Good for you, PMA. Let's see some measurements!
It is little understood by many, that the power line in their homes can be polluted with lots of RFI at least to 50MHz, depending on time and location. Much of this can come from their kitchen electric stoves! A long report with measurements was published in one of the IEEE Transactions by IBM, between 10-15 years ago, on this very topic. I can't find it here, with all the other Transactions that I have stored here, maybe someone could do a topic search.
John, if you can recall any key words from the title I'll give it a try.
Spectrum measured at power supply board output teminals. 10kHz - 4MHz. PSU loaded by 1.46A output current, and with input mains voltage switched off.
Same for BW 10kHz - 50MHz. We can see a lot of RF pickup even for the PSU switched off.
0dBm means 1mW into 50 ohm, i.e. 224mV approx.
As expected, so I must ask: so what's your point? What are the conclusions of your measurements?
That's before even asking about what and how this was measured, etc...
My point is to show that 'clean' power supply is an issue. It needs careful design, both circuit and box/shielding.
The PSU is pretty conventional, EI 30VA transformer + SB260 bridge + 2200uF + 100nF + LT1084-3.3 + 220uF + 100nF.
The signal is analyzed at PSU PCB DC output terminals. There is no shielding enclosure for the PCB. 3.3V PSU output is loaded by 2.26 ohm.
The output PSU terminal is also connected to RG-58 analyzer cable, this cable terminated by 50ohm analyzer input impedance.
I would ask at that level how much of the noise is being introduced by the presence of the probe? These measurements are much harder to make with confidence than they seem.
The presence of the RF itself is less of an issue that the modulation on the RF. If the modulation is significant (and coming from a switching supply it may be) any nonlinearity will down-convert it to audio. That down conversion can happen at any stage in the chain.
Seeing this much RF is not uncommon any more. Any populated location in the US is alive with RF. Getting a really RF quiet location is difficult for making open field EMI measurements.
