Angling a subwoofer in the enclosure
In an upcoming build I would like to include a 12” woofer but the size of my tower is only 10” wide on the outside. I am considering downfiring the sun and angling the baffle to fit. I have the depth to do this just not the width.
My goal is to not have to put a sideways facing subwoofer.
My plan is to use an SVS sub because it is $600 and comes with the sub and the amp. I’m just going to rip it all apart and shove it into this cabinet. They only have 12s. It’s a cost savings and I have heard these sound really good.
Fixing Broken legs on rectifiers
These rectifiers stand up in the amp and use spring clips to keep them tight against the heatsink .
Pretty much all of the rectifiers have broken legs on them .
Would soldering need legs on them be a reliable repair since they stand up in the amp or will they break again and I should order new ones ?
Najda DSP board setup file - please help
Hi, I'm new here but figured I'd jump right in with a problem that is bugging me.
I have in my possession a Nadja DSP Preamp with a v1.3 board. This unit fixes all the time alignment issues with my system but I no longer have a copy of the .nsf Nadja Setup File. Is there a way to read the setup file from the board? Or is there some other way to derive the parameters from the board?
Thanks in advance for you help.
175L active two-way build. Again...
A bit of a re-start here because I previously had eyes on this a few years ago, but stuff like divorce got in the way and y'know, plans go off track... Long story short; Calpomos was the original plan but time and tech move on. I'm in a position to build and afford (within reasonable limits!) a large two-way to replace my Klipsch Forte IIIs and twin 96L 15" subs.
My "research" has me homing in on XT1464 horn (tweeter to be decided) but the question here is about the mid-bass driver. I started with the obvious Faital Pro 15PR400 but in terms of a domestic speaker, but I keep coming back to the Eighteen Sound 15W750. Decent Xmax, low Mms, low Le, 3" VC, curvilinear cone all adds up to a driver that (given that it'll have the DSP of a Hypex FA123 behind it) the ideal mid-bass driver for the job of reaching the proposed 800Hz crossover in a 175L ported box with low 30 something Hertz tune.
Happy to hear about something better as long as it is not assumed I'm a bottomless monetary pit!
Russ
Feedback - global or local?
Let's suppose we build a 50 Watt power amplifier that has 20 mV input sensitivity in open loop, with an open loop gain of 60 dB. Then we apply the proper amount of GNF to set the input sensitivity to 1V and reduce distortion.
The same input sensitivity can be achived by applying local negative feedback in each gain stages. The distortion of each stage will be lower, too. The end result will be the same input sensitivity as in the GNF case, and probably the distortion will be in the same magnitude of order.
I think the harmonic spectrum of the distortion will be different.
In the GNF case each stage gets badly distorted signal from the previous stage, and only using a huge amount of GNF can we manage to have a clean signal at the output. In contrast, in the local feedback case each stage will send a low-distortion signal to the next stage.
What is your opinion? Do we destroy the noise performance with local feedback? Do we have better gain distribution between stages? Which feedback will give better sound? (I think local feedback wins, but I don't have any hard evidence).
Klipsch KG1.2 woofer replacement
I have some KG1.2 2-way speakers (8 ohm) with dead woofers. Unfortunately, finding good K-1007-K drivers is not possible, unless I want to buy some KG1.2's with cosmetic issues and just use the woofers ... but that doesn't make $$ sense.
Rather than relegate these to the dump, I'm thinking about just replacing the woofers with cheapies from Parts Express and use these in my garage workshop where sound quality isn't a big deal.
I'm hoping someone here can chime in on things to consider, like the crossover point, which is 2200Hz. The two electrolytic caps are KSC 20uF/25uF, 100 VDC, 10%. I can get film replacements fairly cheap at PE.
Part of the problem may be the plastic front baffle. The tweeter opening is part of the plastic baffle. So if I were to make mdf front baffles, I'd have to deal with that ... or maybe just get "matching" tweeters for the woofers from PE. But then I get into crossover design, which I have no clue, and honestly, it's not something I'm planning on doing more of.
The oem drivers do not have an ohm rating on them and since they are dead, I can't get a reading. The baffle opening for the woofer is 5.75". Here is the woofer I'm looking at: GRS 6PR-8 6-1/2" Poly Cone Rubber Surround Woofer
Under Investigation New posts on home page not showing
On the home page, when new replies occur the page is not getting updated. Previously the new reply would appear at the top and shift the list down, but this does not seem to be happening now without manual refresh.
Related to this, when I leave the page for a few minutes and replies have happened in the background, clicking the 'load more' button results in a duplication of threads at the join between where the first list was and where the new list is appended:
Windows 10 on Chrome. Logged in and logged out. Incognito and usual.
JL Audio HD1200/1 parts identification needed urgently
I received a JL Audio HD1200/1 that had failed and a previous repair attempt was made. The prior repair attempt involved replacing one of the IR2010s output ICs and four of the output transistors which are driven by the same replaced IC. IRF540 was used as a replacement, but FDP2532 are the originals, which are what the other four outputs are. I replaced the IR201s again, replaced the IRF540s and remaining FDP2532s with 8 new FDP2532s, the four 0.1uf capacitors by the speaker terminals, and some of the smd capacitors connected to the IR2010s.
When powered up, the capacitors located in front of, and connected to the speaker terminals burn up in dramatic fashion. I really don't know the value of the smd capacitors, and also have no idea what L4 is. I need to order these items immediately as I am finalizing an order that should ship by tonight or tomorrow.
