Duelund Coherent Audio DCA 16GA Premium Audio Cable - 100M Spool
SOLD
Duelund Coherent Audio DCA16 premium audio cable, tinned copper in cotton, oil impregnated.
One of five spools left. My cost was $410/spool ordered directly from Duelund in the Netherlands, ten spool minimum.
Superior to the famous Western Electric 16AWG hookup wire.
Used to manufacture some of the best sounding speaker cables and interconnects anywhere near the price.
Also great for audio construction hookup wire, rewiring speakers/crossovers, etc.
Retail: $800. Yours for $429/100M spool.
Lengths less than 100M are $6.99/M (7M minimum).
Price is firm. No trades. Buyer pays shipping. PayPal adds 3%. Other fee free options.
Thank you.
B+ voltage not as expected
Fair warning: I'm not the most circuit-savy person, so feel free to roll eyes at my question.
I'm building a tube rectified amp which is a clone of a Decware SE84, but using headphone output transformers. The power transformer is a Hammond 272FX, which uses a center tap on the rectifier heater windings. I'm using said center tap as the B+ which is what the SE84 does.
The tranny is a 300-0-300 output. On the Decware (since sold) I measured 357VDC at the rect. center tap (B+), but on this one, it's 410VDC, which is nowhere near half of the stated output of the tranny. This puts the plate voltage on the output tubes 30+ volts too high. (These numbers are with the amp loaded.)
I should explain that Decware has a DIY circuit board version of this same amp, but uses diodes for rectification, and the spec's for the transformer for that amp is the same as the 272FX (minus of course the 5V output).
WTB: multibit DAC Tube output
I already posted a couple of WTBs in this spirit, but could not find one of them and as I want to open up to other possibilities, I am posting a new one 🙂
So looking for a nice, not too expensive, finished project of a multibit (I am not into the new chips for now - question of mood 🙂 DAC with tube output. USB interface is desired but not a must - good execution is the biggest priority. Hoping I can fins something as budget for a commercial one (MHDT is top of my list right now) is currently not there.
Feel free to MP me
Electronic Flue Gas Analyser
A good day to you at DiyAudio; this is out of the ordinary, I have an electronic flue gas analyser, made by Colwick Instruments Ltd (they are no longer around), it’s called Anagas. The sensor fitted detects CO carbon dioxide only, yet the manufacturer successfully managed to achieve detecting CO² carbon dioxide; I am guessing this was achieved by adding a adjustable resistor?
It would be good to know more about how this was achieved, detecting CO².
You can see the components on my Microsoft OneDrive
https://1drv.ms/i/s!AuQDAPiShOjc2Sru5HJEJIdT1oRK
I am in the process of fitting a new battery pack and a new CO sensor.
CDM4/19 two types of cog-wheel
There are two kinds of cog-wheels in the CDM4/19 based drawer mechanisms (see the photos attached): full plastic, supported on both sides (the second photo) and plastic with the metal spindle, fixed on the one side (the first photo). I found the first type cog-wheel in Marantz CD-72 unit and the second type in many other Philips and Marantz units.
In what units are used the full-plastic cog-wheels? Is there a list?
f.
Boston Acoustics Soundware Subwoofer agonizing coil whine (PSU?)
Had my BA subwoofer for 4 years and it had a terrible coil whine squeal from day one.
I RMA'd it twice, but both times it came back (after a 6-8 weeks return time) and had the exact same problem.
Said they "swapped the amplifier module". As it didnt help, personally I feel more convinced its the PSU module.
Its a coil whine tone, maybe around 4.5Khz. Its terrible agonizing, when worst I hear it clearly 4-5 m from the Sub (because sits in corner).
It wines without PCA input. It whines in both active mode and stand by (inactive) mode, though changes a bit in frequency and often gets noticeably higher when in stand by!
I whines if I move it to a completely other room in the house. Whine makes a weird "squeak squeak squeaaiik" and then dies, when power is pulled.
I opened the sub, not being able to exactly pin point the source. I also didnt see any bulged caps, everything looks normal and smells new.
Fun fact; Im pretty sure the sound dropped dramatically when sub was upside down, being opened up. I have basic knowledge and repair skills like changing dead caps.
Question is: Will I be good with "drowning" the coils (I see at least 2) with eg. hot glue? Or what to do?
Thanks!!
Diagram (I THINK): Box
Inductor Choices
A lot of designs seem to offer ICE inductors or wind it yourself on T106-2 cores. At the moment, due to the stupidity of Brexit, it is hard to get those in the UK and confusion over the new import arrangements have put off companies from selling into the UK.
I can get Bourns, Vishey etc at similar values and currents but wondered if there is any particular parameter that I should keep in mind?
Trying to build my own loudspeakers for the first time. I need help!
Hello everyone!
I am new to this community and just started a loudspeaker build.
It is a 2 way design with a 6" Dayton Reference RS150-4 and a Dayton 1" tweeter with a 2nd order butterworth crossover at 3.5kHz. The vented enclosure is Vb = 14.7L with a 3" flared port Fb = 41Hz.
I took my first measurements using a Dayton Audio EMM measurement mic and am really confused with what I am seeing. I am not expecting a perfectly flat response but I am trying to get it pretty close.
I have attached the SPL measurements of a single loudspeaker at 1M on axis.
I am aware that my tweeter is more sensitive than the woofer and I am making the fix soon. What confuses me is the massive dip at around 180Hz. I am stuck trying to figure out the problem.
I was wondering if it was port noise, resonance, room issues but I am not able to figure it out. Please let me know if any further measurements/info are required.
Thank you
Centre speaker locations or alternatives?
I've got a AVR that's great on movies but sucks on stereo music using the on board ESS DAC and pre stage. I want to add a stereo amp which is not great but heaps better on music from a NAS etc and that will supply LF and RF from the AVR pre outs. The dilemma is the centre channel sits on a angled shelf so it fires towards the viewer and do not want to move it above the screen. There's a soundbar in front of the screen so can't add a shelf and lift the screen to place the centre under it as well as the screen would be too high.
