Hertz EP1D
Hello
Haven't been working with amps for years but a friend asked me to look at his Hertz EP1D.
Amp's relay does not engage, DC protection kicks in, that means that protection light is not on but the relay is not engaging. Relay is in working order. I checked by applying 12V to its appropriate terminals. Tried to measure voltage on the transistor supplying 12V to the relay while amp was running, when measuring the relay engages, DC on speaker terminals on that moment was 0,5V. Tried playing music through speaker while holding relay open, plays fine, no excessive heating. While relay is not engaged before the relay there is good audio signal, it is just not getting through the relay.
Anyone got a clue what could be causing this problem?
Which Amplifier do i need?
First of all sorry if the thread is in wrong section
2ndly, hello i am new here . First post
Now, on topic,
I just happen to find a really old 8Ohm 75RMS phillips subwoofer lying around.
HTS3152_98-RTP-global-001
i have the sub only, nothing else.
Currently i am running this thing with a cheap tpa3116d2 board
Running with a 24v PSU. But if i am not wrong i am getting max (24x.6x24x.6)/8 = 26w RMS
i want a cheap amp which can drive it to the max potential.
I can have 36v PSU but strictly DC.
Belva BB3000D V2 protection issue
I have a Belva BB3000D V2 class d amplifier. The amplifier will play audio ok, but goes into protect at higher volumes. I do not have very much experience with Class D Amplifiers. I was unable to get a schematic from Belva. What should I be looking for. Any help would be great, thanks.
Isaac
Asking all Bluesound Node 2i owners!
Hi everyone, been away for a while, and am now in the market for a new digital streamer. The Bluesound Node 2i seems a great choice and almost pulled the trigger on it last night. VERY highly rated by customers and a What Hi Fi? 5 star review... then I checked the reviews on the BluOS app (the app which of course controls the node 2i)... DISASTER. A complete 180 departure into 1 star catastrophic oblivion is what came up. LOTS of very negative reviews.
I DON'T GET IT?! Can someone with experience with this device please chime in? Is this a screaming deal or frustrating disaster? Totally can't understand how something can be so highly regarded while its own control mechanism derided as so terrible???
FS: Betsy's. Hemp 8's.
Wild Burro Betsy pair in near new condition. $110 shipped lower 48 usa.
Hemp Acoustic 8's. One pair. Function fine. But cones are faded. Whizzers detached, and creased, not sure could be reused. $90 shipped lower 48 usa.
I changed the ad a couple times when I wasnt getting any rexponse. Am a bit scattered with excess work these days. Sorry. Ill keep it like this.
Thanks, Don
Unity Gain Stability with OPA2365 as a DAC LPF
Hi!
I'm starting the design of my DAC/AMP based on the PCM2903C (for the dac), and the amp part based in the Objective 2. I'm doing this more with the purpose of learning than actually getting a super good dac/amp.
I'm not an expert so I thought that a good place to start would be a product made by, well, experts. So I download the datasheet of the PCM2903C evaluation board and saw that they placed an OPA2353 active low pass filter in the output.
While wandering around in the TI website I saw a equivalent model to the OPA2353, that seems to be better spec'd, while costing the same in Mouser, the OPA2365.
Questions were raised when I noticed that the OPA2353 datasheet stated that it is unity-gain stable, leading me to the thought that it makes some sense, since the active filters should be (inside a desired range of Hz) unity gain stable, right?
On the other hand, the OPA2365 does not claim such a thing, and furthermore, it recommends having a pulldown resistor in the output, connected to an additional negative supply when operating as a buffer, even though, said resistor is not included when the OPA2365 is acting as an active filter.
My questions is then, can the OPA2365 act as a LPF without the pulldown resistor without deteriorating the performance of my DAC? It seems to be an direct improvement of the OPA2353, while costing the same.
Or should I be using an different op amp as a LPF? Do you guys recommend any?
Thank you for your time! :cheerful:
SE to Balanced Line Converters
I am looking for a commercial single ended to balanced line out converter or preamp stage. Pre-made units boxed and ready to go don’t seem to be readily available. It seems like a basic thing but not sure why something for say $40 from Behringer or similar doesn’t immediately come up on a search. However, a $10 Sparkfun THAT1646 breakout board with TRS jack did come up. If anyone has suggestions for a commercially made ready to use one, please share here:
Sparkfun THAT1646 breakout board:
https://www.digikey.com/products/en?mpart=BOB-14003&v=1568
Needs a +/-voltage PSU and a panel jack.
I have made simple 2 transistor converters using a CFP in SE Class A and that works well but looking for an ultra low distortion IC implementation here.
Tubes, chokes, sockets, film caps, ALPS pots, and more... Tom's bargain basement!
I decided to Marie Kondo my lab. I haven't touched tube circuits in years, so my collection of tubes, sockets, high-voltage caps, etc. no longer brings me joy. I think it's time for them to bring someone else joy. 🙂
If you're interested in buying, please toss me a PM or email (add @neurochrome.com to my user ID here). I take payment by credit card directly or by PayPal. Credit card is preferred.
