F5 power amplifier
Matching
Speaking of the Fairchild parts...
I was looking at the threshold voltage of the FQA12P20 vs the FQA19N20C and
noticed there is about a 1V difference. That wasn't the case with the original
MOSFETs. When you adjust the bias to get 1.3A one pot will be higher than the
other. Doesn't that make the gain on one side of the input fets higher than the
other? Does that make any difference or does the feedback take care of it?
I also noticed on one of the pictures from an F5 review that a 2.2 ohm resistor
was put in parallel with the 0.47 ohm resistor on the N-Channel side. Does this
have anything to do with the difference?
P.S. I haven't matched anything and the output on an oscilloscope looks very
symmetric. I just don't understand why.:(
Thanks.
I'm only to page 222, so sorry if I havent got there yet, but was wondering what everyone is going to do now that FQA19N20C and FQA12P20 are discontinued? I ordered a parts kit from Tech-DIY, but was wondering if there is a replacement?
Thanks, back to the thread,'
Russellc
You can use IRF9240P's and IRF240N's instead.
Nelson Pass said:
The output MOSFETs are the IRF240 N channel type (Q3) and the IRD9240 P channel type (Q4). They will want to have a voltage rating in excess of 50 volts, a current rating of about 15 to 20 amps, and a dissipation of about 150 watts. Comparable parts are widely available, and here I used Fairchild FQA12P20 and FQA19N20C.
Thanks.
You obviously didn't read the whole thread. The issues that you mention are already discussed at length (in some other threads too).
Russellc
Russel, the Tech-diy kits are avaiable with the Fairchild FQA12P20 and FQA19N20C MOSFET's. I received these within the last couple of weeks.
Actually I have read most of the thread and don't remember any mention of my
specific questions. How about giving me post numbers or just a short answer. I
have read quite a bit about the lack of need for matching, but not why.
