The red, yellow, and black wires in the very middle of the picture, are they the connection between regulator output and load?
Ok!
The red to L- load regulator
The yellow to R- load regulator
The Black to GND (- ) load regulator
Hmmm, the Jfet and the mysterious noise. A jfet that chickened out?
Ok!
you can see!
thank
That trimmer R8 is in the wrong place. Should be between pin G and S pins of the 2sk170, but the connection to R4 should be from the gate of 2sk170!
I think this is the proper one, looked in my files. Looks OK Iko?
edit: Redrawned it too so to look a bit more clean.
ok!i try do it again!
Looks good to me.
Have you considered a 47R to 75R resistor on the base of Q2? There may be a benefit from higher value of C2, best decided on location.
As before in this thread we saw that in some layouts helps. But also shows some interference with transient edge theoretically. So as it was done with disco, recommendation is to allow space for it on a pcb and jumper if the thing is stable, or use if in doubt. It can damp some nH PCB inductance interaction with Q2 in practice. In point to point maybe easily no base stopper. At least I did not see difference in p2p.
Hi Salas, ikoflexer!
tonight i do again!
The new cricuit use 2sk17 is very good, i think is better than use 2 BC560.
In my pre use tube 6C45.* last pre , there are a lot noise, hum.
Last times I use Salas shunt use 2 BC56. the sound is still noise and hum,
But . this times I chang 2 BC560 by 2SK170 sample you post.
the sound is not noise, only a little hum. Im happy. It is very good, Tonight I dont sleep! hum hu !
It is exelent! wonderful!
Thank Salas and ikoflexer!
Pm: Salas :I want to ask copyrighted designs?
I want to ask you license boards to share community
And I make Board to share all Members , I would pay to Forum 1+ 2$/board Salas shunt.
What do you think about it???
thank you very much
tonight i do again!
thank you very much
Well done! Your hum is surely from somewhere else, probably the filament supply.
Hi! what do you think I wand make this board and share??
Don't ask me, it's salas' circuit. Send him pm and be patient.
Ok! Last layout. I make 2 board, I gift to Disco one!
Hi !
unfortunately I do not have something to measure the level of interference circuit!
tonight i do again!
thank you very much
Happy that you are happy. What you mean? You want to do a group buy here as we did with the Pass DCB1S redesign of mine?
Happy that you are happy. What you mean? You want to do a group buy here as we did with the Pass DCB1S redesign of mine?[/QUOTE]
Yes! because There are alot of meber want i make Your design!
Ok,
I think make that! What do you think!???
thank!
Ok,
thank!
Firstly the ''Simpler Simplistic'' has to be tested by one or two members that have to volunteer here to test your board for it. We call it prototype or ''proto'' testing. After they are happy it all works fine, they tell us more about reliability, no hum no noise etc. If that phase is a success, you can go to the group buy section or GB and say there how many boards you can at least make at what price and make your intention to donate to the forum known to the administration. There people will declare interest and will trust you for paypal, its their responsibility. DIYA does not interfere with group buys, just hosts them. Me I don't want any money for group buy for members. Only save me a couple of boards I keep as souvenirs if you finally organize it. But I will not endorse any commercial action on ebay etc. OK?
Hi Salas!
Ok! I make 10 Board ''Simpler Simplistic'' and sent to 10 member, thay are try do it, When It is ok, and good, I make it, I dont sell them in ebay, only share in this room!
I run ''Simpler Simplistic'' from 7- 10.35 , is still good,
I think it's better than the old version
less noise, more stable, and sound better! good design
Pre for my very sensitive to the source * I sent him and circuit layout *
Thank
Thank
- Power Supplies
- Simplistic mosFET HV Shunt Regs