I will use strikethrough and (PENDING) to indicate that a buyer has expressed interest and requested a shipping quote. I will use (SOLD) to indicate when an item has sold.
Unless otherwise noted all tubes are used but not abused.
I will be selling them at the quantities listed.
I'm happy to work out a deal for someone who buys all of it (or all of what's left).
I ship from Calgary, Canada by Canada Post (or DHL if you want it faster and are willing to pay more). I have commercial accounts with both and get a pretty nice discount, which I will pass on to you.
I'll have to quote shipping for each order, but expect shipping to run about $15-20 to the US and $19-25 for the rest of the world (including Canada). If you buy all the iron, the shipping will run a little more.
I'll take $40 (including shipping within North America) for what's left.
--- TUBES ---
  • 6AN4 (QTY 5) - $10
  • 6AN5 (QTY 4) - $10
  • 6080WA, three - $10 (SOLD)
  • 6BY5GA, two - $5 (SOLD)
  • RTC E188CC, pair - $100 (SOLD)
  • Pinnacle 6J5GT, NOS in original boxes, four quads - $25 per quad or $80 for all 16 tubes. (SOLD)
  • Electroharmonix 12BH7A, matched pair - $15 (SOLD)
  • Sweep tubes: 6GF7A (x3), 6LU8, 6KY8A (x4) - $5 (SOLD)
  • Amperex 5842, pair - $30 (SOLD)
  • GE 6SN7 side getter, matched pair - $40 (SOLD)
  • 7721 (= d3A), quad - $25 (SOLD)
  • Sovtek 5AR4, trio, new in box - $30 (SOLD)
  • Tube goodie bag: 6AN8, 6AN5, 6BK7B, 6CL6 (x2), 12AT7 (x2), 6BX7 (x2), 6DW4 (x2) - $15 (SOLD)
  • Voltage regulator tubes: 0A3, 0B3, 0C3. Boxes are pretty ratty (except the 0C3, which has a nice JAN box) - $5 for all three. (SOLD)
--- MISCELLANEA ---
  • STE 8-3 IEC mains inlet filters. Brand new. 115/230 V, 3 A. (QTY 5) - $3 each or $10 for all five. See Post #9 for picture and data sheet.(SOLD)SOLD[/color]
  • Sockets: Various 7, 8, 9, and 12 pin ceramic sockets both for chassis and PCB mount. Most are new. Some have been used for prototyping. About 1.5 lb (750 g) in all. - $10 (SOLD)
  • Turret strips (as shown) - $5 (SOLD)
--- FREEBEES (WITH ORDER) ---
  • 10 uF, 450 V. Bag of about 30. New.(SOLD)SOLD[/color]
  • 100 ohm, 1 W, 5 % resistors (QTY 80) - new (SOLD)SOLD[/color]
  • 220 uF, 400 V, 105 ºC Panasonic electrolytic. 10 mm snap-in types. (QTY 2) - new. (SOLD)
  • 470 uF, 400 V, 105 ºC Nichicon electrolytic caps (QTY 4) - two used, two new (SOLD)
  • 47 uF, 500 V, 85 ºC Nichicon electrolytic caps (QTY 6) - used for prototyping (SOLD)
Select your freebee by ordering at least one of my other items and asking for one of the three freebees listed. One freebee per customer.
--- ELECTROLYTIC CAPS ---
  • 1000 uF, 50 V, Nichicon Muse KZ (QTY 16) - new - $10 (SOLD)
  • 100 uF, 100 V Nichicon Muse KZ (QTY 18) - new - $10 (SOLD)
--- IRON ---
  • Antek AS-4T430. Two windings of 0-70-430 V @ 460 mA, two windings of 6.3 V @ 4 A. 400 VA total. Used for prototyping, leads uncut. - $20 - See Post #8 for shipping charges. (SOLD)
  • Electra-Print #8037: 70 H, 20 mA plate choke / inductor, (QTY 4) - $60/pair; $100 for all four. Used for prototyping, leads uncut. (SOLD)
  • Hammond 156R: 1.5 H, 200 mA inductor, (QTY 1) - $5. Used for prototyping, leads uncut. (SOLD)
  • Triad C-14X: 6 H, 200 mA choke / inductor (QTY 1), new in box. - $5 (SOLD)
  • Triad FP230-50: 230 VCT @ 50 mA, 12 VA transformer, new in box. - $5 (SOLD)
--- POTENTIOMETERS ---
  • ALPS motorized pot, 50 kΩ, audio taper, stereo (QTY 4) - $10/each or $20 for all four (SOLD)
--- FILM CAPACITORS ---
  • 47 uF, 630 V Solen polypropylene caps (QTY 4) - two new, two have been used in prototyping, never cut (or even un-bent) the pins - $25/pair or $40 for all four (SOLD)
  • 2.2 uF, 630 V Solen polypropylene caps (QTY 4) - two new, two have been used in prototyping, one has cut pins
  • 220 nF, 630 V Solen polypropylene caps (QTY 8) - most are new, some have been used for prototyping.
