Geddes on Waveguides
Interesting. That is counter-intuitive.
It should not be counter-intuitive that a larger area should be more directional. Directivity is like a Fourier Transform (actually it IS a FT) where a larger spread in the source yields a narrower spread in the polar distribution. Hence while it is theoretically possible to get a 2" throat to have a wide directivity at higher frequencies, it is a lot easier with a smaller throat. I have yet to measure a commercial 2" throat driver that can do 10 kHz with a wide coverage, while almost any 1" can do that easily. In a nut shell a 2" driver will always require a third driver for the very high end and a dreaded crossover in a critical frequency region - a serious complication (and compromise) in the design IMO.
Just to add to the good Doctor's comment, I do have a 1" compression driver that is not doing wide dispersion at 10k in a horn. In fact it's very narrow. More narrow than a 3"full range driver I have measured. So the design of the flair, motor and diaphragm is still critical even for a 1" driver if you want wide dispersion at 10k. It certainly seems like a worthy goal.
Dan
I know Fresnel zones are of equal area, so 0.528 is 0.528" or 52,8% of radius or...?
You are not reading the description of the figures. The area of the sum of the Fresnel zones is normalized to be 1.0. This makes the radius = 1 / sqr( PI) or .564, in whatever units the area is measured in. Just read the patent. It's all correct and seems perfectly clear to me. The examiner understood it!! And thats unusual!
For example, if the throat radius is .5 then you would have to multiple all the numbers by .89 - get it? I could just as easily have normalized to a unit radius (i.e. multiple all the numbers by 1 / .564), etc. But I choose area. You have to normalize to something or it doesn't make sense.
NM, I read it the other way around. :spin: My mistake
Ok. Mr. Geddes I think I understand. This is how it looks for 85mm flat driver and 1" throat. I'm not sure if unequal paths will work.
