B1 Buffer Preamp
Stepped attenuator
I found a "reasonable" price on a 24 position rotary switch, and since it seems like dual gang linear taper potentiometers are hard to find, I decided to try my hand at making a stepped attenuator (I just can't stand the idea of dual mono pots to be adjusted separately).
My question: will a shunt-type attenuator be a bad idea for this circuit? What I'm worried about is that the pot supplies the input resistance. Is 2K input resistance at the loudest volume enough?
- diomedian
Here is an even easier way to do something similar and yet completely different. This, I think, is my afternoon project sometime in July after F5 and B1 are built.
Dual Audio Taper Potentiometer with Pushbutton Control
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2778
* Two digitally controlled, 65-position potentiometers
* Ultra low-power consumption
* Software and hardware controlled mute
* Digital or mechanical pushbutton wiper control
* Potentiometers can be linked for stereo control
* Logarithmic resistive characteristics (1dB per step)
* Zero-crossing detection to eliminate noise
* Serial port communication
* Can be daisy-chained for single-processor, multidevice designs
* Operating temperature range: -40°C to +85°C
* Operating voltage range: 3V or 5V
* Resistance available: 45kΩ
$2.56 @ 1k
$2.56 @ 1k
That is what Nelson Pass used in the integrated amp (INT-150).
B2 biamp buffer
Hi Steve,
The B2 Biamp Buffer. You say you tried bi-amping but didn’t get sound you wanted? The B2 uses two pairs of the buffers found in the B1 but configured for splitting the output of the preamp with variable relative gain to two sets of power amplifiers. This allows not only isolated amplifier impedance buffering, but adjusts the gain levels for different amplifiers. Even for identical amplifier channels it also allows the subtle adjustment required to get exactly the top/bottom balance you need.
$2.56 @ 1k
Where I can find the "schematic" (application) ?
I want the simplest one !
BJT switch attenuator
Hi Guys,
Here is my take on a BJT switch for a nice attenuator. It came to me this morning and i can't wait to wire it up tonight. It should have good BW and no DC offset, the only backside is that one needs two floating switch control voltages that are fairly well matched, the last bit of assymmetry can be trimmed away by adjusting individually for each switch R4 or R9.
BR,
Anders