The only reasonable option I can see is the place the stereo amp in the AVR location and move the AVR to the left bay. It would be nice to have them both in the centre bay but the centre speaker resides there. In the past I've used 4.1 and also 5.1 with 2 centre speakers beside the screen but not as effective as the single centre speaker which is better for ageing ears. I've also played with the AVR settings and patterns and found no improvement to stereo music and even the Direct mode sucks.
It's for occasional stereo music use as the main stereo stuff was moved and is in a different room.
Before I move this stuff around, somebody might have tried or seen some alternatives.
USB interface overloading - Passive attenuator help?
Hello guys!
I've built a phono preamp based on John Broskie's schematic, minus the 12AT7 output stage.
Here is the ('modified') schematic i used:
attachment.php
Obviously its output impedance is pretty high and needs a high enough input impedance on the following stage.
RCA manual states it should be kept above 250kΩ.
Anyway, here's my specific problem:
I've been ripping records using various USB interfaces.
Using a Focusrite 2i2 3rd Gen at the moment, feeding signal into its Hi-Z instrument input (impedance specified @1.5MΩ).
All is good, up to the point I want to rip records using high-output MM cartridges.
For example using a Shure M44-7, even with gain knob at zero the inputs get overloaded and clipping occurs.
It's so bad there's hardly any record I can record without clipping.
So, my question to you guys is whether I could use an unbalanced, passive attenuator?
Placed between the source (as seen in the above schematic) and the interface's input (with its 1.5MΩ impedance).
But, without disturbing the impedance 'matching' too much for the reasons explained above.
A good target attenuation would be around 15-20dB.
That'd be enough I guess to keep levels low enough and not overloading the interface when using my favorite high-output MM cartridges.
It'd be really great if the passive attenuator consisted of a few resistors and the impedance seen by the source be kept above 750kΩ.
Obviously this is above my skills, so I ask you guys.
Hopefully you can help me out a bit.
Thank you for taking the time to read!
Kind regards,
Nikos.
Recommendations for a finished TPA3116/TPA3118 unit
Hi, I'm looking for advice on which completed (enclosure, jacks, and all) TPA3118 or TPA3116 unit would be best, preferably for under $100.
I've never used a soldering gun, and I'd rather not mess around with getting a proper enclosure, volume pot, etc., if I don't really have to. Sorry that I'm not taking the DIY route on a place called diyaudio, but I don't have the time right now (maybe some other time?)!
This would be to power a set of Micca MB42X speakers, currently being powered by an Indeed TA2021 Tripath amp. The 3116/3118 units I've found that would seem to fit the bill are as follows
SMSL SA-36 Pro
Yuan Jing TPA3116 2.1 [red board]
I also found this other Yuan Jing unit (with the blue and black board), but I really don't want to pay $115 plus $48 shipping for it.
Any ideas how these finished units compare, sound-wise, or if there are any major problems with them? I couldn't find a whole lot of info on the finished units in particular from the big 3116 thread or on Google. I'm currently leaning toward the SMSL unit because I don't need external tone controls.
Thanks everyone.
EDIT: It looks like the blue board might be able to be gotten to a usable state without soldering: just the DC, RCA, and audio jacks would be needed.
The enclosure and volume pot/knob might be a little more complicated. Hmm..
Converting Linaeum LT1000 from active to passive
[:cop: Thread split from here - Introduction to designing crossovers without measurement]
Folks, this is an amazing thread, and there is literally too much information - making it difficult to comb through.
My question is this:
I have been using a miniDSP 2x4 HD active crossover, and biamping my 2-way transmission line Linaeum LT1000 speakers. I have settled the crossover design using REW with a miniDSP UMIK-1, and listening, and making custom driver EQ filters. These are loaded into the 2x4 HD and I have been listening to it for many months.
The crossover frequency is 440Hz (yes, really) and I am using 4th order Linkwitz Riley slopes. To be precise, the woofer is a 24dB/octave in the 2x4 HD - and the TLS tweeter is an 18dB/octave - and there is a 22uF capacitor in series with the tweeter. I am assuming this is effectively a 24dB/octave slope, as well.
The reason I did this was for our friend Justin Case. I didn't want to risk these tweeters, which are the definition of extremely rare.
*Is there a guide for how I would go about picking the values of parts to build an analog 4th order LR crossover, at 440Hz?
I am then going to need to add a resistor(s) to the tweeter, given it is 1-2dB louder than the woofer, and I am aiming at a so-called "room curve". In REW, I am using the default one they suggested: flat between 200Hz and 1kHz, with +1dB per octave below 200Hz (so a total of +3dB at 20Hz) - and a -0.5dB/octave above 1kHz (so a total of -3dB at 20kHz).
I am intending to build a MLTL cabinet for the Dayton Audio RS225P-4A woofer. I have all the data on these woofers. The challenge is for the needed data on the Linaeum TLS tweeter. I can obviously measure the DC resistance (I *think* it was around 6 ohms?) Do I need additional data to build the crossover?
Any and all advice and information you can tell me, would be greatly appreciated. I have only done the crossover in the 2x4 HD - which I highly recommend, by the way, for this purpose at least. I was highly skeptical of it - but it sounds really good! I think that the upside is that the amps power the drivers directly - the woofer in particular benefits from this, I think. Having the ADC / DSP / DAC stages may seem problematic (I had serious doubts!) but listening has proved to me, that I was wrong.
This is the in-room frequency response and waterfall measured with REW. The dips I think are the 32 year old TL design. I *think* I have got a new cabinet that will eliminate these, and extend the bass quite a bit lower. Which is going to be amazing, if it works as I hope. The Linaeum TLS tweeter is a Paul Paddock masterpiece.
SigmaStudio usb
Hello,
I'm having problems connecting a ADAU1701 (Wondom) board to my computer using a programmer board.
When first time connecting, the SigmaStudio label (inside the software) turned green indicating the board was connected. I played around in SigmaStudio and everything worked fine. Then windows 10 tried to install a device driver, an unknown device pops up and the connection in SigmaStudio turns back to orange. Connections fail.
