Reducing gain on red mono TPA3116 board?
I bought a couple of the Chinese red mono TPA3116 boards on eBay, that have balanced inputs. I have connected them to a professional line level source (+4dBu) and they have far too much gain.
I started investigating what the gain value was set to on the boards and have been a bit confused by the resistor values:
R1 = 01D = 100kΩ (SDZ to PVCC?)
R2 = 473 = 47kΩ (GVDD -> GAIN - aka R2 on data sheet)
R3 = 01D = 100kΩ (GAIN -> GND - aka R1 on data sheet)
These are valid combinations listed on the datasheet, and it doesn't seem to match any of them?
Closest appears to be Slave / 32 dB. But I would presume that it wouldn't work at all in save mode without a master.
Am I reading these resistors wrong?
Or have they chosen weird values?
Does anyone else have one of these boards and changed the gain on them?
Apart from the high-gain, the board is working well and appears to be sensible.
Really not excited about replacing tiny SMD resistors! 🙁
Thanks!
njh.
Code:
MODE GAIN R1 (to GND) R2 (to GVDD)
Master 20 dB 5.6 kΩ OPEN
Master 26 dB 20 kΩ 100 kΩ
Master 32 dB 39 kΩ 100 kΩ
Master 36 dB 47 kΩ 75 kΩ
Slave 20 dB 51 kΩ 51 kΩ
Slave 26 dB 75 kΩ 47 kΩ
Slave 32 dB 100 kΩ 39 kΩ
Slave 36 dB 100 kΩ 16 kΩ
Thanks!
njh.
