Hello,
I want to mod a sega saturn to output spdif, i need it for my dac + amp + speaker combo. The saturn provide an i2s signal with a master clock, so it shouldn't be very hard to do...
There is a known mod that can be done to do it, most people use a basic CS8406 board to do it.
As i had to make an order at audiophonics, i bought this i2s to spdif interface :
Digitale Interface I2S vers SPDIF BNC WM8804 - Audiophonics
This thing has a terminal block for a 5v DC plus the i2s input. Strangely there is a DATA 1 and DATA 2 on the i2s input, i don't know why.
My saturn is a model 2 japanese with a TDA1386T dac. I get the 5v DC from the pin 9 - 10, i check with a multimeter and it's fine. For the i2s signal i connect this way :
MCK to pin pin 12 (sysclk)
BCK to pin 4 BCK
LE to pin 5 (word select input)
DATA to pin 6 DATA (i2s Data)
For the GRD, two cable connected to the pin 9 (digital ground) go the the i2s grd connector and DC terminal block ( - in the photo).
The spdif kit power on, tension is good on the dc terminal. I connect it with toslkink and there is light, but no sound. I check the tension in the i2s input, i get between 3.2v and 1.7v depending on the input, so there is no problem with the connection.
I hate these chinese board because audiophonics do not give a s*** to give correct technical information and the technical service don't know much better. I have problem in the past and now it's the same story, i won't even ask audiophonics it's a pure waste of time, and every info i could find on these board are of course in chinese.
This board has a i2s input and output, plus 2x spdif output (toslink and rca / bnc). I start to think there is a way to choose between the i2s output and spdif outputs. I check the tension on the i2s output and there is the same voltage as the i2s input, so the i2s out is active. There is no sign of jumper in the front of the board, but in the backside there is an IC close to the i2s input, and two resistor (R20 R21) that can be put in different position.
https://zupimages.net/up/20/32/5idx.jpg
Any idea ?