Then after reading forum posts here and elsewhere, I tried installing the CyUSB driver (after removing the device, before removing the unknown device) nothing works. The driver doesn't show up in the device manager.
I'm actually ready to ship it all back.
Anyone else had problems with windows 10, usb3 ports and drivers in SigmaStudio?
Kind regards,
Reinhout
Windows 10, usb3, ADAU1701 (Wondom) with programmer board
  • Locked
Power amplifier PSU SMPS
Hello,
100w ... 300w power using PC power supply transformer 2x30v + + fan temperature control pcb size 100x86mm for more power (400,600,800w) see files
test video (load, short circuit etc.)
IR2153 Audio SMPS Circuit 100W-800W - YouTube
923442d1613570464-power-amplifier-psu-smps-smps-pcb-layout-png
download file;
Just a moment...
Download | file.io
Gofile
  • fls.zip
    fls.zip
Reverse engineering Krell KMA 160
I was able to acquire a dead Krell KMA-160 for $0. The driver board of the amplifier seems to have set itself on fire. All the components in the vicinity of the last driver stage have been destroyed, including the transistors, several caps, and a few resistors, one of which is merely scorched, the other if which actually exploded. In addition, a diode in a power supply snubber -- the driver board has a power supply separate from the main power supply -- has exploded. Scary stuff indeed.
What's particularly interesting is there's nothing special about this amp. The topology is unremarkable and the quality of construction screams DIY. In fact the build quality of my Aleph-X monoblocks is, IMHO, quite a lot better than this thing.
Of course, the Krell precedes my efforts by 15 years 🙂
I hope to get photos and schematics up soon. So far I don't see any exotic parts. There's plenty of MJE 15030/15031 driver transistors, as well as A968/C2238 (these are not marked 2SA/2SC but they do have a great big capital "T" printed on the case. Are they Toshiba?) The small-signal BJTs are A970 & C2240 like you might expect. The power supply seems really basic, but I'll report more after I've diagrammed the whole thing.
Oh, and on the back of the board is the gross rework hack. Eww.
Anyone else have experience repairing, or improving, this unit?
Pile of T10001BD to repair
Got myself a project pile of T10001BD amps to be resurrected.
Thank you guys for all this wonderful info!
I managed to get one going from scrounged parts, which was cool, haven't fixed amps in a long time.
I have schematics for most of them, except the older 2005 models.
I was wondering if anyone one knew the part numbers to the switches SW100, SW101, and SW102?
Figured out the 4 gang frequency pot RV101 replacement, Bourn #PTD904-1015P-B203.
All these boards seem to have malfunctioning pots and switches, along with some have let the magic smoke out. Looks like the circuit board needs support in that area to keep from vibrating so badly. Repair first, then modify...
Thanks for your tjme
6.5-8" mid driver for 150-1500hz with high sensitivity
Hi guys, i am planning a 3 way with the PHL 4021 and the 18sound nsd1095 with xt1086 horn. But I am not sure about the mid driver. The crossover frequencies are approximately 150 and 1500. I don't need high spl, but high dynamics and very good transients. It shouldn't cost more than ~300euro.
mid drivers i consider right now are:
PHL 1120
PHL 2460
18sound nmb900 or mb420
What do you think?
Panamax M5400-PM Odd issue
I owned Panamax M5400-PM.
Which has voltage regulator function with
input voltage and output voltage indicator.
The thing is when input voltage is 120v, the unit think it's 110v, so
the unite up-trans 10v. So, output voltage indicator shows 120v but actually it's 130v. I checked with several multimeters.
Basically, the unit always think 10v lower than actual voltage.
There is no adjustment knob or switch to calibrate.
I asked Panamax and they just told me not to use the unit and buy new one.
Do you guys have any idea how to fix it or adjust it?
I ve changed every capacitors, relays, voltage regulator ICs.
Another possible failure components?
or adding some components to adjust?
Gentlon, a Power-Good Driven Soft-Starter
What is GENTLON?
It is an after-the-fuse power entry control board that gently turns on the power to an amp (or other devices).
Is Gentlon not just another soft-starter?
Yes, it is, if one doesn’t care a short list of a few little things more than what a usual soft-starter does, and the way that it does them. Otherwise, the list goes,
1. Power-Good driven: Gentlon soft-starts the power, but does not turn power full on until a subsequent Power-Good condition is established. If Power-Good fails to establish within 5 seconds after soft-start, the circuit gives up and returns to power off (standby) mode.
2. Has onboard Power-Good monitor that watches up to 4 DC rail voltages, 2 positive and 2 negative, detects rail droop/collapse and defeats Power-Good accordingly. The threshold voltages for Power-Good and rail collapse are user-defined (by resistor values).
3. Two wire headers offer off-board speaker relay drive, at 12V/100mA capacity each, also sustained by Power-Good,
4. A wire header offers off-board power relay drive if choose to have the power relays and the NTC thermistors installed elsewhere in the chassis.
5. Accepts speaker kill override.
6. Accepts power kill override.
7. Has on-board bulk capacitor bleeder, fully discharges rail capacitors in seconds at power off. (Can be defeated with a jumper)
8. Allows installing up to three 1-in diameter NTC thermistors, offering generous Joule handling capacity for even "ridiculously" large bulk capacitance on the power rails.
9. Has a NTC cool-off timer that blocks repeated, frequent power-on attempts. It gives the NTC thermistors chance to cool down and come back to normal resistance to help ensure adequate inrush limiting performance at each power-on event.
10. Rev.3 PCB offers relay-switched Neutral connection, in addition to the usual switched Live wire. (Rev.2 PCB does not switch Neutral, but it has a 30A relay.)
How does it operate?
A simplified flowchart:
Note about the “Plateau”: A time delay placed after the soft-start before probing the PG status. If one wants to probe the PG and shunt the NTC sooner or later this is where to make the tweak. But it is up to 5 seconds, or the circuit goes back to Standby state.