These are the locations of the items I need identified so I can order replacements:
C93- one side to + speaker terminal, other side to GND(same as C94)
C92- each side is connected to the + and - speaker terminals
C99- each side is connected to the + and - speaker terminals
C88- one side to pin6, other side to pin7 of IR2010s
C89- one side to pin2, other side to pin3 of IR2010s
C166- one side to pin2, other side to pin3 of IR2010s
C90-one side to pin11 of IR2010s, other side to GND
L4- one side to D16 diode, other side to C15 capacitor(220uf10v) which has its other side connected to GND
Tweak/mod NAD C350
Has anybody moded this amp. I have changed the powercord and replaced it with an IEC jack and 1.5ml silver cable....wow what a sound! I also had the amp modded in switzerland by Mr Graff who opened the mid range up so much it was like a new amp. I would like to do more to it coz the basics of the amp are phenominal, its punch mainly.
What I'm looking to do is get a more realistic sound to instruments, and tighten up the bass. Everthing else is amazing! Can anyone suggest any mods?
Ps I hope this is the right section!!
Need Help with Amp Preamp Gain Matching/Staging
I've read a few things about amp preamp gain staging, but I still can't wrap my head around what I should be shooting for. The amp in question is a Parasound A21 and the pre a CODA CLX (specs for both attached), using the balanced connections. Right now, I have the gain controls on the A21 all the way clockwise and either leave the CLX at unity gain or add about 6dB when using one of my turntables (the cart is on the lowish output side and the phono amp doesn't have any provision for adjusting gain). Other than with this one table, this ends up with me having the CLX volume set at between 75 (for CD source) and 85 (for tape or phono).
On/Off switch keeps on breaking
Hello,
I bought a couple of these on/off switches:
I use one in an amplifier build as on/off switch. I wire the hot wire from the 220V mains to this switch. After a couple of on/off cycles, the switch breaks and remains 'on' regardless of its position (there is current flowing even when the switch is on 'off' position). Now this might be a single defective switch, but I have replaced it 3 times already and every time the same problem occurs - after a couple of cycles, the switch remains always 'on'.
Am I using this switch correctly?
Is is due to a bad batch of switches?
Goodbye Alps Pot! TU8600
Today I took out the Alps volume pot in my TU8600. I soldered the volume in and out pins together--one time on the right channel and one time on the left channel. I left the grounds open.
Disclaimer-- I'm human and guilty of subjectivity and confirmation bias.
That said, the 8600 sounds definitely better without the volume pot. Now, maybe a better resistor based and numerous stepped attenuator wouldn't degrade sound. But, I am confident the amp sounds better without that pot, in my setup and my room.
Need a simple, cheap bass/treble tone control.
Hi. So i am building a small portable speaker out of some drivers i have laying around.
I would like to add bass and treble boost and cut like old radios used to have. So i need some simple, cheap circuit either passive or able to work from single rail 5v supply, Input would be fed from Bluetooth module and output would go into small amplifier boards.
Also it has to be able to be built on perfboard easily or it could be something pre made but cheap.
Thanks in advance for any suggestions.
Need a way to convert a Shure Lav Microhone (TA4F) to XLR
Good afternoon.
I have a Countryman MEMWF05BSL with the TA4F connector. I no longer have the Shure transmitter/receiver, and would love to use it hardwired.
I have a ZOOM F4 recorder with XLR inputs that can be powered with either phantom or plugin power.
Is there a converter or a diagram available so that I can do my own connector?
Thanks guys,
David
Zed Audio Minotaur III amps (2)
I have two of these in for repair from a friend.
First amp powers and will play but at very high unloaded drive signal when the amp indicates about 3/4 amplification the upper waveform on the outputs squares out. Briefly the amp will draw excessive amperage out of my small PS set limit (5A) and the amp will reset. During this problem, some of the small LEDs on the ZED logo will flicker off.
IRS20957 driving IRFP4227
Type 3 amp
How can I check the output circuits in this, or should I look for a replacement 20957?
Second amp had an open 1-ohm resistor very near the IRS20957, and also two small caps - one shorted down to 25 ohms. I replaced the caps and installed a new 1-ohm resistor. Most other components in this area seem OK from what I can measure on the PCB. Ohming out the 20957 devices between both amps made me think this 20957 is OK, but maybe not. Amp powers on with 4.5vDC on speaker terminals, and the ZED logo is only 15% lit up once the amp fully boots (But it DOES flash fully during soft start) - I think its indicating some kind of problem but have no idea what the ZED logo LEDs are trying to say. On this amp I'm thinking the 20957 is not operating correctly.
Quantization distortion in miniDSP with amp and DSP plate amps for super-tweeter channel
Hi all!
Without very very precise and distortion free measurement equipment difficult to find out. Maybe someone here have some kind of spectrum analyzer to check this out. I have this concern with my DSP active crossover as of the miniDSP 2 X 4 HD with listening tests with a high SPL super tweeter. Depending of the crossover frequency the time domain and frequency domain signal portion of the super tweeter channel get very low in amplitude. With 7 to 9 kHz crossover with lower listening level i sense putting my ear very close to the horn super tweeter with about 100db / meter sensitivity only a kind of contact noise and nothing else that reminds me of that what you can hear when you have massive quantization distortion. Have anybody figured it out with serious measurement equipment? Just apply a 443 Hz standard pitch square wave signal with smaller signal level in steps - let us say with 40, 30, 20,10,0 dB attenuation of the maximum input level and measure the small signal distortion level on the analog output of the DSP crossover with a crossover point in the steps let's say 6 kHz , 7 kHz, 8 kHz, 9 kHz and 10 kHz. For the low pass output no problem, for the high pass output the signal portion in my theory is so small that the A/D - PEQ - XO - volume attenuation - D/A section of the DSP crossover introduce a relatively significant amount of distortion to the high pass filtered small signal portion of the square wave signal. There are two variants of that with level attenuation already of the input signal in front of the A/D section and DSP based volume attenuation for the output level in front of the D/A section, this will be a significant difference for higher attenuation than for low attenuation - 0 db attenuation no difference, 40 dB attenuation bigger difference. I am a non native English speaker and i hope that i get the things explained in more or less plain English. Feedback is very appreciated, many thanks in advance.