  • 100 nF, 630 V, polypropylene Epcos P/N: B32652A6104J (QTY 4) - new
  • 0.1 uF, 630 V polyester cap Panasonic ECQ-E6104KF (QTY 30) - new
  • 1.0 uF, 630 V polypropylene Epcos P/N: B32674B6105K (QTY 6) - new
  • All 52 caps on this list: $10
  • (SOLD)
Thank you tubes... 🙂
Tom
Bluetooth Speaker with "programmable equalizer"
Hello everyone, I'm trying to do my first project with DIY Audio. I have found a old radio in the shed, a big wooden box from GDR times.
After checking it it did not seem to work and there are not that many circuit diagrams for that exact model so I figured I would try converting it into a bluetooth speaker (not a portable one but still).
I found this youtube video of someone building a 2.1 bluetooth speaker and thought that I might be able to pull that off: YouTube
I wanted to maybe change it up a little bit as some parts would be easier for me to aquire, the whole voltmeter part would also be left out because it does not fit the aesthetic of the old radio.
I now have some questions for parts and compatibility. I wanted to go for a "Class D" amplifier: TPA3116 2.1 Klasse D Digital Verstarkerplatine Amplifier Board 100W + 2x50W DE | eBay. It has 2x50W and 1x100W output. I also wanted to use crossovers: 2-Stuck V-150 2 Wege Frequenzweiche Crossover Weiche 150W 4-8Ohm 3-3,8kHz 12dB | eBay (sorry that all components are from german ebay).
As I am really completely new to this: first question: would the amplifier and crossovers be able to work in this configuration? Also: what should I look for when looking for drivers for this setup.
My second question for that matter would be how to arrange the insides of the speaker or is that information given in some way in the specifications for a driver. Maybe it isnt really necessary, I dont want to have the utmost high quality sound.
The bluetooth receiver part shouldn't be to hard to pull off. But I would like to add one last thing: a kind of "pre-amp" (?). I don't know the terminology but to describe what I want to achieve: I know that there are adjustable equalizer pre-amps like this: Stereo EQ Equalizer Board 15 Band 2.0 Kanal Vorverstarker Ton verstellbar Preamp | eBay. On the front of the radio are buttons labeled "Bass", "Jazz", "Voice", and so on. This would correspond to some kind of EQ-Setting (for example on a smartphone). My third question is: is there some form of "programmable equalizer" to achieve this change of EQ-settings on button press?
Thanks for any help, I know my questions are pretty broad (at least the second one) but maybe there is a quick answer to that. I don't want to get into creating speakers for eternity (at least for now, maybe this will change), so I really dont want to spend money on a book.
Need help on crossover for Jensen H222 coaxial
I recently got a pair of Jensen H222 (16ohm) coaxial driver and using them on open baffles. They were designed to crossover at 2000Hz. I want to build a crossover with new component for them. I already experimented disconnecting the old cap and connected a new 3.3uF Clarity Cap (which is what I have on hand) to the tweeter while keeping the woofer connecting to the original coil. It sound better already than with the old cap. Originally, they should have only a 1st order crossover but I can't be 100% certain as they are potted in a small cover.
Someone pointed out that Jensen have equivalent separate woofer and tweeter to the H222 coaxial which use the A204 (2nd order) crossover. The A204 is a 2nd order butterworth as shown in the picture. At first, I was thinking to build my crossover base on the A204. Then I read that Linkwitz has a more flat response so I am leaning more toward the Linkwitz design. I wonder what kind of difference should I hear between the 2 kind of crossover?
Also, if I want to save money on parts; can I use lower quality cap or coil for the parallel connection to the tweeter or woofer so that I can put some better one connecting in series? Or should I keep them all the same?
For the coil, would it be better to go with a smaller gauge foil or a larger gauge wire coil for the same money?
Mesa/Boogie Rocket 44 tube amp repair
I picked up an "as is" Mesa/Boogie Subway Rocket that was salvaged from a storage unit that had some flooding.
Initial inspection shows really no water damage to speak of. The high water mark is a full foot below the amp chassis so there was no direct water intrusion. Even the speaker survived and even the cabinet is none the worse for wear. I think it got a few inches of water that quickly receded.
However, although the amp ran OK when first tested, which only happened AFTER a teardown and inspection for corrosion issues, (It's very clean, really pristine actually.) after a couple hours of operation it developed an interesting problem. The whole power supply sags badly, and the bias supply sags worst. Normal B+ to the power tubes should be about 460 volts and bias, around 12. After several seconds on, bias drops to about 6 volts and B+ is down around 380.
Note, this happens even with NO tubes in the amp. So it's not a shorted tube.
Since all the capacitors in it are of 1999 vintage by the date codes, it's time for them to go. So I ordered a full set and swapped them all out with fresh caps.
Tests repeated. Results...SAME. With fresh caps.
Basics of the Rocket 44: 4 12AX7 tubes in the preamp stage, 4 EL84/6BQ5 output tubes, 44 watts rated output. Fairly conventional topology.