Has it been built and tested?
Built a few Rev.2 Gentlon, all operate properly. I have one of them in a dual mono power amp (Meistersinger amp, my own design and build) with two 600VA toroidal transformers, followed by 120,000uF total capacitance on +/-65Vdc rails, in service for 5 years now. Have never built the Rev.3 Gentlon, but the only difference from Rev.2 is the added option of the switched Neutral, and a 16A relay instead of a 30A relay.
There are loads of SMD parts, can someone new to SMD build it?
Unlike most other SMD PCB designs seen in our forums that simply take standard IPC7351 compliant footprints, I make all SMD footprints specifically suited to DIY hand soldering/reworking. All land patterns in my PCB designs have ample pad exposure beyond the component body for easy iron tip access. The smallest size SMD part used is the large-ish and easy 0805, making the Gentlon a good SMD beginner's project. A usual temperature controlled soldering iron and a pair of fine tipped tweezers would be adequate for assembling this PCB (what I solder mine with). For advanced level builders in terms of SMD experience and equipment, this PCB is also suited to reflow assembly process.
What's being shared?
Schematic diagram
View attachment GENTLON_2.pdf
PCB fabrication data package (can be sent straight to a fab house to order PCBs, as well as the paste stencil if desired)
View attachment Gentlon_2_Gerber.zip
BOM
View attachment BOM_Gentlon_2_Raw.txt
An LtSpice power rail monitor schematic for simulating/altering resistor values to suit desired Power-Good voltages and the hysteresis, or the protection threshold. The un-altered circuit validates Power-Good at about 56.5V, and defeats it at about 55.5V.
View attachment GENTLON_2.asc
2. Assembly Options
Some functionality of the design can be opted out.
Don't want the Bleeders? Delete all components in the "Cap Bleeder" box in the schematic, with the exception of the four 10-ohm resistors and J11.
The amp has only one pair of DC power rails to monitor? Connect the DC power rails to J11, delete J10, D10, and D11
Use no more than one NTC? Use a proper resistance value and current rating NTC, delete the other two from the BOM and short their soldering pads.
Power rail on different voltages? Simulate for the desired voltages in the LtSpice schematic and change the resistors in the BOM.
What does it look like when in action?
Gentlon_in_Action
Sorry, ran out of hands...😀
Tweeters too bright
I recently purchased a set of older Marshall speakers with blown tweeters. I could see the 15" woofer is 8ohm but I had to guess for the tweeter. I replaced the diaphragms in the tweeters with 8ohm as well and now that I can finally hear them running they are really bright. I would like to avoid just getting a l-pad to fix it as although they are not super expensive to buy neither were the speakers and if I can I would prefer to just do it with resistors. My question is, can I use REW to analyse it and figure out how many db I need to turn the tweeters down (and from there calculate my two resistors) to get a better sound?
Cheers!
P.S. I am quite new to this and have only just started playing around with REW.
Carver 2000 issue with amp section
I just purchased a Carver 2000 magnetic field receiver.
it works fine until the volume control hits about 10/11 o'clock, then protection cuts off the relays for a few seconds while I lower the volume setting and then its fine until I take it back to 10/11 oclock again
I opened it up and visually it looks fine.
I measured the four largest caps and they seem fine with a standard cap meter
I set the voltage adjust to 69V
then I went to set the idling voltage and it acted weird.
I measured 0 volts on both channels instead of 4.5 but adjusting the two trimmers did absolutely nothing.
does anyone have any suggestions ?
thanks
My best bookshelf speaker.......so far
I thought this might interest owners of the Peerless 6.5” nomex mid-woofers.
I’ve had mine for several years paired with DX25 tweeter and they are ok, but nothing great.
I build some .5cuft out of some red oak boards and sculpted some leather covered mdf baffles after laminating three 3/4” thick sheets together.
Then, during isolation last year, I found an article about the “Distractions” speakers by Robert Dunn who paired the same woofer with Hiquphon OW1 tweeters back in 2012.
Coincidentally, I found a pair of OW1 tweeters, assembled the Distractions crossovers, and replaced the DX25s.
The final combination is the best standmount speaker I have built, along with the Ergo ix, courtesy of James of PFM fame.
This is the only time that I have heard the Hiquphon and it is magical how the soundstage is enhanced, improved imaging and shimmering percussion.
6SC7 Phono pre amp
I built this pre amp mule while ago, and recently dug it out, rebuilt the PS and added a second channel,,, Played a couple dozen albums and find it to be a little lacking in bass response with a TechnicsSL-D30/P28,,, it seems to respond better with the Dual 502/Shure M91E...
I want to try a different coupling cap, replacing the .0047 to .0068 or .01 or so to see if there is any boost in the bass response...
Question is,,, Will changing that cap change the EQ of the pre amp? How about if the 22M grid resistor is left in place?
Some searching turned up this post,,,
"I noted that in the Tronola articles, the coupling cap in an Eico phono section was changed from a 0.05 ceramic to a 0.1 µf film cap. This made sense and improved the LF response. So sometimes it is beneficial",
Para phrase from...POST #15
http://audiokarma.org/forums/index....or-values-in-tube-amp-preamp-rebuilds.744091/
Any thoughts from the designers out there!!
Thanks for any info,,,
Successful TU-8600 300b Build
Hello All,
I completed my Elekit TU-8600. I opted for all of the optional upgrades through Victor. Here is a summary of my experience.
This build was a bit more involved than the 8200, but not much. The board layouts were superb and made a lot of sense.
It was a bit slow going in the beginning when I had so many open slots to populate; as the main board began to fill up the pace picked up because I had less searching to do to locate the next spaces for placement.
I needed Victor's help on this one (not on the 8200). He was amazing. I felt that I made a friend. He calls and emails promptly. His passion for the hobby shines right through.
