The best sounding audio integrated opamps
Andrea, are you sure that the numbers on the opamps aren't just a specification of the dominant harmonics? Avoid 5s and 7s like the plaig. Try to get a good balance between 2s and 3s. Maybe spice it up with a 4, 6 or 8. This could be the reason why you like LT1028 and OPA1612. I'm not quite sure how to interpret the letters - AD, OPA, LT, LM etc.
What I think is that it must indeed be the type and distribution of harmonic distortion what determines the dominant colors (thus the numbers in their code, really 🙂) of every opamp.
That said, I don't understand what you're trying to suggest. 😱 Do you want to confirm your personal prejudice that I'm desperately seeking some sort of coloration, maybe? 🙂
I like the OPA1611, LME49720HA, LT1028ACN8, for one specific common reason, mainly: that they're tonally as transparent as opamps get, meaning that they mostly let the records' own dominant colors through, without superimposing a common 'colored curtain' to all sounds, nor washing all the colors out of them (the latter being a vulgarly false idea of neutrality). 🙂
Of course, they're also very hi-fi sounding opamps, meaning hard to criticize in any parameter of the typical audiophile conception of sonic fidelity. 🙂
I think it's really beyond our reason to understand how numbers are the foundation of all order in the whole universal multiplicity; and by this I mean, far beyond our rational, mathematical approach to them.
I'm really a modern day pythagorean, am I :mischiev::happy2:
PCM56 + LME49720HA = 145679, decently good 🙂
Opamp is working with +/-5V, is there any improvements if it runs at +/- 15V.
Yes, just a little, though this kind of improvement can never override the consideration of numbers i.e. sonic compatibility DAC-to-opamp. 🙂
PCM69AP +OPA1611 = ?
Pretty bad really. I'd rather use the LT1028 here, or others.
Single TDA1543 NOS +OPA1642 +OPA1612 = ?
Pretty decent, but you're not gaining anything really from the different opamps, since they're not different enough 😱 Better TDA1543 + OPA1612 + OPA827 for instance 🙂
oh ok, I thought it was FET...so is LT1113ACN8 a drop-in replacement for OPA2134P?
doess +1 stable means it's unity stable?
I put two LT1113ACN8 as AK4396 LPF buffer and I was told on another forum:
You can't use not unity gain stable opamps on the HD2, the gain is too low. LT1028, AD797, OPA(2)228, OPA637 etc all don't work or oscillate. The only one's that're stable and I don't know if they're unity gain are AD8022 and AD8397.
It's a voltage out DAC chip (AK4396) so the opamps have a gain of just 1 to supply current and make it single ended. The layout isn't designed to make a gain of 1 good enough for something like the LT1028 and it's never gonna work for uncompensated BB's
anyway, LT1113ACN8 sounds really great..the more expensive their op-amps, the better they sound 😀
ok thanks, where did you see this? I must be blind 😱
it says you can add some components around it to make it unity gain stable...that's what I understood anyway..
so if I read carefully the post I quoted about my soundcard...I need to use opamps that are either stable at +1 or unity gain stable(is that the same thing? sorry for the noobish question!!)
and LT1028/AD797 are stable gain <1, so they're no good to me? they were making strange low frequency garbled sounds from time to time tbh...but well using browndogs in a PC case is a terrible idea anyway 🙄
so unity gain stable is better for blind op-amp rolling basically?
thanks for your help! I think I'll keep the LT1113ACN8 in there for a while, I love how it sounds 🙂
Datasheet here, second paragraph under "description"
http://www.datasheetcatalog.org/datasheets/270/57393_DS.pdf
Unity gain stable means gain of 1 which is for example a buffer with the inverting input tied to the output.
The AD797 is unity gain stable but only if used correctly... this is why I keep saying to Andre that you can't just drop in devices with no regard to the circuit it's going into, and why it's necessary to optimise for a given opamp.
ok, thanks Mooly...finally some technical details I understand 😀
so I should only use op-amps that are given to be stable at a gain of 1(= unity gain).
I wish I could get the LT1028/AD797B stables, but it seems like a lost cause?
apparently LT1128 might be worth a shot, though? I really miss the 1x28 color as final buffer 🙁