Subway Rocket is nearly the same amp.
Aside from hot tubes I'm not getting any hot or burning component smells.
So, the question I'm asking and trying to troubleshoot my way to an answer is, what is dragging down the power supply, and the bias supply most of all?
I tend to believe it's not a transformer issue. If it had a bad transformer it shouldn't be coming up to rated voltage at all. Well, if I'm wrong, a new transformer for this model is not expensive.
I have had an amp with a bias power supply problem before that was a bad bias coupling cap, an Orange Drop that shorted after that amp was recapped. The increased voltage from fresh healthy caps killed the Orange Drop so that was replaced, no further problems.
This is kind of a challenge. Usually when I see a problem with high voltage supplies that are being dragged down like this, there's evidence somewhere on the board. Some component(s) are expected to get HOT and be pretty easy to find. This one...not so much.
35x 6AU6 Pentodes
I have roughly 39x 6AU6 pentodes, all used and untested. I can throw in about a half a dozen 6AV6's as well. These aren't specifically audio tubes, but they may be fun to play around with. Heck, you could tie 'em together with some string and hang 'em on a Christmas tree (just don't plug 'em in if you do that!)
Anyway, $30 +shipping from 94591 takes 'em.
Need help on building a FAST / WAW speaker with TB W8-1772 and 55-2421
I really like the sound of full-range speakers and I'm going to build a pair for a friend. His living room is quite large so some bass augmentation is necessary. I've been trying to figure out how to build a FAST speaker using W8-1772 and MCM 55-2421 woofers. I plan to use 2 of these 4 ohm sub drivers in series. My dilemma is should I bi-amp the full range and sub drivers with an active crossover? If I do that the system becomes more complicated, needing two amplifiers, more cabling, etc. I also considered using separate plate amps to simplify things but the plate amps I find are either too powerful (ie PA) or don't have enough power. I'm building the speaker for a friend who isn't technically savvy and likes things really simple. So I want to let him stream from his phone via bluetooth or wifi and avoid burdening him with extra knobs and buttons to fiddle with. The last option in my mind was a passive low crossover and a 2 ch integrated amp to drive both speakers. But passive xo's are totally uncharted territory for me. Any suggestions?
Best,
Selim
35x 3A4 Pentode Power Tubes
I've got roughly 35 3A4 pentode power tubes, all used. I tested a couple and they tested OK. These are relatively low voltage and low power, about 600mW each class A. If anyone wants to experiment, there are plenty here to play with. I haven't got any sleeves for these, so they'll be a hassle to pack and ship. Local pickup is possible. $35 +shipping takes them all. Shipped from 94591.
10-15x 6005 / 6AQ5 EL90 Beam Pentode Power Tubes
I've got maybe 10 or 15 6005 / 6AQ5 beam pentode power tubes. I tested one of the 15 tubes and it measured OK, but some of them look like they might be a bit tired. You can get about 10W out of a push-pull pair. I have no sleeves, so I'll have to wrap them in paper towels or something. Bit of a hassle. $25 +shipping takes the lot. Local pickup is possible. Ships from 94591.
Occasional low frequency problem
Hello all, this is my first post here.
I bought a nice 1952 Browning RJ-12B tuner several years ago, so decided to build an amplifier and make a radio. I started with a power transformer from a Stromberg-Carlson radio, but bought a nice new audio output transformer. The amplifier works and sound nice, but every now and then it will put out a low frequency signal (even with no input) which causes the low frequency speaker cone to move back and forth at what I timed to be 1 or 2 cycles per second. Any suggestions?
Yesterday, I changed the input filter capacitor to 40 MFD, but that did not help.
With the Browning tuner and Renegade speaker I intended to use:
The schematic
Testing a # 46 tube?
I have a few gorgeous nos RCA Radiotron/Cunningham # 46 tubes. I have three testers, a Hickok 600a, a Hickok 550X and a Mighty Mite V.
I know how to test a tube of course but the problem is that none of my testers has data for a 46. In fact they don't have data for any of my globes. I need that data to test them but I don't know where to look. I searched but did not find anything.
Thank you
FS: Iconic speakers
SOLD: Iconic speakers
Now that I have your attention ...
A piece of me died inside today listing these but I am recently an open baffle "convert" and I don't have the room to properly store these. It would be a shame to store either of these speakers anyway!
There is no point typing everything twice and taking up server space with pictures so I will link my FB ads.
1. Snell Type-E/II's in walnut. Sequential SN's, ALL original (disabled rear ambience tweeter) and DIY stands.
2. HIGHLY-modified Klipschorns. Crites cast woofers, Eliptrac tweeter w/B&C DE10s, ALK CSW crossovers, Rosewood veneer
Due to size and weight, I will not ship. Please contact me if you want to audition them.
SOLD
Mystery Peerless Tranformer
I have an old Peerless/Altec transformer with part of the label missing. The part that is there states it is a Type B-1... Unfortunately the rest of the part number is missing. I've looked through their catalogues from the era I believe it is from (50's) and there is no 'B' prefix letter id to be found.