My left channel was not working upon completion. I had to go back through each and every solder because I could not locate the issue. I reheated each solder on the left channel. I also went at the solders that were close together and cleaned up the space between them (regardless of whether I could see much if any solder) to eliminate any shorts. I also took the main board out completely and flipped it and checked each and every through hole placement, etc. After about 4 hours of this I set everything back up and voila!-music out of both channels.
The amp sounded great out of the gate, yet a running in of 90 hours this week (night and day playing) has improved things more.
I have two issues to address. First, I'm getting a ever-so-small static crackle when I move the volume knob at higher volumes. I'm thinking that I need some insulation/gasket between the Alps pot body and the knob spindle to reduce static electricity. My Alps 100k didn't come with any nut or locking washer. Maybe that will help?
The second issue is paint color. I think that I will paint the unit for living room display in the future--maybe an automotive finish in a vintage color.
This amp is amazing. As Victor says, it places vocals front and center. I love, love love it with jazz. I have a pretty substantial main tube based stereo (~$20k). The 8600 sounds different in a good way. It draws me in much more and has even less listening fatigue (keep in mind my main system is all tube based and is of great quality making it low fatigue to begin with).
Last night I listened to some pretty popular albums--Vince Guaraldi's Charlie Brown Christmas and Muddy Waters (Buddy guy on lead guitar) Folk Singer. The sound was intoxicating.
I cannot find any fault with this kit or the end result. The only thing I would like to see is a second input so I can run a turntable/phono pre and a digital input.
If I can build this anyone can! Go slow and enjoy the process. It's a zen-like thing to build one of these.
Special thanks to Victor for all his help and sharing in the passion! Victor, you are the man!
Looking for a Dayton SPA-250 schematic
Not sure if this the right place but here goes... I have had four Dayton SPA250 Plate amplifiers over the years and they all fail after a while, usually five years down the road. They just blow the fuse and go dead.
I was wondering if anyone knows where I can find a schematic for the amp to see if i can get any of them fixed. I contacted Dayton and they would not provide me with one.
I guess I shouldn't complain too much as these amps seem to last for a while. My two SPA500s and SPA1000 are running about 10 years old and still going strong. My Polk subwoofer and Velodyne amplifiers had failed at only a couple of years.
Thanks in advance...
Sources and thoughts on transport buttons?
Working on my first project and I'm looking for a set of transport buttons. Searches at Mouser and DK haven't turned up anything.
I love the vintage look and feel of the ones on my Akai R2R - but assume they'd be either proprietary or NLA?
In a much more contemporary vein, the Arturia KeyStep has nice, soft internally illuminated buttons about the right size.
Any sense of where to get these sorts of buttons?
Thanks in advance!
RK
Step-up transformer comparison
Recently I opened a new topic about my stats lacking bass punch:
Lacking of bass "punch" in my esl's
I got a lot of insightful replies. One of them was this one by bolserst:
This post lists a few possible causes that contribute to the experience of "lack of bass puch" in stats, one of them being: step-up transformer compression/limiting.
I still have to continue reading this topic and doiing my research, but I started to measure and test my current three different pairs of step-up transformers:
1. AudioStatic 2x1:75=1:150 step-up
2. DIY #1: 1:120 step-up
3. DIY #2: 1:90 step-up
Transformer #2 end #3 were made by two different local hifi-enthousiasts.
In the attachements you will find:
* a saturation comparison. I put a 2 ohms resistor in series with the transformer and measured voltage across the resistor in order to calculate current. Voltage across amplifier output on x-axis, current through transformer is on y-axis (I put a wrong label on the x-axis). I measured with a 10 Hz sine-wave.
* an impedance comparison of the transformers (without load / esl)
* an frequency response comparison of the transformers
It seems the 1:90 transformer has both the best (highest) impedance and the best saturation behaviour. The AudioStatic has the worst saturation behaviour. The 1:120 DIY has the worst hf frequency range and a promlematic impedance. So at the moment I prefer / use the 1:90 DIY transformer on my current stats.
The next step would be to make a circuit which turns on a LED when saturation current is reached just to check if the transformers do saturate when playing music.
I will keep you informed.
FS: Doug Self Preamp Linear Audio 5 PCBs
Hi!
I have a set of PCBs for the preamp from this very popular thread:
https://www.diyaudio.com/forums/analog-line-level/280458-doug-self-preamp-linear-audio-5-a.html
Unfortunately I don't find the time to build it and I have to many projects in the pipeline.
I'm based in Europa but can ship them anywhere in the world.
I paid 50 USD + shipping.
You can have the PCB kit for 35 USD + shipping.
KEF B139 as subwoofer
I have a couple of these, which I could either sell if anyone is interested, or otherwise build subs with. I don't have space for a TL, so the sub would have to be IB or ported. Can anybody point me to a functional design that's as small as possible? I don't mind flat to 40hZ - don't listen to organ music and low E on the double bass is the lowest note I'm interested in. Thanks for all suggestions. Andy
Volume control of TAS5754 based amplifier
I have purchased this board - [wiki=https://store.sure-electronics.com/product/AA-AB32256]%[/wiki] - from Sure Electronics. It is based on the TAS5754 and is attractive in that it has an I2S input.
It also has an I2C input which I mistakenly thought led directly to the I2C port on the TAS5754. As I wanted to control the amplifier - and in particular - the volume from a microcontroller, this seemed ideal. However, the board I2C terminal leads to a microcontroller embedded on the board. Sure Electronics sells a volume control for it, but to have more general control possibilities I need to be able to generate the I2C signals myself. These seem to be a state secret.
My first question is: does anybody know where I can find out how this particular I2C port works (e.g. The I2Cs address, what data needs to be sent etc.)?
I have asked the manufacturer. They seem to imply that I can change the volume by adjusting the voltage levels. I’m assuming that this is the power supply (e.g. high volume = powered at 19V, low volume = powered at, say, 5v). I could then use a variable voltage regulator (suitably rated) and adjust the voltage (0 volume) using a digitally controlled potentiometer.
Is this a technique that could work? Are there any gotchas that I should know about?
Many thanks for any hints.
KSL Kondo Overture
Audio Note Japan KSL KONDO OVERTURE.
