Grid tension that moves by itself ... on C. Follower, Why?
- By TasoTaso
- Tubes / Valves
- 17 Replies
Hi, I have a problem ... but I don't know if it's a problem.on my prephono based on Audioresearch SP3/6...clone.
V1 = ecc83, V2 = ecc83, V3 = 6n1p.
When I measure on the V3 grid and on the V3 cathode to see the voltages and calculate how negative the grid is ... I notice that the voltage is not stable ... it moves ... it goes up and down ... it goes down and it goes up ... it goes up and down .. it is so unstable that I can't figure out how many -volt they are.
I find the unstable voltage on the grid and on the cathode of V3 and on the anode of V2.
The range of motion is about 1.5v on about 135v (Vk of CF).
Who makes who move? Whose responsibility is it?
Obviously the stages are continuously coupled. It's normal?
It seems to me that in the past, doing these measures, I had not established.
To be honest I do not remember well if in the past, when I measured, it moved .. I think not .. but I'm not sure.
I point out that the power supply voltage is perfectly still as I also have a mains stabilizer (voltage in the house 230v + -1%).
I tried to change both the V2 with other ecc83..che put in V3 another 6n1p, then a 6n23p then an e88cc ... it always does the same .. the voltage moves.
Can you give me information about it?