Any ideas?
I'll try to take some photos in the next few days...
Bridge Rectifier vs. Schottky Diodes for F4
This is the last item I need to add to my parts order for building an F4, so I need to make a decision between using the universal PSU with Schottky diodes or a bridge rectifier block.
I built my F5 using the diyAudio Universal PSU with Schottky Diodes.
I'm leaning towards the rectifier block as it saves space in a 4U chassis, and the easy of installation.
I just wonder if I'm giving anything up?
Magnet to Magnet
Hey everyone,
I was wondering, is it possible to place two speakers magnet to magnet (back to back) using the same enclosure?
So
Speaker 1 is placed on the baffle and its magnet is inside the enclosure, that enclosure is closed off by a panel, in that panel is speaker 2, facing with its magnet to the other speakers magnet.
Is this possible and does it bring any problems with it?
What things should i look for and watch out for?
Ive attached a sketch of the scenario
Raspberry Pi + CirrusLogic Audio Card = FAIL
Anybody had luck building a decent music rendering system out of the Raspberry Pi plus a Wolfson / CirrusLogic Audio Card? My efforts have been a disappointing FAIL.
I'm trying to build a simple media rendering device out of a Raspberry Pi. I know, I know, it may not be the most HiFi solution to the rendering problem, but for this application I'd be content if I could get something up and running that works like a Squeezebox and has passable audio quality for non-critical applications.
The inherent audio system of the RPi (analog output) is well known to be just awful. My experiments were in line with everyone else's in that regard -- the result was lots of cracks, skips and pops. It was a total failure.
Things looked encouraging when Newark Electronics / Element14 in the USA started to co-market the CirrusLogic (formerly Wolfson) Audio Card. I'm in the US, and having a local distributor like Newark / Element14 seemed like it would solve some of the accessibility problems involved in ordering parts from the UK.
The CirrusLogic (Wolfson) card seemed like a decent option, but so far all of my efforts have resulted in failure. I'm wondering if anyone else has gotten the combination to work, and if so, how they've done it.
My first effort was to buy a new Raspberry Pi 2 (quadcore) device and a copy of the latest CirrusLogic Audio Card from Newark/Element14.
When I bought the CirrusLogic card, Element14 was marketing it as being compatible with the RPi 2, but they stopped advertising it as being RPi-2 compatible when it became evident that it was only pin-compatible as a plug-on card, and was not software compatible.
The problem, as discussed on the Element14 site, is that CirrusLogic still hasn't done their job of writing the ARM-7 compatible drivers for the quadcore RPi-2. At this point in time, the software support for the hardware on RPi-2 remains vaporware, which has resulted in quite a few disgruntled customers.
Community: Cirrus Logic Audio Card | element14
My second effort was to fall back to installing the CirrusLogic Audio Card on a Raspberry Pi B+.
Since the audio card wouldn't work with the ARM-7 quadcore RPi-2, I decided to use the ARM-6 RPi B+ as a fall-back option. Element14 is still advertising these products as being compatible. Unfortunately, my efforts to get the card up and running on the single-core RPi B+ haven't fared much better:
With the B+ I've found it impossible to build the kernel drivers, largely due to the fact that the manufacturer's wiki article is poorly written and contains enough errors to force the effort to result in a FAIL.
Has anybody had luck in getting the Wolfson or the CirrusLogic Audio Cards to work as a rendering device on the Raspberry Pi? I'm having a bear of a time getting the hardware/software to work, and I'd really like to know if anyone has been successful in doing it.
If you have been successful, please let me know whether you've been happy with the quality of the audio output and the usefulness of the device as a music renderer. I'm hoping to find out if it's possible to succeed in the task that I'm trying to accomplish, whether the functionality and sound quality are worth the additional time and effort that's going to be required to get it to work, or if I should just fall back and punt.
TIA.
I need some new woofers
I'm working on a 2-way system using a stack of 4 5" woofers in a 50L box. My initial choice for the drivers was poor, and I've given up trying to get them to work. They have an aluminum cone and sound like a pie plate. I'm using the miniDSP-HD in an active crossover system and have tried all manner of EQ.
I have my eye on the Silver Flute W14RC25-08 as a low cost option and the SB Acoustics SB15NRX30-8. I like the low VC inductance of the latter, but it is pricey.
I've also just come across many Peerless options; maybe the TPY05W08O0088, Heritage.
I'm looking for any comments on these specific drivers or any other suggestions.
Thanks,
Chris
Having cabinets CNC cut for you - experience, costs?
I built a kit from Madisound, which most importantly came with 'prefect' CNC cut panels which allowed for easy (and perfect) assembly. At $130/cabinet (before discounts for the kit), it seemed obvious they did a big run and were able to get some efficiencies.
Is it common to get plans and have a shop CNC cut material of your choosing for just one single pair?