From 2011 and in absolutely ‘mint’ 10/10 condition. U.K. spec. Comes fully boxed, KONDO certificate signed by KONDO President Masaki Ashizawa, spec sheet and all relevant paperwork. Musical presentation is as beautiful as the aesthetics and engineering are exquisite.
This item is only for sale in The UK and is collection only from Harrogate, North Yorkshire. I simply would not trust any courier with the transportation of this fabulous amplifier. Psvane Phillips replica EL34’s are currently fitted and sound wonderful.
I realise collection in the current conditions are not favourable, though perhaps not impossible. However, so folks can give it due consideration, I’m posting this lovely amplifier for sale nevertheless.
I am relatively new to The diy audio forum, though being a ‘box swapper’ have a long history on U.K. forums.
I don’t have a PayPal account so it is payment by bank transfer. New price for Overture is a whopping £30.000. There are a couple more Overture’s for sale in The EU, this being the cheapest by quite a big margin. I am asking £9400.00 or close offers. At the asking price, I will also include a Quad of unused NOS SIEMENS EL34’s circa 1980’s.
Photos are of the actual Overture. I’ll post a pic of the rear of the amplifier when I find a minute. As this is a ‘For Sale’ thread and not a ‘Discussion Thread’, far better to discus via PM’s rather than on ‘open’ forums. Serious enquiries only please and by PM. Think that’s everything.
Thanks for looking. Mark.
FS: Parts kit for Zaph ZA5.3c center channel (USA)
Zaph|Audio ZA5.3c Center Channel, Single
za5.3c
Options:
Accessories : Ported Enclosure Accessories Package
Crossover Version : Traditional Boxed Speaker Design
Tweeter Cap : Bennic XPP
Binding Posts/Input Cups : DB-CUP [Qty 1]
Full parts kit, brand new. Includes:
Included:
(2) ZA14W08 Aluminum Cone Midbass Woofers
(1) DQ25SC16-04 Titanium Dome Tweeters
(1) Professionally Assembled Crossovers
(5ft) Supra Classic 1.6 (15AWG) internal speaker wire
(2) 1.5" x 4" PT-F415 port tubes
(1) 27" x 42" x 5/8" Foam Sheet for lining the internal walls
(1) GOOP adhesive to glue foam to walls
(1) QC110R for + tweeter tabs
(3) QC110B Quick Connects for – tweeter & - woofer tabs
(6) QC187R Quick Connects for + woofer, + crossover & + binding post tabs
(4) QC187B Quick Connects for – crossover & - binding post tabs
(12) #8x1 Black Ox & Wax Socket Head & Wood Screws for mounting drivers to baffle
$140 shipped to lower 48 states
Paypal for payment
Mycelium speaker
Hey guys, I'm new here so excuse me if I'm posting this in the wrong sub.
I'm an industrial design student from the Netherlands working on a project in which I'm designing products with a new sustainable and biodegradable material called mycelium. It is a composite of fibers and fungi roots that is comparable to MDF except it has a lower density (I like to call it LDF). You can view it as a low-density MDF material that replaces the epoxy with fungi to hold the fibers together.
It has some interesting material properties that make me wonder if it's suitable for building speaker cases. It has naturally sound-absorbing properties (This might be a downside as well) and it is great at dampening vibrations, reducing problems with resonance in the case. It can also be grown in a mold, allowing you to make more complex shapes that might be interesting for base ports and the design in general.
I am no audiophile however, I am interested in a subject. Do you guys think this might be a relevant use case? What are the pitfalls? Should I approach a speaker manufacturer, and so can you recommend any in the Netherlands?
Thanks! Yvo
Edit: I am currently looking into transmission line speakers since it seems like making one from mycelium might be advantageous from a production point of view. Currently, transmission line speakers have to be CNCed which is an expensive process. Using mycelium grown in a mold might be a good solution. What are your thoughts on transmission line speakers? It seems like an outdated idea, what are the advantages/disadvantages?
Clarion amp, not powering up
Hi all, trying to repair a Clarion Apa4300 amplifier.
When attempting to power up the digital panel lights up,
The power on led stays off.
No audio output.
On internal inspection Q143 tested 0 ohms across all 3 legs so I removed it along with Q144
I've tested TL594, all measurements in DCV pins 1-16
1, 0
2, 4.9
3, 0
4, 0.1
5, 1.5
6, 3.6
7, 0
8, 12.9
9, 6.2
10, 6.2
11, 12.9
12, 12.9
13, 4.9
14, 4.9
15, 4.9
16, 3.5
Also checked dc voltage on Q812
1, 12.65
2, 13.6
3, 13.3
Apologies I had already started a post on this amp but my meter was on the wrong setting leading to much confusion so I've started a fresh thread.
Hopefully I can get the amp up and running again, and thank you Perry for your patience and support.
Passive Radiators in Front L/R 3-ways???
Silly question #3
Is it a bad idea to go with an 8" woofer and either 2 x passive radiators (or 1 bigger PR) in normal floorstanders?
I like the idea of not having a port (chuff chuff) but I haven't seen any DIY 3-way floorstanding projects with PRs.
2nd question
Is it a bad idea to have an 8" driver, an 8" PR on the same baffle facing forwards and another 8" PR on the side?
Any links to floorstander projects with PRs would be good. I've tried searching but the forum search seems to return 100s of threads not relating to the search term!
What is killing my MOSFET (Tube CCS)
I have been trying to build the CCS according to the schematic found here:
diytube.com • View topic - EZ Sink: Depletion-mode MOSFETs and the LM334
LM334 is configured for 7mA.
First attempt, I built the circuit, connected it to the 6SN7 plate, applied 250V B+ to the drain of the DN2540...and poof. No more MOSFET. Basically have an expensive resistor.
Thinking there was some issue with the way current is applied from the cathode warming up, I subbed the tube for a 1000 ohm resistor as a load. Ammeter shoots up to about 15-20mA...and no more MOSFET.