P.S.: having said that i think the discussion whether a FIR or a IIR filter reconstruct better the original shape of a square wave signal is irrelevant for normal listening levels of the music program 30 or 40 dB below the maximum output of the system unless you have the analog volume attenuation between crossover and amp - definitely NOT what you have in a plate amp like the Hypex Fusion
The truth from a Velleman K4040 tube amp owner
I was doing some internet surfing (haven;t been on this board in a while ..was on an audio sabbatical...LOL) and I saw a thread talking down the Velleman K4040 (mostly down). As a proud owner I want to share some details that may give some folks HOPE who may have one laying around and not realize they are sitting on gold.
For the price and capabilities as a kit when these came out, it was really a steal. Maybe not so much straight out of the box as designed...where they could be a 10, they designed as a 7.
I actually purchased mine used about 10 years ago, pre-built for a very good price. That price was probably because one side crackled and the other had a hum. Not TOO bad but there and that would NOT do. So i did some research and enlisted the aid of a guy who could actually read schematics and teach me some things.
The first steps was donning an indiana jones hat and searching the WEB version of the amazon for details on what the heck. I stumbled upon some very detailed "fixes" that entailed mostly replacing certain caps, resistors and such with different values, a jumper wire at one location and some other mystical magical things. That worked really well but still had that subtle hum which after agonizing time turned out to be needing an additional ground. Now we had it clean.
Did that make it a 10 yet? Nope, the key to that was canning any thought of the stock type tubes (EL34's regardless of brand) and getting 6L6GC's. Bingo. In my case, I spent $90 EACH for 8 GE NOS form 1961. OMG. Amazing...there was the 10....but wait there is more
It uses 1 12AU7 and 2 12AX7's. The input tubes were another journey but well worth it. Tried Mullard, RCA, GE, Baldwin, you name it but the winner - a NOS matched pair of sylvania Black plates, square getter.
Now it went from 10 to 11 (like Spinal tap, its was 1 better ..lol)
So someone might ask, why got to all that trouble ? You could just buy one newer, etc. yada yada. NOTHING looks like this. Nothing evokes the sweetness from my vinyl than this. So if you have one lying around, dust it off. Pretend you are restoring a 66 Fastback mustang. It may look a bit rough, but when its done...WOW.
And just so you DONT have to play indiana jones, I have a step by step guide to upgrade and the original manual...shared on one drive. I would love to hear back - HEy this worked for me !!!
https://1drv.ms/u/s!AoQ15fY-JFvSpa1VIqlue-Qh60HRlA?e=O7s5SK
And also attached below
Purifi vs. Pascal (Etc.)?
Has anyone compared the Purifi and Pascal class D modules (preferably with the Purifi stock input buffer)? I'm looking to buy one or the other from VTV. Internet searches have come up blank.
I recently picked up the ClassDAudio Mini GaN 5 out of curiosity and, in isolation, it's quite good. I want to compare it to either Pascal (which I'm told is a dark horse) or Purifi once I establish which is superior sonically. I'll also be able to compare it to a SS push pull class A amp once it arrives back to me early next week (although there is a10X power difference between the two).
Completed project: "Fenrir"
I just finished this pair of bookshelves a couple weeks ago, using the Rival Acoustics R176-P-08 carbon-paper woofers, and the Wavecor TW022WA06-4 waveguided 22mm tweeters. 18 ltrs tuned to 40Hz for an F3 just below that, and an FR measurement that sits mainly at +/-2dB, while having low HD.
I'll attach all of the documentation in photos. Thanks for looking, and please ask if you have any questions!
Later,
Wolf
PS- more photos in the second post...
Basic Crossover Question
I'm trying to crossover my Dayton RS225-8 at 1200hz. I realize I'm pushing them a little high to avoid breakup but they are what I have to use without purchasing new drivers. No measuring capability here and don't understand simulation software. I'm using MH-Audio calculators. The calculator asks for driver impedance at XO point. Factory specs show about 9 ohms impedance at 1200hz. Do I use this impedance AND add a Zobel to flatten impedance or just use this? Thanks for any suggestions. By the way they are in a 42 liter BR cabinet with a 10" wide baffle. Also wondering if baffle step is needed. Thanks again.
evaluating used power transformer for use in Matchless Spitfire clone
building a Matchless Spitfire clone, and was lucky enough to find an old transformer with very close to appropriate voltages! 6.3, 5, and a HT+ of about 265, close enough to the 285 on the schematic and a bit gentler on those super hot biased power tubes. what's really neat is it's got a dial on the side for different wall voltages, so it could be used in other countries, and it's got a 145VAC input setting... which is pretty strange, but basically constitutes a low power mode. i wonder what this came from...
i want to make sure i'm using best practices when trying to make this sucker work, so i wanted to run a few things by you guys.