I think it is less an issue of a shop that 'can' do it vs. one that will do it for anything approaching a reasonable cost. For a modest pair of small towers, I imagine you will pay a bare minimum of $200 on top of the materials. Further, if you brought them a design, it would need to be translated into a file the CNC machine could use (so maybe minimum of an hour of billable labor on top of the actual build time)?
To be clear, only talking about getting the pieces cut, not an assembled cabinet.
Output
I have this TPA3116 board. Why are the speaker outputs both at 12V relative to the ground input? I've done some gain and input circuit mods but this isn't normal? Running it at 24V with a switching power supply. Otherwise it works well but just noticed this. The + and - speaker outputs are mV as you would expect, but both +12 relative to ground and input voltage!
any ideas??
Thanks,
Thei
Speaker Recommendation
Current system: Akitika PR-102 preamp and GT-102 power amp with Bose Interaudio 4000 speakers. I'm currently considering 3 sets of speakers for my next upgrade, and would like to know if driving any of these with the Akitikas would be asking for trouble. Also if one jumps out as a much better fit than the others, since I won't be able to hear the last two before making a purchase.
Option 1: A pair of nicely reconditioned JBL L100 speakers from a friend. They were put in nice wood cabinets about a year ago and got everything that needs to be replaced over time upgraded, so they sound better than new. They'll be about $2500 plus 5 hours in the car with the friends and family discount.
Option 2: A pair of Polk LSiM707 since it's that time of the year for Polk's half off sale. After tax (grrrr) that'll be about $2150 for the pair. This seems to be the most questionable for whether or not the Akitika will drive it. I seem to remember reading that these needed a beefy class D amp somewhere, but I could be thinking of something else.
Option 3: Save some more money and get a really pretty Seas Odin pair as pictured on Madisound instead of one of these. Seas Odin Speaker Kit - PAIR
Parasound HCA 806 with some bad channels
My Parasound HCA806 has at least 3 bad channels. The symptom is a heavily distorted sound.
I have done quite a lot of basic electronics repair over the years so I'd like to try my hand at fixing it. I have a few questions:
1) It seems like the capacitors are the common problem in old solid state amps. Should I just go ahead and replace them in one of the bad channels as a first step? What model of capacitor should I buy?
2) I couldn't find schematics for this one, but I have them for the 800 and 855. Is anyone here familiar enough with Parasound to know if these will be helpful (or even better, does anyone here have the 806 service manual or schematics)?
3) Should I let the amp sit for awhile before opening it up? I have read that if you're not careful, amplifiers can discharge quite a lot of electrons even when they are unplugged.
Thanks!
Mark
Whaferdale Pro S-1500
Hi
Does anyone know what is the bias setting for this amp. There are 3 trim pots, VR4,VR5 and VR6 on each power amp board, no information is given on the schematic on the bias settings. I guess that VR6 is for biasing and VR4 and VR5 for DC offset. I have replaced some blown power transistors on each channel. I did not rebias after replacing the transistors, but using the preset bias. After leaving the amp ON for 2hrs, the left channel feels warm but the right channel is hot. Please assist. Schematic attached.
  • Locked
Global Movement to shift manufacturing from China to Elsewhere
Hi Friends,
I am an Indian Resident. As we all know that agter COVID-19, World is changing rapidly and this might lead to averting of purchaser countries to import from China. This will definitely be an opportunity for some other country to begin manufacturing facility.
I am just creating this thread to access effect of this polorization.
B&W ASW 855 turning off when heat up
Hi, I got my hand on cheap B&W sub that plays pretty nice bass but when played out loud or for long time, it turns itself off. After letting it cool down and turning it back up it plays like nothing happened.
I guess its overheating because thermal connection between parts and heatsinks are bad after all those years of usage. But I am no amplifier expert, I know my basics, can build stuff from kits and so. So just to be sure - is there any other reason for class D amp to turn itself off other than heat?
Thanks to you all kind people
LTSpice KT88 model problem, or schematic?
While I'm waiting for my transformers to come in, I thought I would give LTSpice another shot and play around with some values. I had some trouble with the 12AX7 model in the past, but worked it out. Now I'm trying a KT88 and I'm not really sure what I'm looking at here.
Basically I am getting -223KV on the grid. I played around with different values(which is why some of them might seem wacky) to try to get the grid to "move" to see why it's doing this. I detached the signal just in case it was coming from that somehow(impossible with the cap).
Is there something obviously wrong with my schematic or is my KT88 model borked? Someone else on this board had a similar problem, which they fixed by renaming the symbol's pins to match the model. This did not seem to help.
AudioStatic ES-100 power
I just bought a second hand AudioStatic ES-100 print. It has 2 wires for power supply connection, but I'm not sure what voltage to connect. Can I connect it straight to the mains (220V, Europe), or is it a lower voltage like 12 V? When watching photos, I see just a wire from the rear of the ES-100, but I've read about 120 / 12 V power supplies for the ES-100 on this forum. I wasn't able to find a schematic of the ES-100, only for the ES-100, where a 9V voltage input is printed.
