Hello there,
I am a beginner in simulation S.P.I.C.E., in simulation electrical and electronics circuits. I want to simulate a schematic with the program Micro-CAP 12.Or is possible to use the program LTpice, to help me? I want to monitor some graphics from a photodiode PIN which is a InGaAs Photodiode IG22-Series, I want to monitor follow parameters:
responsivity (A/W) vs wavelength(nm);
dark current (A) vs reverse voltage (V);
shunt resistance vs. temperature;
detectivity vs. shunt x area;
capacitance vs. reverse voltage;
normalized response (a.u.) vs time (µs)
relative sensitivity (%) vs incident Light Level (mW)
And at the transistor BFP420 I want to monitor some graphics at the following parameters:
total power dissipation Ptot = ƒ(TS);
collector current vs. collector emitter voltage IC = f(VCE), IB = parameter
DC current gain hFE = f(IC), VCE = 3 V
collector current vs. base emitter forward voltage IC = f(VBE), VCE = 3 V
base current vs. base emitter forward voltage IB = f(VBE), VCE = 3 V
base current vs. base emitter reverse voltage IB = f(VEB), VCE = 3 V
collector emitter breakdown voltage VCER = f(RBE), IC = 1 mA
transition frequency fT = f(IC), f = 2 GHz, VCE = parameter
collector base capacitance CCB = f(VCB), f = 1 MHz
gain Gma, Gms, IS21I^2 = f(f), VCE = 2 V, IC = 20 mA
maximum power gain Gmax = f(IC), VCE = 2 V, f = parameter in GHz
maximum power gain Gmax = f(VCE), IC = 20 mA, f = parameter in GHz
source impedance for minimum noise figure ZS,opt = f(f), VCE = 2 V, IC = 5 / 20 mA
noise figure NFmin = f(f), VCE = 2 V, ZS = ZS,opt, IC = 5 / 20 mA
noise figure NFmin = f(IC), VCE = 2 V, ZS = ZS,opt, f = parameter in GHz
I do not know how to begin. Please help me. I accept, if is necessary any simulator of circuits.Or only important electrical parametersm to monitor them graphically.
I attach a electric schematic.
Thank you for understanding,
Draggos.