first - the thing is almost 2x as big as the Hammond xfmr recommended to replace a Spitfire, so i figure i'm not pushing any power handling limits, especially with only 2x 6BQ5, 2x12AX7 and 1x GZ34. is this a safe assumption?
second, there's one mysterious green lead coming from the PT that doesn't read continuity or any kind of resistance to any other lead, and sits at about 82VAC... what the hell is this?? i was thinking electrostatic shield until i read the voltage... could it be a shield and the voltage indicates something is wrong internally? all the other windings tested as expected.
third, i want to understand proper mounting, combined with proper grounding of the outer shell. i've seen a lot of conflicting opinions on this. to avoid affecting the flux at all, i was planning on mounting it with brass bolts with nylon washers insulating it from the chassy at all points. but then i've seen others saying that it needs to be ground referenced at one point... and i'm not sure how this ties in with the 'air gap' that should exist. my attempt to combine these leaves me with this plan:
  • brass bolts with nylon washers insulating from the chassy at all but one point
  • for one of the bolts, use a conductive washer at the chassy attachment for a ground reference (also just considering a terminal and wire running to the star ground point at the neg. terminal of the filter cap)
  • make sure that the rest of the transformer shell does not make contact with the chassy (this is what i'm assuming is the 'air gap') except at that one grounding point
fourth, what do you recommend in terms of a combination of nuts and washers in order to mount this securely? my thought was internal toothed washer with the teeth facing the chassy, then nylon washer, then nut. is a nyloc nut any help here?
fifth, should the same general practices in the last two questions apply to mounting OT's and chokes? i already know about how they should be oriented in reference to each other, just wondering about grounding, insulation, mounting etc.
thanks in advance!!
Power supplies in a separate chassis
Quick question about physical layout options in a preamp + power amp setup:
If using 2 chassis, would it be beneficial to arrange the setup so that one chassis would contain all power supplies, and the other everything else (input devices and the amps)? The traditional way would be to have the preamp and power amp in their respective chassis containing their own power supplies.
My assumption and understanding is that by isolating the transformers and power supplies to their own chassis, possible hum and noise issues could be prevented. Is this the correct way to think about this?
PMC inspired speakers
Dear all,
After hours or reading and as a total beginner on speaker design, I come here to explain my project and my questions.
Few month ago I discovered the PMC twenty5 range and especially there tower speaker (23i, 24i and 26i). 2 way speakers MLTL type. Completely amazed by the design (and their price), I’m serching for a way to make an inspired version of those speakers, especially the 24i tower speakers.
https://pmc-speakers.com/products/archive/archive/twenty524
https://www.lbtechreviews.com/test/speakers/pmc-twenty5-24i
I found many informations on the web (external cabinet dimensions, cutout…) but not much about the characteristics of their speakers ( 17cm woofer g-weave cone / 19mm tweeter Sonomex dome – that’s all).
Which speakers would you recommend to use in such project ? Do you think it is reasonable to try to reuse the costless Amiga MT speakers and associated crossover (Dayton audio RS180S-8 and Perless DX25TG59-04) in such transmission line as they have very similar dimensions (but certainly not similar characteristics).
IDC Insertion Tool
I bought some header/harness combos for a project and ended up with some 24 awg, IDC connectors. I looked around for an insertion tool and bought a punch-down tool which was too big. I ended up using a small screw driver, That was messy and took a long time, but it did work. I certainly like the IDC idea - smaller, cleaner, and cheaper than Molex-type crimp inserts. But I wonder if there is some tool that would make this easier.
Triton MLTL dearly missing a VWR126X. Alternatives?
Hi. After noticing my Triton MLTL didn't sound right, I found that the basket of one of the VWR126X has broken, tearing the spider in the process (no idea how or when it happened). So I'm looking for alternatives:
  • A woofer that could replace the VWR126X in the Triton, although I doubt one exist as the Triton was designed specifically for the VWR126X;
  • A design that would take advantage of the remaining three VWR126X (I guess one will feel lonely) and the two LD25X tweeters;
  • Feeling very very lucky, someone have a VWR126X (or a couple) collecting dust.
Thanks for your suggestion.
Improving simple CCS PSRR by 30 dB
It was noted in another thread that ready-made CCS, as current regulator diodes (CRD), are better than discrete ones. I had CCS on breadboard and those diodes laying around, so decided to check. Comparison between “two diode & BJT” CCS vs. Semitech current regulator diode (two terminal JFET CCS) at 1.5 mA current was made.
To my surprise, CRD CCS is better.
Working on some design, you are guaranteed to reinvent the wheel several times at least. I found that similar proposal was mentioned before on this forum (by peufeu I think), but to find that right choice of search phrases or pure luck is needed. As a newcomer, I can only notice that vast knowledge is buried inside countless threads, waiting to be discovered again.
I won’t discuss other smart and much better CCS designs that can be found here, but simple two diode CCS as found in the article (Figure 4A):
https://audioxpress.com/assets/upload/files/Sources_101_P1.pdf
Replacing resistor R1 with simple CRD, decreases Q1 Vbe modulation by supply ripple and brings + 30 dB improvement in the PSRR of CCS. This is interesting because existing CCS can be upgraded by simple one component exchange.
Edit: some find thread title offensive. I’m always for some humor as we are not discussing life and death matters. So, I’ve made some edits and requested title change.
Reactions: YashN
12” ported cabinet or 15” sealed cabinet?
Hi I’m a new member who is very green when it comes to the audio vocabulary, so please bare with me.
I am a drummer and was considering building a 3 way speaker. I have a few spare drum shells and was considering turning one into a woofer enclosure.