Kind regards, Jeroen
Cubo Kick 15 measurements
I apologize if I have overlooked it, but I couldn't find measurements of the Cubo Kick 15 design anywhere, so I thought I'd post them here.
The bin has been built according to the available plans on freespeakerplans.com, but with 18mm poplar multiplex, which was on hand. This makes it VERY light, but it needs some more reinforcements (which we still have to implement). It is loaded with the 18 Sound 15ND930, 8 ohms.
Measurement is with 2.83V at 1m, mic on the ground, measured outside, 2pi.
THD seems a little high 😱. We'll reinforce the cab and do some more measurements.
My second Tubelab Simple PP! A pentoad Frog!
Working on my second simple pp! The first one was set up in triode mode and this one will have pentode outputs with a regulated screen supply.
I am thinking a pair of stacked glowtubes would suffice for a screen supply and look pretty...
The outputs are a pair from stancor out of a Heathkit AA-100 that are 7kpp with 0-4-8-16 secondaries.
Its coming along...
Western electric compression driver clones
Good day
Currently i have pretty good modern hybrid system with radian 950+k402 on top and bass reflex low section.
But i`m going to grow a bit)
I`d like to try something like western electric 555 driver + we15 horn, but originals are too expensive for me and i`m a bit scared of 5 watt maximum power handling.
Horns aren`t a problem because there are people in my country (Ukraine) that are making we15 clones for much cheaper. The main difficulty are drivers.
I am looking at clones like lamar audio and G.I.P.( don`t know more, maybe you can recommend other).
And i have a few questions:
1)Maybe someone was able to hear them and can tell me how do they compare with original we555 and more modern drivers?
2)If someone used such a deep horn, how did you manage with time delay between woofer and driver?
3)I have read Geddes and many other literature about horns and all of them share the same opinion that such a long horn can`t sound good. Is it true? I have no possibility to listen them, aren`t they just a cool vintage stuff that sounds bad?
Would be very grateful for any thoughts of more experienced colleagues
Reactions: David Whistance
Akitika gear "can't" have XLR?
I shot an email to Dan at Akitika and told me that you "can't" have balanced input/output on the PR-102 or balanced input on the GT-102, but didn't get anything back when I asked why not. Does "can't" mean he doesn't want to mess with and/or support it, or is there some design limitation that prevents anything other than RCA from being used?
In principle it sounds doable. Remove the RCA jacks, drill a bigger hole (probably limited to one input and output on the preamp due to the proximity of the jacks) and drop in the new XLR. Am I oversimplifying and missing something obvious? I ended up getting the preamp and power amp second hand so I didn't do the builds on these.
Sooo...XLR on Akitika. Anyone actually done it and can confirm that's it's possible? 🙂
FS dual lt3081 voltage regulator pcb & lt3081/lt3091 bipolar power supply pcb
As the title says I am selling 6pcbs(3 of each kind).
Both pcbs, the dual and the bipolar are the same dimmensions and have the same mouting holes.
Some details about them
102.54mm * 251.44mm ;
Layers: 2;
PCB Thickness: 1.6mm;
PCB Color: Green;
Surface Finish: Hasl;
Copper Weight: 1;
The boards are designed to be used with avel lindberg 50VA incapsulated transformers.
Transformer input is configured only for 240Vac input.
The dual lt3081 pcb has 2x lt3081 each one connected to a secondary winding of the transformer, completely independent between them.
The bipolar lt3081/lt3091 pcb has one piece of each reg and these are connected each one to a secondary winding of the transformer thus isolated between them also.
I will describe in short what is on the pcbs.
We have ac line in, fuse, transformer primary.Since I have opted for screened transformers I have connected the transformers screen to ac earth as suggested by avel lindberg.
After the transformer I have c rc network to eliminate rectifier diode ringing.I can supply the values of the components for these networks for the 50va 2x20V and 50va 2x12V transformers.
Next are the rectifier diodes, after them a crc filter and finally the lt's.
For the lt's I have included a 1206 smd resistor to setup output voltage, or you can use a pot which has also it's own place on the board.
In the first photo you can see the bipolar pcb. If you look on the bottom you will see the outputs which are signed as out_pos and out_neg.
Second photo is the bipolar pcb bottom.
Third photo is the dual ps pcb.
Fourth photo is the dual pcb bottom.
Fifth photo shows the bipolar ps front side.
Sixth photo shows the dual ps powering a b3se dac and cronus reclocker.
Seventh photo show the back of the bipolar ps.
Eighth photo shows bottom of the bipolar ps.
Nineth photo shows the bipolar ps near a legto iv stage which was powering with succes.
All boards are sold
Thanks.
High efficiency Two-way design, where to cross them
As a "thought experiment", some musings, trying to design a super high efficient two-way. The two culprits are the Audio Nirvana 15" classic ferrite, and the Aurum Cantus G3...
By plotting the two together, my best guess is a first order for the AN 15 at about 2K, so by 4K it has tamed that rising response, dragging down that hot spot 6Dbs worth...what do you guys think?
----------------------------------------------------------------------Rick........
