Hi, first time poster 🙂
I recently have built a power amp based on Hypex NC122MP board. I bought a Ghent Audio connection kit, and it went quite smoothly. The only issue I have is a humming noise in both speakers, not very strong, barely perceptible from the listening position, which seems to be specifically related to the input connection.
For reference, in the NC122MP, the inputs are mapped to the following pins of the J4 H-Box connector:
- for channel 1:
--- pin J4.1 - inverting signal ("-")
--- pin J4.2 - non-inverting signal ("+")
--- pin J4.3 - ground
- for channel 2:
--- pin J4.16 - inverting signal ("-")
--- pin J4.15 - non-inverting signal ("+")
--- pin J4.14 - ground
I use the Ghent Audio h-box connector to attach shielded 3-wire input cables, connected to the RCA sockets. "+" goes to RCA pin. "-" and "ground are soldered together, attached to RCA sleeve, and are grounded tot he chassis.
Here is what happens:
Case 1: Amplifier powered on, connected to 2 speakers, all wires disconnected from the J4 H-box -- dead silent
Case 2: Amplifier powered on, connected to 2 speakers, input wires, connected to the RCA input sockets, with sleeve grounded, are connected to J4 H-box, nothing plugged into RCA input sockets -- humming noise
Case 3: Amplifier powered on, connected to 2 speakers, input wires, connected to the RCA input sockets, with sleeve grounded, are connected to J4 H-box, a source (network streamer with volume control) is plugged into RCA input sockets -- very slight humming noise, I really need to put my ear to the speaker
Case 4: Amplifier powered on, connected to 2 speakers, all wires disconnected from the J4 H-box; 1 single wire, 2-3 cm long, attached with a JST connector to J4.2 (channel 1, non-inverting signal, or "+") - same humming noise in channel 1 speaker as in case 2.
Basically, looks like
- powered on, connected to speakers, but with nothing attached to input pins, the amp is dead silent (except the usual slight pop when powering the amp on or off).
- attaching anything at all to "+" signal inputs provokes humming in the corresponding speaker.
- attaching an actual source on the other end of the connection cable does not stop, but attenuates the humming.
Any advice on possible causes, or troubleshooting hints would be much appreciated. Thanks.