I have read some specs on a 15” woofer that said a 63 litre/16.5 gallon sealed cabinet would suit , fortunately my 18” maple drum shell fits the bill perfectly so I have a few questions.
1) Would I get the same amplitude from a 15” sealed woofer as a 12” ported but with improved sound characteristics?
2) if I heavily dampened the shell and reduced its volume considerably would I need to increase the size of the shell I use? (I hear that with a ported cabinet if you dampen the cabinet you may be able to reduce its size by up to 20%) I guess I’m also wondering if a sealed woofer requires dampening at all.
3) Would a cylinder style cabinet net me any benefits rather than going with a standard square/rectangle design?
Thankyou everyone I have so many questions but I think it’s best to go one thing at a time.
20k Stepped Attenuator with loudness tap?
This isn't critical, but if I could find a decent/high quality replacement for the volume attenuator in my Kenwood 700c preamp I'd be tempted. It is a 2 gang 20k part with loudness tap.
Are there any available with a loudness tap, or could I add a loudness tap to one?
The original works but needs periodic cleaning. I can deal with that but thought I'd see if anyone here had anything to suggest. This is my main preamp. It is a truly great unit. Many units have crossed my bench but none have beat it and few come close.
Mono, the best approach
I have no exposure to mono at all. But I have someone who I built a Paradise for asking for a solution to a dedicated mono setup.
Is he best off using a Y splitter between tonearm lead and into both inputs of a dual mono phonostage?
Or, is he better off getting another single channel of a Paradise and using a y splitter on the output?
Assume cost doesn't matter, and he's using a Majiyma dedicated mono cartridge.
All opinions appreciated.
Broken speaker cover frame - Fixable?
I picked up these PSB Stratus Goldi speakers a few days ago and one of the frames is broken. Looks to be some kind of fiberboard. Can this be repaired somehow, or am I looking at having to replace them altogether? I'd also like to replace the cloth, any suggestions/caveats welcome!
An alternative to Goland Audio DVD Creator suggestions ?
Hi
Once again I am having trouble with trying to burn hirez 24/96 Audio dvds (Not DVD Audios)
This simple easy sytem seems to have gone wrong after a Microsoft update to Windows 10.
Does anyone have a simple working alternative as I had tried a good few that do not take either 24 bit or 24/96 sampling of wav.
Many thanks . As I am considering an extra old hard drive with a version of earlier win program as a desperate last resort.
What is the purpose of these caps?
I have one of the earlier versions of the ShortestWay 51+ amp (also referred to as the SW51 amp). This amp was created by a SBAF community member. It's a SET amp that uses 6Z51P/EF184 tubes.
I had a look at the PCB and was wondering if someone could tell me can what the purpose of these 2 film caps were:
The caps are WEIDY W313A102-J6:
  • Capacitance is 0.0010 uF / 1000 pF
  • Voltage rating of 1000/1250 Vdc
Thanks in advance.
Is there anyone in New England that is legitimately interested in audio R&D?
I've been on a research and development montage in the audio field for almost 10 years now and at this point I'm becoming overwhelmed with everything that I am working on.
After thousands and thousands and thousands of hours of R&D, I can confidently say that I know the path to achieve perfect sound reproduction, however I can no longer do it alone.
I will soon be starting a company showcasing the fruits of my labors but the R&D portion is overwhelming me even without the burden of running a company.
I am wondering if there are any souls in New England that are passionate about progressive audio research and development. Even if you have zero knowledge and would be willing to learn. The ability to think creatively and a results driven mindset is all I need.
I already know the answer but I figured I would ask anyway.
I'd be willing to move elsewhere if I found such a person outside of my region as well, but that would take some convincing.
Advice for newbie crazy enough to want to build a DAC inside a Keyboard
Hello diyAudio, this is my first post here. I have some experience programming in C on embedded systems (mostly on a TI ARM micro-controller). I have been learning KiCAD and about PCB design, since I want to design and manufacture my own 60% keyboard PCB. I am almost nearing completion of my CNC Milling machine to make metal cases for custom mechanical keyboards. However, I had the somewhat crazy (and possibly stupid, who knows) idea of integrating a DAC and headphone amplifier into a keyboard PCB (or daughter board if possible in the cases I plan on designing). I understand at a basic level of what a DAC does along with ADCs, along with what an Amp is supposed to do. Since this would be for a keyboard that is communicating via USB, I have read that I should use I2S in asynchronous mode between the micro-controller and the DAC. I am thinking of using an STM32F411RET micro-controller which seems to have a decent amount of grunt along with what seems to be a good enough I2S interface and it is already compatible with the popular open-source firmware for custom mechanical keyboards, QMK.
This is pretty much where my knowledge ends. I have looked at pictures of some of the DAC designs featured in this forum, and there appears to be a lot more to a proper DAC than just sending my I2S signal to a DAC IC and then feeding that signal through a few capacitors to an amp and calling it good. I am still learning about the theory when it comes to properly designing circuits. I am a computer science student, and not an electrical engineer. There is also probably a lot of domain knowledge when it comes to audio and music too for designing circuits for this purpose. The most I've seen of DIY kits for DACs is on AMB's website, but I don't understand their designs due to my ignorance. I would appreciate any advice you guys are willing to give, especially in learning the fundamentals of designing a decent DAC circuit controlled by a micro-controller which is talking to a computer over USB. I also have to figure out the headphone amplifier, but I believe this part of the forum is dedicated for DAC stuff and things similar to that. Just keep in mind that I am still trying to learn a lot of the terminology involved, such as reading about FIFO's which is more of data structure concept for queues in my head vs whatever is being used to build a DAC in hardware.