Best "bang for the buck"5 inch full range is?
Hi Gentlemen,
I am delighted with my just finished Alpair 10P speakers. I have built several smaller full rangers using Tang band 4 inch drivers in the past and liked them pretty well, but the Alpairs are in a whole different league. I would like to turn a couple of friends on to this full range experience, but dont want to spend more than necessary on the builds since I'll be gifting them.
A while back forum resident XRK, who is very knowledgeable, suggested that on a super low budget the Dayton Audio PA 130 would work well for the price. I built a pair, and while they were not bad they had little to none of the "magic" I hear in the 10Ps.
So, are there any full rangers that approach the bass depth, detail, and SPL levels of the 10Ps for a significantly lower price? I think I'm asking for a lot here but am hoping that there are some hidden gems out there.
Best,
Jay
Valve ( tube ) Characteristic Tester.
I have no idea if anybody has posted this before but if anybody has the time and patience its not too hard to build .
Keep in mind this is a "proper " tube tester in that it employs a Wein bridge oscillator to test the tube .
The circuit is available in issues of ETI magazine -
Volume 26-number 8 and volume 26- number 10.
It can be accessed on that wonderful American radio heritage website -
RADIO and BROADCAST HISTORY library with thousands of books and magazines
Design Stable @ 1 Ohm Nominal?
Good evening all,
I am experimenting with a Frankenstein re-build of an old pro-sound subwoofer. The only voice coil I could find so far is from the car audio world, and is rated at a disturbing 1 ohms nominal impedance.
Do any of you know of a module or proven design which is stable at such a load? I thought of using a car audio amplifier, but it seems a shame to step the mains voltage down to 13.5 or whatever, only to have the power supply in the mobile amp step it back up. North of 500 watts RMS if possible!
Thanks for your help,
JF
Impedance of two drivers at their crossover cut-off?
Hello,
I'm using this site for rapid crossover simulation of two raw drivers : Speaker Crossover Calculators by V-Cap I like the possibiity to enter the impedance of the high pass and low pass for each driver.
I please have a question about these two impedance : should it be the impedance of each standalone at the precise cut-off frequency or the average Re (voice coil resistance) given in the datasheet... Or the lowest impedance point where the impedance curves meet each others in frequency ? I.E : the impedance at cut-off of the weakest Z of the two drivers cause this is what see first an amp!
Just for illustration : 2 bass driver, 2x 8 ohms with a Re of 7.8 ohms , chosen cut-off : 300 hz, here the impedance of the two // drivers measured raw is not half of the 7.8, i.e 3.9 ohms but 3.4 ohms.
The mid driver ha a Re of 7 ohms and at 300 hz the impedance curve is 6.5 ohms.
Sould I putt in the calculator at 300 hz : low pass : 3.4 ohms and high-pass:6.5 ohms or should I simply enter the average Re of each drivers given in the data sheet : 7.8/2 for the 2 bass : 3.9 ohms and 7 ohms for the high pass for the mid driver ? Or I enter the lowest impedance for the high and low pass cause electicaly this is where it goes : 3.4 ohms
The question is for passive XO but I ask for active crossover as well : has the exact impedance at Xo cut-off to be entered in the soft parameters as well or just the average Re of the drivers.
Many thanks.
Inductor or resistor?!
Hi this is my first post in this forum. I am trying to restore a pair of German made ALR Nummer 4 speakers which I picked used. There is a crossover board inside which for the midrange and the tweeter and a separate board for two woofers. On the mid-tweeter board, there are two components which looks like resistors but had 47RJ written on them. They are as big as a 3W resistor. are these resistors or 4.7uH inductors ?? How can I find it? I replaced them first with 3W carbonresistors and sound became very shouty which is not at all close to the working pair I have. But when I used a 0.82ohm small 0.25W resistor it sounds close to the good speaker which made me think this was an inductor more than a resistor.
What is the difference between wirewound resistor with value 4R7 and inductor 4R7?
Mono sub channel summation
When we're talking about active crossovers, setting the gain is pretty straightforward when we're talking mid-to-high frequencies; just give the stereo channels a flat response. But I have a question about what happens when you have a mono sub. Do you make it so that the sensitivity of the mono channel is (up to) 6 dB higher because there is only a single channel, or match the sensitivity with the stereo channels because the summed signal will automatically be at a higher voltage and result in the appropriate higher SPL? I'm leaning toward the latter but would like to hear others' opinions/facts.
CGR Mar-Kan 10.3 Question
In fear of too much bass in my room I changed my mind and want to build the CGR Mar-Ken instead of the Pensil for the 10.3. My old (2005) Seas 21cm bass was too deep & mighty for my room.
I think the CGR Mar-Ken or BR will show more 3D/soundstage and detail than the Pensil.
The question is: Can I transfer the vent to the back? I cant see any problem doing that....or?
Thanks in advance.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,835
Members
7,890,191
Messages
Filter
Forum Statistics
Threads
406,341
Messages
7,890,191
Members
507,835
Latest member
hightechh
