Tube Voltage Regulator, Is it worth the effort?
I’ve been experimenting with tube based voltage regulators for my next amp, which will be 2A3 or 300B (switchable) SE stereo amp.
See this link from JC Verdier more details on the tube voltage regulator tech300B
My first impression is it’s not worth the effort…. But I’m still undecided and looking for feedback.
You will see from the test data below that I never got down to the less than 1R z-out as the JC Verdier article indicates….
My B+ for the baseline of this test was based on a LC-RC PSU (10H,60uf-200R,100uf)
If I add 200-400uf to the LC stage of this psu I get roughly the same Z-out numbers as with a VReg psu
Could I hear the difference? I can’t say because I didn’t do a side by side blind test.
Here is the test setup:
The input to the amp is a sine wave at full power, from 20hz to 5Khz
100R in series with the OPT used to measure the AC voltage drop and calculate the AC current
The AC current was very constant from 20hz to 2Khz, at around 40ma
AC voltage measured at the B+ via a 30uf/1M RC filter
Z-out is calculated by = Vac/Iac
The psu for the V-reg test was: 10H,60uf – Vreg – 100uf
Here are the test results (Z-out in ohms) that compare several LC-RC power supplies to the V-Reg power supply:
The first 4 are normal LC-RC types, then a solid state test just for grins, the 2 examples of tube based voltage regulators, the first using a 5V zenner diode for the voltage reference, the 2nd using a 0C3
PSU Config
#1 10H,60uf-200R,100uf
#2 10H,260uf-200R,100uf
#3 10H,460uf-200r,100uf
#4 LM317 (ss) V-reg
#5 6AS7,6SG7,5V zenner
#6 6AS7,6SG7,0C3
20hz 50hz 100hz 200hz 500hz 1Khz 2Khz 5Khz
#1 50.0 29.5 15.6 8.0 3.1 1.5 .96 .84
#2 18.3 9.75 5.11 2.47 1.0 .52 .31 .18
#3 11.2 5.75 2.82 1.44 .58 .31 .18 .12
#4 45 19 10 6 4.2 3.4 3.3 3.3
#5 23.9 18.5 12.8 7.4 3.1 1.4 .57 .15
#6 19.2 14.5 11.8 8.7 3.1 1.3 .51 .21
Disabled Account
Joined 2006
That's interesting.
I find that most folks who swear by tube regulated power supplies actually do it for reasons of tradition and sentiment (i.e. psychological bias) rather than for actual / pragmatic reasons. Personally I have had fine results using solid state regulation based on the Maida (augmented 3-terminal device) regulators. I have not measured the output impedance though.
Jan Didden (who usually hangs out in the Solid State and Power Supply areas of the forum) recently authored an interesting article in Elektor magazine that combined a solid state error amp and vacuum tube pass element. It has a sub 0.5 Ohm impedance across the audio band. (Elektor March 09, page 22, "T-Reg".)
AX tech editor
Joined 2002
[snip]Jan Didden (who usually hangs out in the Solid State and Power Supply areas of the forum) recently authored an interesting article in Elektor magazine that combined a solid state error amp and vacuum tube pass element. It has a sub 0.5 Ohm impedance across the audio band. (Elektor March 09, page 22, "T-Reg".)
Actually, it's sub-100 milliohms Zout and sub-300 uV hum/noise ;)
http://www.linearaudio.nl/t-reg-1.htm
jd
Are there famous commercial high end tube power amps with stabilized power supply for the B+? I have not seen them yet. If it is more superior, there should be some out there.
Please correct me if I am wrong. In fact, I really like to try but I still have not got the chance yet.
Johnny
AX tech editor
Joined 2002
That'll work fine, looking at the specs. I haven't checked the pin-out though, so that's something you'd need to verify.
jd
Ok! And filter before your cricuit ??
C-R-C/ C=?, R+= ?? the value of C, R is enough, And is good filter??
In your cricuit DN2540 is wrong foot. What do you think??? yes or no??
Se in the image
GK
Disabled Account
Joined 2006
AX tech editor
Joined 2002
The plot on your website shows that that is predominately hum (and the same for all three plots, despite signifcantly different loading??).
How much ripple was present at the input?
Glen,
I didn't measure the ripple but used a 100uF cap after the rectifier as a 'typical value'.
That hum is also partly caused by the aux supply for the error amp, which is constant with load of course. But at sub-mV values at the output, I wasn't going to spend anymore effort at that.
jd
Audio Research and Berning come immediately to mind. I'm sure there's more. But even if something is superior, it doesn't follow that it's fashionable, and fashion is what drives commercial equipment.
Disabled Account
Joined 2004
And then you start to worry about the sound of the regulator transistors, regulator caps, etc.
Double work.
It seems people can do perfectly without them.
And if they improve the sound how is it that so little people have noticed it?
I remenber Gizmo and.....Berning.......and who else?
Administrator
Joined 2004
I've been a proponent of voltage regulation in tube gear for close to 25yrs now, and in fact just about all of my designs use it. I generally prefer tube based regulators for reliability, but a Maida based on the LM317 or comparable LT monolithic can be reliable and work well with just a little care.
I think one of the things that scares people off is the added cost and complexity - also in so far as effective tube regulator design is concerned there is some art involved. (well actually, really good engineering)
My most successful power amplifier designs all featured regulated supplies. The business itself was overall not too successful.. :p
Every tube component in my current system features a regulated tube based psu, in most cases on a separate chassis.