More Adventures with Class D
I added a follow up to the article I wrote about my journey with an ICE Class-D Amplifier build I recently finished.....Hope you enjoy
"Back in school days getting a “D” was a bad thing. I had friends that got very good at changing a D to a B on their report cards! But I’m here to tell you that in this case, a “D” is a VERY GOOD thing. I’ve been in the HiFi retail business for near 50 years. I’ve had the luxury of being able to audition dozens if not hundreds of higher end HiFi components at home for extended periods of time. It always boiled down to “Length of Listening”….Some amplifiers and/or speakers were simply unlistenable for longer than 30 minutes or so. They were somehow fatiguing and I would simply shut them off and do something else. Many of these items were amazing on first few minutes of listening, but then grew very tiring and just not interesting to listen to the music any longer. Some components would put me into some kind of HiFi nirvanas and I’d be listening until the wee hours of the morning. I simply didn’t want the session to end.
Well, last night was one of those LONG nights! Using the ICE amp with a Zero Zone Conrad Johnson clone tube preamp and a Node2i/Gustard X-16 DAC playing Tidal direct, into my KEF LS50 Metas, I was smitten! And I didn’t hit the sack until well after midnight.
This amplifier defies all logic. $300, Kit Built, sparse parts, the size of a small box of cigars, doesn’t even get warm…….and it holds fort with my acclaimed Nelson Pass First Watt F5v2!…….But it has better bass!
Maybe it’s my near 70 year old hearing. Maybe I’m easily sonically pleased. But I don’t think so. During COVID, I’ve bought so many amplifiers and other HiFi gear and returned it because it sounded horrible. I can’t hear anything above 15Khz, but I can hear sound stage, imaging, air around the instruments, dynamics…..and I believe these things are more important to good HiFi that frequency response. And this ICE amplifier offers these attributes up in shovels full!
The question I now have to ask…..How much better does a $XXXXX.xx Jeff Rowland Class-D amplifier sound? Diminishing returns you say?
Yup, we got ourselves a VERY interesting hobby!"
for the full article: www.rvbprecision.com
Low Cost Minimalist Speaker Design
Building on the open baffle design I created earlier, quite successful in its own way, once again I started musing about another design, this one with a large bass driver, using low cost components and easy to build.
The current design is a result of many influences: first of all the rising and not inconsiderable cost of speaker drivers compared to a complete used speaker set: as low as $10 per pair for a vintage Sony or other brand. Given these costs it simply does not make sense to build one. The other driver, if I may call it that, is the combination of an equalizer on my music player (Musicolet) and the Sony XB10 Bluetooth speaker pictured. It is only after a some time that I began to appreciate the little speaker's ability to reproduce voices and the mid-range well, and bass, and, with some equalizer adjustments, a balanced clear sound across the audible range, with all the sounds being heard. Could a small speaker really produce such bass? Well hes, due to some passive radiator arrangement within, still it did not change the size of it.
Preferring two speakers, even two left channel speakers hooked up in series to a single mono source, I set out to design another set of speakers, with some new features.
For reference, here are my Desktop Open Baffles (sadly, dismantled) and my Sony BT Speaker.
Garrard 42M drops on 1 record.
I have a Garrard 42M that I recently bought and put through the usual cleaning and re-lubing. I managed to get is all working, except for one issue.
When I use the cycle function it is able to drop a single LP without a problem. But if I put more than one LP in the stack it won't even drop the first one. I tried various other records on the bottom, and various number in the stack. But it will not function correctly.
I noticed what appears to be an anamoly but with only 1 changer to look at I'm not sure. When it cycle the small inner lever that pushes the record on the bottom over so it can drop down, before it goes to the right, it goes to the left away from the direction it is supposed to go.
I am thinking perhaps I have the roller that moves that in the wrong place on the cycle cam. Anybody have a Garrard 42M or similar they can look at? Confirm that it does not go left and then right, but only to the right and back to drop a record.
Drop in TDA1541 upgrade board?
I've just spotted a small PCB for sale that allows you to double / parallel a TDA1541 in a CD player or DAC.
It has the positions around each DIP socket to install decoupling capacitors.
I've a Marantz CD-65. It's one of the models where the factory decouplers are underneath the PCB rather then next to the DAC.
Woulda a PCB drop in, between the TDA1541 and the main PCB (with DIP socket added) be a suitable way to move these decoupling capacitors to the top.
I've read you don't actually need to remove the factory ones when upgrading them, I'm pretty sure I read of folk simply soldering on the the same points the factory ones do.
But would the idea of a effective daughter board to move these caps to the top, and ease upgrade, actually work? Or am I missing something in my naivety?
Zeus h5000
Hello everyone ! I have this amp to repair and I have blown transistors! Among the damaged components I have this component with the code EN3A11! does anyone know what kind of transistor it is? Or do you by any chance have the schematic of the amplifier?
Hifisonix Soft Start + DC Blocker
I've just completed building and testing a soft start DC blocker ('SSDCB') board.
You can read about it here:- https://hifisonix.com/projects/soft-start-dc-blocker-for-mains/
Here's a presentation you can download https://hifisonix.com/wp-content/uploads/2022/01/DC-Blocker-Soft-Start.pdf
Here's a video about DC on the mains by Paul Gowan of PS Audio DC on the Mains
The circuit uses a 32mm Ametherm thermistor to provide 10A current limiting for 3~5 seconds after mains power is applied with a fast (<0.5sec) reset when power is removed. A separate function provides DC blocking to remove the annoying audible transformer 'growling' that arises from DC on the mains.
