OLD THREAD DAC End by Andrea Ciuffoli
Hi Quanghao,
i guess I'm No. 9.)
In any case I sent you 120 for 2 full set.
regards Michael
YES! thank!
Hi all!
I think in Dac-end need DIP28 for CS8414, you can by it whith CS!
By AD1865 N-k or N, or N-J
Thank you
Count me in 🙂
1. MarkLai : 2x DAC sets: DAC + Salas Shunt power for DAC
2. Jeffrey Davison : full set
3. TjongKristian : full set
4. gillib : full set
5. sugden : full set
6. toufu : 2 full sets
7. sugden : 1 set
8. Yunick : full set
9. Michael : full set
10. COX77 : full set
11. Yunick : full set
12. jleaman : ?
13. fredlock : full set
14. Cobra2 : full set
15. assosk: full set
16. pdcaceo:full set of PCB
17. pop music : 2 full set
18. Erwincantona : full set
19. numerik
20. Tea-Bag : full set
21. giabast : full set
22.Blitz : full set
23. Duc Tran: full set
24. agithegreat: full set
25.jims : full set
26. khaho : full set
27. ernesternest: full set
28. dvb-projekt: full set
29. quanghao: full set
30.Audiodesign: full set
31. frd__: full set
I'll make payment next week.
Just one question: If I understood correctly you said it is possible to make transformer based output using your proposed I/V board layout. Is that right?
F.
Me too!
7. sugden : 1 set
12. jleaman : ?
19. numerik
22. Blitz : full set
25. jims : full set
30. Audiodesign: full set
31. frd__: full set
32. Ekkeri: full set
Why sugden is still/again 5 & 7?
YES! thank!
Hi all!
Thank you
I also order :
- CS8414+DIP28
- DS2Y Relay
- All resistor for 4 Board (my friend said that it's difficult to find good resistor at cheap prize in Indonesia)
- 74HC04
(count for them all. How much? Give me the prize as cheap as possible you can give)
This DAC use how many transformer? How much each in US Dollar?
I also order :
- CS8414+DIP28
- DS2Y Relay
- 74HC04
Hi! erwincantona!
I not a seller, im only diy, This my hopbie and I share design layout with PCB.
I can help you by them in Vietnam, but i not have it.
If you want it you can sent to me e-mail you need!
This dac use 2 tranformer:
1. for iv
2.for dac!
thank
Small correction:
7. sugden : 1 set
12. jleaman : ?
19. numerik
25. jims : full set
31. frd__: 2 full sets
F
7. sugden : 1 set
12. jleaman : ?
19. numerik
24. agithegreat: full set - Paid 🙂
25. jims : full set
7. sugden : 1 set
12. jleaman : ?
19. numerik
25. jims : full set
Dont worry. OK! thank you!
you can se all iformation about this DAC at:DAC End - the AD1865N-K with single ended vacuum output stage
One full set for me please.
7. sugden : 1 set
12. jleaman : ?
15. tassosk: full set
19. numerik
25. jims : full set
33. prooptiki: full set
Hi quanghao, I have do some amendment, because I only need 1 full set.*
7. Yunick : full set
8. Michael : full set
9. COX77 : full set
10. Yunick : full set
11. jleaman : ?
12. fredlock : full set
13. Cobra2 : full set
14. tassosk: full set
15. pdcaceo:full set of PCB
16. pop music : 2 full set
17. Erwincantona : full set
18. numerik
19. Tea-Bag : full set
20. giabast : full set
21. Blitz : full set
22. Duc Tran: full set
23. agithegreat: full set - Paid
24. jims : full set
25. khaho : full set
26. ernesternest: full set
27. dvb-projekt: full set
28. quanghao: full set
29. Audiodesign: full set
30. frd__: 2 full sets
31. Ekkeri: full set
32. prooptiki: full set
Best regard
Martin Tie
