Low Mu Preamp Build
- By Jenghis
- Tubes / Valves
- 33 Replies
Hi everyone,
I'm in need of a new preamp, and Pete Millett's Low-Mu Triode Preamp looks like it will fit the bill for my system:
Low-mu preamp
I'm looking for feedback on a few mods to the design, I know there's a few people here who have built or heard this design.
1. I want to use the Hammond 270FX power transformer, but its 6.3V winding can't supply enough current for all the tube heaters. Would it make sense to use a separate 6A 6.3V transformer to power the EL34 heaters, while using the main transformer 6.3V winding to power the 6AS7 heater? The EL34 heaters need to be floated above ground to avoid exceeding the heater-cathode voltage difference, so this way the 6AS7 heater wouldn't need to be elevated too. Might be possible to rectify and filter the 6.3V heater supply for the 6AS7 as well.
2. Instead of a 5U4GB rectifier, I'm thinking a 5AR4 might be a better choice. The 5U4GB heater current would max out the 5V winding on the 270FX at 3A, whereas the 5AR4 only draws 1.9A. It doesn't look like the power supply would exceed any limits of the 5AR4.
3. I think for the preamp tube itself, I'm stuck with the 6AS7 and 6H13C variants. The 7236 and 5998 tubes seem to be in short supply. Would either the 6080 or 6H13C supply more gain than the 6AS7?
Thanks in advance!
Low-mu preamp
Thanks in advance!