NFB VTL MB250 , help me understand, how to adjust?
Hello again , I hope that this is what it is called ( negative feed back ???) NFB . I see a variable pot in the middle of the circuit board of these VTLs which I have brought back from the dead. Replaced both Power caps in both amp , replaced suspect tubes in one and replaced a 20k resistor that was bad in the other . It seems "something" can be adjusted and I take it that it is for a balance of sorts ? Between the two banks of four 6550we tubes in theses mono blocks? Please educate me.
Now since an adjustment can be made , what would I be looking for voltage wise ( will be ac or dc) mv or volts. I see close to this pot are four diodes and a capacitor would this be a bridge rectifier associated with this pot?
As always thanks for the safety protocols working with tube amps. Luckily this amp has a negative insert for the negative probe so it is a one handed process probing into the circuit.
Thanks all
Acoustic door seals
I need to reduce the amount of loudspeaker noise transferred from my listening room into our lounge.
At the moment, I have bi-fold doors which have gaps everywhere.
For aesthetic reasons, I must use glazed doors so I know the result won't be as good as is possible, but it will be better than I've got. I'm planning on using 2 No. of doors similar to below.
I've found Lorient acoustic seals. In particular AAS7503 perimeter seal and AAS7506 meeting stile seal look as though they should be fairly simple to fit.
All comments / advice welcome.
Thanks in advance,
Barry
Where to repair a Rawson Aleph 5 clone
I just bought a couple of mono Rawson Aleph 5 clones on Audiogon. They just got shipped ground.. very well packed, boxes looked fine.
One of the amps sounds great, the other one does not warm up. I can hear some sound but it never really gets going. The LED comes on and I hear some sound through but the amp does not warm up. I looked inside and I can't see anything burnt, the amp looks very well made, it has the Nelson Pass boards.
The circuits look simple enough, but all I got is a voltmeter. is there someplace I could take a simple voltage measurement?
Before I send them back to the seller (heavy) I wonder if anyone knows where in Southern California I could get a technician to take a look at it.
Cloning the JBL 4429?
The first time I heard a pair of Avantgarde Uno, I couldn't believe it and after that I've always had a thing for horn but the Uno is beyond what I could afford. Also being very efficient at probably about 95db, they were driven by some 15W 300B single-ended triode and hence the added realism. After that, I could never forget the soundstage. So the next best thing is to clone something similar.
The JBL is a reasonable alternative to clone. The JBL is somewhat similar to the Uno is that both uses a horn loaded super tweeter, horn load compression driver for mid, and a conventional bass driver. So if you had to clone the JBL, what drivers would you use?
The JBL is a three way: 1 horn load super tweeter, 1 compression driver midrange, and 1 12in. bass. At least in theory, here are the drivers I would use. I looked up at PartExpress and come up with a set of alternate drives to the JBL and here what I found. I group them into two category: expensive and affordable. Target efficiency will be around 95dB.
Expensive:
1. Faital FD371 super tweeter ($172 each)
2. Faital HF146 compression mid driver ($256 each)
3. Faital LTH142 1.4'' Waveguide ($118 each)
4. FaitalPRO 12PR300 12" ($224 each)
Cross over from the compression to the bass will probably be about 1.3 Khz.
TOTAL: $1540 for drivers/probably $200 for xover components.
Affordable:
1. Fostex 025H27 Super Tweeter ($32 each)
2. PRV D3240TI 2in. ($109 each)
3. PRV WG14-50 Waveguide ($23 each)
4. Dayton Audio PA310 12'' ($65 each)
TOTAL: $458 for drivers.
The difference between the expensive and affordable is that the expensive version drivers have smoother frequency response so you can use lower order filters
Those would be my driver selection. I would like to see which drivers you would use if you had to clone the JBL 4429.
I am surprised to see that the JBL 4429 is only rated at 91dB. The clone version will have efficiency of about 95dB or more.
ALPINE MRP-M650 Issues
Looking for some help. I have a sick MRP-M650. The output FETs were removed to check for shorts and they tested OK. When I measured voltages on PS FETs and driver IC (494), most everything was normal, however I found a shorted MURs120 that I replaced.
I put the last 3 output FETs back into the amp, powered on and tried to measure waveforms only to find the amp seems to go into protect. the only thing I can think of is the driver IC on the opposite channel is shot. When the last 3 FETs were removed, IC307 measured ok but had the shorted diode (MURS120). IC308 showed -21v on pins 6,7 & 8. My questions is, how could putting the FET's back into the board all of a sudden cause all of the other components I measured ok before, to most not showing voltage? Did I answer my own question?
If it helps, when the last 3 output FETs were removed, I got a nice clean square wave on all 4 PS FET's, the dual diodes measured ok, the 494 measured ok but when I put those last 3 FETs in everything went haywire. Oh and before you ask, I put all new IRF540N's sourced from MOUSER.com
Advice on 24V power supply
Hello fellow enthusiasts,
In the past few months I've built an ACA amp and ACP+ pre-amplifier. Great fun, great sound! (Hooked up with Klipsch R-51M speakers.)
As a future project I'm thinking about building a solid, clean and stable power supply, able to drive both devices at once. I guess it should be able to deliver 150VA (or more?) with 24V output or similar given 230V AC input.
Please share your ideas what would fit. A kit is convenient, if applicable.
Kees
A different kind of triode amplifier...
