I designed and built 3 pairs of mono amps around the Musical Concepts PA7 MKII / PA8 and am super impressed with the PA-8, its layout, ease of installation and use. It sounds astounding, small amp delicacy and finesse, with HUGE AMP effortless ease and an unflappable sense of drive. I am struck by how quiet the amps are (no fan is nice) the music emerges from velvety (almost eerie) silence. These amps are rendering the most musical detail I have ever experienced with any of my amp builds or systems, without grain or etch... the music event is very relaxing, with a harmonic more like vacuum tubes. (without excessive heat or required fans)
I powered the amp up, checked / set DC offset, gradually brought the bias up... the most challenging part, as with any build, is the couple hundred hours of burn-in (as with most components). When something sounds like this, so great from the get-go, you know it will only get better and better. Incredible Macro and Micro dynamics, increased sense of space around instruments, with an immense sound field. I cannot say enough great things about the sum of my project(s) built around a known standard. I am also "burning-in" a Mundorf MLytic HC (LOCO cap) power supply version, not shown.
It was actually easy, I knew exactly what I wanted in a power supply, after designing, building and modeling dual mono supplies with Hafler 500/600 amplifier modules over the past 6-8 months. I have wanted a Driver PCB solution like this, although I was prepared "to hack" or reconfigure a PA7 to flat, into a point to point layout for the output stage. When John mentioned the TO-247 / TO-264 output option, I request / committed to 2 pairs right off the start... knowing just how great the PA7 is... this elegant circuit is a breakthrough in system transparency in the over a dozen amps I have used them in...
Background / my inspiration to do this... **I wanted to build something that I could not go out and buy**
I have *dreamed of* wanted to build *own* an amp like this for many years. I will just say it... I wanted an amp to "equal" and/or mirror my "old" Levinson No. 336, a beast for power, one that I could no longer pick-up after L & R shoulder surgerie(s), I sold it in 2011. The total / combined weight of my 2 channel beast, is about 15lbs. lighter than No. 336 and I can pick them up and carry them = A REAL WIN!!!
I believe these amps are more delicate, open (literally), equally powerful and do not require 50-60 amp electrical service to deliver spec... though I am considering wiring the main sound room with a 240v (amp) feeds... which is only 10 feet from my electrical panel. Where does this hobby end???
~ I will admit to buying most of the initial PA8 production run ~
I feel that certain = that confident in it to, build more amps...
with this most elegant DIY solution.