To check that I have the LM334 configured correctly, I remove the MOSFET from the equation. I hook up the LM334 to one of my low voltage bench supplies, using it to source current to the same 1k resistor, and it behaves as intended. I get a constant 7mA from the max voltage of the power supply down to the dropout voltage of the device.
I pop in another DN2540 (source connected to the V+ of the LM334, gate tied to the V-, and consequently, the load) in circuit, and the MOSFET fails once again.
I've been testing the DN2540s cascoded as a CCS for about a week prior and outside of one oops, they had been performing admirably in the exact same role. My goal with the LM334 was to be able to have a repeatable current reference vs the variability I had run into with using a current set resistor (I was just using a trimmer to get the current set) based on whatever the Vgs was of the particular 2540 I had plugged in at the time.
I'm about to pull what is left of my hair out over this. I'm down to a single good FET now and really don't care to destroy it...however it is managing to happen. Any ideas?
Integrated using BOZ + Camp Amp v1.0
Hi folks
Back in 2018 I built up a pair of Camp Amp v1.0 PCBs and a BOZ, but due to illness they have sat in a box ever since.
I'm finally getting round to doing something with them, I'd like to build an integrated amp and was wondering if the BOZ & these Amp Camp modules would work well together.
How large do the heatsinks for the Amp Camp modules need to be? I have quite a few heatsinks of various sizes I could use.
What sort of power supply arrangement would be most suitable for powering the Amp Camp modules? Again, I have a variety of power supply components I can select from.
This is going to be my first attempt at building my own amp, so forgive any potentially silly questions.
FIR/IIR/LinearizedIIR software crossover is released
Hello, all!
Few days ago I released my new software audio crossover - dePhonica version3 (windows only yet).
I hope, its easy to use and configurable in minutes (basic configutation) - from installation to music listening.
Fully functional preview version of crossover is available for free and I hope its will be user-friendly enough to evaluate crossover potential.
Video example of installation and setup here: https://youtu.be/1jK7sJr9i7M
Here list of features available in current version:
  • Built-in ASIO Sink driver for transparent stream input from audio and video players
  • Different input sample formats: 16 bit integer, 24 bit integer and 32 bit floating point
  • 2 input channels and up to 8 output channels
  • Output to DirectSound, ASIO and Kernel Streaming audio devices
  • Processing completely in 64 bit floating point precission
  • Built-in crossover`s frequency response analyzer with overview amplitude graph, single channel graphs (amplitude response, phase response, group delay for each channel) and response addition graph
  • Filtering by FIR filters, IIR filters or by IIR filters with automatically designed phase correction FIR filter
  • Can create FIR phase correction (all pass) filter for external hardware crossover
  • Two FIR convolvers available: FFT convolver with Overlap-Add algorythm and linear convolver (Straight FIR) without usage of FFT
  • Any of two convolvers can be used with one or more IIR filters in each processing channel
  • Up to 128 000 taps per channel with FFT FIR convolver
  • IIR filters and frequency response envelopes available: Linkwitz-Riley, Butterworth, Chebyshev
  • Parametric synthesis of amplitude and phase responses for filter types: Low Pass, High Pass, Band Pass, Band Stop, Low Shelf, High Shelf
  • Band pass and Band stop filter responses can be optionally defined via lower and higher cutoff frequencies or by a definition of central frequency and bandwidth
  • Amplitude and phase equalizers for arbitrary amplitude and phase response correction with data import features (from text file or from impulse response in WAV format)
  • Any combination of FIR and IIR filters in each processing channel
  • Full-featured pre-processing channel for input stream with its own filter set
  • Automatic biasing feature for gain response in a separate channels or in a group of channels
  • Input and output gain adjustment in each channel
  • Adjustable delay in each channel with optional sub-sample resolution
You can download installation package on official site: dePhonica sound labs.
I will appreciate you for feedback and will review all your suggestions to improve future releases.
Max.
Parallel Cathode Follower
My apologies if this is redundant. I was looking over an old book at a triode cathode follower circuit and fell for the simplicity of it. A tube and a few resistors, low output impedance, and the direct plate connection to B+ appealed to me.
I understand voltage gain is less than unity, but the circuit produces an increase in current, so we still have power gain.
So, what if we go parallel, like 10 or 20 triodes? Is it possible to get up sufficient current with low enough output impedance to directly drive a speaker?
Highly unlikely that I'm the first to have this thought, so perhaps it's been done, or is impractical.
Trouble with Denon PMA-520 bias adjustment
I'm trying to adjust the bias on an older Denon PMA-520,following this translation of the German directions from the service manual (corrected from here):
BIAS CURRENT
-Setup
1. Install device in a normal position and protect from direct draft of A/C or fans. Carry out adjustment at a room temperature between 15°C and 30°C.
2. Set control elements to the following:
POWER BUTTON -> OFF or STANDBY
VOLUME CONTROL -> CCW [counter clockwise] until stop
SPEAKER TERMINALS -> open (connect neither speakers nor load resistors or similar)
-Adjustment:
1. Open top cover, then [put a] DC voltmeter on the measuring points of PCB number 1U-1608-1 (EQ.- and amplifier module).
2. Plug in power plug and switch power button to "ON". Within 10 seconds turn up VR403 (left channel) and VR404 (right channel) so much, that the voltmeter shows 0,5 mV +-0,2 mV.
3. Warm up for 5 minutes, then adjust VR403 and VR404 so that the voltmeter shows 3 mV +- 0,5 mV.
4. After 15 minutes of warming up, adjust VR403 and VR404 so that the voltmeter shows 5 mV +- 0,5 mV.
5. Apply a signal of 1 kHz and 100mV RMS and turn up volume to maximum.
6. Now the voltmeter should show a slightly higher value (max. about 10 mV), now adjust the trimpots VR405 (left channel) and VR406 (right channel) so that the voltmeter shows 20 mV +-3 mV.