I've been wanting to build this amp that John Stewart shared with me a while back, and finally found (what I hope) are going to be some good output transformers. Antek has these MP-15W50 15W Output Transformer that are close to fitting the bill, and won't break the bank. If the amp serves me well, of course, I can buy more expensive iron later if I feel I need it.
The design calls for a 4300K 43% UL tapped transformer to provide bootstrapping to the drivers to help overcome the trouble of massive drive signal needed by very low mu 6080 or 6AS7. There is also a way to do this without a UL transformer by adding a couple of extra resistors, which I have procured, but I'd like to do this with the UL transformer to save on the AC losses of using the resistors to provide bootstrapping. I'll post the schematic in a bit, it's something that jhstewart9 published in glass audio many years ago, and has graciously shared here too.
Because I'm a little bit cheap, and a whole lot curious, I also want to get a set of 50VA power toroids from antek to try as output transformers, as some have had success with power toroids as output transformers. Using two transformers, and putting all of the primaries in series will give 480V CT, with two 50% taps for UL/bootstrapping. The plan at the moment is to use transformers with two primaries and two secondaries to get somewhere around 4-6K into 4 ohms. I'm going with 4 ohms on the outputs, since the current speakers I'm using the most are nominal 4 ohms, and It's easier to add some windings to a toroid to get an 8 ohm tap, than it is to tear apart the insulation and remove windings. User kodabmx has reported having good luck using one primary from each transformer in series on each half of the center tap, in order to cross couple them, and reduce interwinding capacitance problems. I'm doing the maths as follows. Please correct me if I'm wrong!
Using the 115V/6V transformer AS-0506, they have a data sheet that shows the unloaded secondary voltage as 6.3V with 120V in. From there I calculate a turns ratio of about 38:1 (using 480V into 12V.6V), or impedance of 5800:4. This gives better distortion figures for most of the range, and may still net me close to the 12.5W out of clean power that John says he got from using a single 6080 with the hammond Iron. Using the 7V transformer I get about 4400:4
a pair of AN-0206 is even less expensive at $12, and two of those together weigh in about the same as the purpose wound 15W output transformer antek makes. The downside is the primaries are only good for about 100mA DC, so I may be on the verge of pushing them a little too hard. Only one way to find out!
The "upgrade" circuit uses two 6080 in parallel, which seems wise, IMHO not just for the extra headroom, but also since it will likely be easier to find two semi-matched tubes, when the two halves are paralleled. I've not tried checking any of these tubes in my pile to see if they are matched close enough or not, but others report that it is not too promising. Using AS-0509, I get 480 into 18.8 for the unloaded voltage and a turns ratio of 25.53:1, and impedance ratio of about 2610:4, which ought to be close enough for triodes 🙂 AS-1209 is the 100VA version, if this one proves to be inadequate.
Target operating point of the design is 250V with 50ma of plate current, or 250v with 100mA for the version with parallel tubes. I have three regulated supplies to run this from for construction and experimentation, and will worry about building the power supply once I've got working circuits. I've got some ideas about lowering the plate voltage a touch to help reduce distortion at the expense of output power. 210V at 60mA with 10W looks a little nicer, but I'll have to build to know! The load line simulator/calculator can only tell me so much without real world trials. The only issue is whether the output transformers will get unhappy with the extra bias current.
Dynaco SCA-35 PEC Modules
Does anyone have a Dynaco SCA-35 amplifier and can provide the dimensions of the two packaged electronic circuit (PEC) modules? These carry part numbers 555002 (for the tone controls) and 555003 (for the input loading). I want to make circuit boards to replace these; the assembly manual provides the schematics but I can't tell much about their physical size from the pictorial diagrams.
Thanks to anyone who can help.
kicker cxa 300.1 bad ps and outputs
hi everyone. working on a kicker cxa300.1, mp18021 replaced, irf3205 on ps and irf640 in the outputs, only for test, the amps works fine. now which is a good substitute for aot460 and aot412? i cant find on mouser and i dont use ebay cheap mosfet for outputs.
this is a 300rms little amp, im thinking the irf3205 works ok, more id and only 5v less on vds. but i dont 100% sure.
the aot412 are 60a and 100v, i have irfb4110 used on another bigger cxa at the ps, can i use it like output? these are 130a 100v more than twice the original part.
thankss
Lighter Note Hum/Balance Problems
Hi everyone,
I ordered a Lighter Note kit from Uriah a while ago and a few weeks later received, for reasons unknown to me, a readily assembled LN. It worked fine and I went on to use it with my ESP P101. However, I noticed after a while that in a certain range of the volume pot, there was a slight hum. I found out that it could be removed by connecting the 0V center tap of the 12-0-12V transformer to the ground plane of my PSU which is to connected to mains ground. I attached the cable permanently (I'd tried it by just holding it to the contact, and after that, the hum was gone but the sound was much, much quieter and the balance pot had stopped working. I removed the cable connecting the center tap to my star ground point again, but the sound remained quiet and instead, a new hum appeared. Its volume increases with increased volume pot settings (the one I had before would only appear from around 1/3 to 3/4 of the max volume setting) and it's much louder, except on the most quiet volume settings. The balance pot still doesn't do anything. I'm very confused as to what could be causing this, since everything is now set up the same way as before I started messing around with it, but the new problems remain. If anyone has any clues (or a schematic of the LN to give me at least some orientation of what might be wrong) what might be the problem, I'd be very grateful if they could help me out. I've also emailed Uriah, but have so far not received a response from him.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,910
Members
7,893,381
Messages
Filter
Forum Statistics
Threads
406,474
Messages
7,893,381
Members
507,910
Latest member
LiamY
