Hello all,
the focal crossblock is one of the few parts I kept from my few years in caraudio.
It's a wonderful piece that served me a lot in the car, but also helpful in home environment in the variable setup I tried.
It is built, I assume, for 4 ohms drivers so of course with 8 ohms everything shifts, but the wide range of adjustment still allowed a compromise.
I used it few months ago between mids/highs on my OB setup, not optimal because with the drivers I finally chose it required heavy EQ, but ok just the time to find other amps/dsp.
I have now much better result active there too, plus gained time alignment.
I always wondered why there isn't anything like that for home, I mean with this flexibility and build quality, but maybe I’m just unaware of it.
DSPs are great and cheap now, but with 10 channels it doesn't hurt to simplify a bit, and I find it transparent sound wise.
I explored other active solutions like the k231 but they're a bit steep, and would require a bunch of spare cards for the same flexibility.
Anyway, I'm sure I will use it again one day, in the next version or next setup.
Or even right now I could use it to save two channels and maybe test new amps.
So the main question is: could I modify the crossblock itself, basically changing most components to better fit 8 ohms drivers?
I don't know much about crossovers, just how to use them but can't easily read/understand their schematics.
Once opened you can see how it's built (the 2 way version I have):
4 coils (big for woofers and small for tweeters?), few caps and a bunch of resistors, plus maybe few other things that I don't know (it appears two resistors have been replaced by the previous owner).
From left to right, 1st knob defines the low pass point, 2nd the Q factor, the 3rd defines the high pass point and the fourth acts as an L-pad.
I suppose each knob controls a specific routing for a combination of coil/resistor to get to the desired slope.
For the coil I'm not sure how it works, it looks like there's multiple soldered/entry points onto the pcb on their circumferences, is it possible that different pcb "tracks" arrive at different sections of the coil, for variable "rolled length"? If so it's not something I'm ready to change but I could still change the resistors.
The idea is to list all parts, find similar items but with half values for 8ohms (if I'm not wrong there), and solder them as replacement.
Do you think changing only the resistors would mess up everything? I assume the amount of combinations could still mitigate that.
There's thousands of settings once combined, just to give you an idea for basic slopes:
What do you think? I’m nuts or it could eventually work? Thx!