7. After another 2 minutes, adjust VR405 and VR406 to 35 mV +-3 mV (PMA-720) respectively 20 mV +-3 mV (PMA-520).
8. After 10 minutes of warm-up, adjust VR405 and VR406 to 40 mV +-3 mV (PMA-720) respectively 20 mV +-3 mV (PMA-520).
I got to step 5 without incident, but when I hooked up the signal generator and turned the volume all the way up, the voltage at the test points went to around 1.4mV rather than 10mV and was unresponsive to adjustments from either set of trimpots. As I slowly turned the volume up the voltage increased from 5mV to a maximum of over 20mV part way up then decreased. Does anyone have any idea what might be causing this?
NAD C326BEE upgrades
hi there
i bought a new NAD C 326BEE and after opening it up i spotted some generic capacitors which are actually chinese ¾ûÉúµçÈÝ,ÉîÛÚ¾ûÉúµçÈÝ,ÉîÛÚµçÈÝÉú²ú³§¼Ò-¾ûÉúµç×Ó,ÉîÛÚµçÈÝ×¨ÒµÆ·ÅÆ£¡
so my question is is it worth recapping with better quality caps ?
also if yes which ones to choose ? i know ELNA Silmic II, Nichicon Fine Gold/Muse and Panasonic FC/FM series
thanks for your reply 🙂
dbx XB140 sub amplifier (looking to fix)
Hello. I'm trying to fix this amp, but I can't find schematics available online.
1) Does anyone know the value for the internal fuses (circled in pic1)? The manual only has the value for the fuse accessible outside of the case.
2) I have removed the transistors (green dots) and they are bad. I plan to replace them. I also removed 4 caps, but they are all good. Any other advice on which component to replace? The second picture pretty much shows the entire board.
Looking for "good" fm tuner
I'm stupid, as you could probably see from the subject. I was looking for a tuner on ebay and i realised that I don't know anything about tuners. I was wondering if I could build a tuner? Cause some of them (i'm assuming they were the "good" ones) are very expensive.
What are some "good" tuners? Can any one point me in the right direction with a website?
I have a gainclone and 2-way speakers. So I know a little about those things, but not anything about tuners. If some can please, recommend a tuner for me. My cryteria is that i has to be cheap, but not suck, if that makes any sense.
Also are there any FM tuner pc cards that are good? Are there any at all, even; for pci?
cleaning Yamaha relay (CA-1010)
I did do a search on this -- but I'm a newby so my apologies if I've missed the discussion...
I have a Yamaha CA-1010, sounds wonderful but eventually the right channel cuts out. Have to turn up the volume past mid-point to reactivate it -- then it eventually fades again. Sometimes no problem whatsoever.
Used contact cleaner on all pots and switches I could find then stumbled across this problem in another forum and it was suggested that I clean the relays with contact cleaner -- but use another cleaner to remove any residue before trying it.
So, I'm trying to find the relay.
These two pictures show what I think is the relay, can someone confirm that this is the relay and that it is cleanable? I believe the cover should just pull off but don't want to try until confirmed.
Thanks so much!
Question about measuring ditortion multiway planar
Hi !
i got a question. i was wondering about measuring distortion of a multiway planar.
Nothing new to have a tweeter on the same foil, but usually that tweeter is located on de edge of the panel for obvious reasons ,
it does not move much there.
you can use magnets closer to the foil if needed.
easier to wire or foil coil wise.
it does not take much away in excursion capability
and it does not matter if that part does not play low end since it cant move there much to begin with
Now what if i mount my tweeter in the middle (since thats what i want) i might have the following problem, of the tweeter moving in and out the magnetic field when heavy bass is played in combination with content that the tweeter needs to cover. i have a few solutions that might solve that problem but firstly i want to measure the problem. so i can see what the results are.
Since REW plays a sweep the bass and the tweeter range never play at the same time , so measuring this setup i get a scewed distortion result. (or do i miss something) since
What i did today was playing a 38 hz sine on the total foil and performed a sweep on the tweeter. i had to use 2 different channels on my DSP or the thing went complete bananas (not sure what thats causing , i must add i did not check if i was clipping....) anyhow the second options works sort of.
But i wondered are there any other methods that can measure distortion in a different way to see the interaction of drivers combined ? that do not cover the same range
here few pics dont look at FR i just added 4 traces on there to act like tweeter.
Pic 1 Bass panel alone sweep
Pic 2 Tweeter alone sweep
Pic 3 Bass 38 hz sine wave and tweeter sweep at the same time
Now we can see distortion when playing a 38 hz tone increases distortion in the tweeter, FR response seems to be almost not affected.
Pic 4 Bass and tweeter same time sweeped
here we can see the way it is when both are measured at the same time by REW , they both perform almost the same as they would be when playing on there own separately. and does not give a good insight.
its hard to say what im looking at haha. might be that noise of whatever of playing 38hz (like mechanical influenced it as well)
  • Poll Poll
4x150a. Se. prototype
How probably correct output trans formers impedance
  • 3.5k
    Votes: 0 0.0%
  • 5k
    Votes: 0 0.0%
  • 7k
    Votes: 1 33.3%
  • 10k
    Votes: 2 66.7%
Hi. This is a prototype for Rf tube 4x150a.
Diy Amplifier ??????????????????????????
Hifiman diy cable
Hi everyone, I have a doubt about how to build a hifiman headphone cable. I have two 3.5 jacks that go into the headphones and a 4 pin xlr connector that goes into the amplifier. I would like to know if on the 3.5 jack side, for the + signal, should I use the tip for both channels or the tip for the left channel and the ring for the right channel? On the net I found the diagram of the 4pin xlr connector which indicates that pin3 which is the R + must be connected to the ring of the right channel. But I have also read of many who say that for these headphones the rings are not connected and 3.5 ts jacks can also be used. Does anyone know what the reality of things is like? Maybe it depends on the headphone model and / or the type of connection on the amp side (this seems very strange to me). Thank you all.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,783
Members
7,888,271
Messages
Filter
Forum Statistics
Threads
406,232
Messages
7,888,271
Members
507,783
Latest member
ys.zhu
