But suppo audio must be one of this kind.
Joe
Hello Joe,
Best regards,
George
Hi DMKBOX,
We think the EL84 GV-2 case less of space. and it is easy to be damaged in transit. difficult to fit a fuse inside. would you take the new and largeer case, similar as the EL34 beta?
the EL84 is a small AMP that fit small room and smooth music.
EL34 too expensive? lets see if we can do something for diyers. like the review discount as the EL84.
We will build mono block of EL34 to play "The Mass" from Era which I love.. hope they can do the job.
shipping cost a lot. the case weight more than 3KG itself. the IPT weight over 3.3KG. 2 OPT weight over 5KG. a solid stuff.
