For Sale Active speakers
Hello,
I’m selling a pair of active speakers originally built by Pat McGinty of Meadowlark Audio. I used these with a Wiim Pro streamer via various music services (Pandora, Qobuz and the like). They originally had Minidsp Power Ice plate amps but I upgraded the amps to Hypex FA122’s. These are a really convenient way to utilize any music service. If you’re interested in learning about active speakers these are a affordable solution.
There are some minor scratches but the drivers are excellent. Please see the pictures and if you have any questions just pm me.
Price $1600 plus shipping
Included with the speakers is a pair of custom covers, a coax to aes adapter and a 25’ aes cable and a power cord for each speaker.
I’m located in Northern California at 95453
Reactions: taloyd
Do sealed back drivers need an enclosure?
Is there any benefit from enclosing the rear of a sealed back mid-range driver? I am thinking mainly of horn loaded compression drivers and sealed mid-range domes. I can think of reasons for no rear enclosure, just a supporting pod/frame provided the driver is flush mounted together with effective edge diffraction control. Is there any evidence that there is significant acoustic rear output from the sealed back driver that can disrupt the forwards radiation?
Filtering out distortion from a function generator
I haven't had good luck building physical sine wave generators. I want to make a fixed 60Hz sine wave generator.
Giving up on doing it myself, ebay has lots of boards with those out-of-production function generator ic's on them. But to do the distortion trim on them I would need instruments that I'd rather not buy.
It occurs to me, though, that if I follow the sine output of the chip with a regular opamp 12db/octave lowpass filter set at 60Hz, it would clean up a lot of the wave's distortion. Harmonic distortion is harmonics, right? If you filter out the harmonics you filter out the distortion, right?
I expect a lot of attitude from the ideaphobes here. It always happens. Knock yourselves out. If anyone has anything helpful or constructive or experience to share, that would be pretty keen.
Need Help Understanding Frequency Demodulation Circuits
Hi everyone,
I’m currently studying frequency demodulation circuits and have some questions. I understand that these circuits are used to extract information from frequency-modulated (FM) signals, but I’m struggling to grasp how they work in detail.
Specifically, I’m curious about how common designs like phase-locked loops (PLL) or Foster-Seeley discriminators achieve demodulation. How do they convert frequency variations into voltage changes, and what factors affect their accuracy?
If anyone could share explanations, examples, or helpful resources,
I’d greatly appreciate it!
Crown Studio/Macro Reference Amplifier Feedback points
Does anyone have any opinion on why there are two feedback take up points in "Grounded Bridge" Crown Studio/Macro Reference Amplifier. There seems to be two loops one before the output coil and one after it. They seem to be called high and low feedback lines on the schematic. .
Is there any benefit to this arrangement?
Thanks.
  • Studio-Reference-Schematics.pdf
Interesting/weird SMPS startup sound
Hello together, I build a F6 amp and because of my unpredictable mains I tried a SMPS. I ordered one from Connex but the negative rail was 1V beneath the positive. Send it back.
Now I have two MW LRS 150-24 connected together to have the bipolar setup.
Without a load everything is silent. With the F6 as a load the SMPSs make a sound like maybe a starting jet turbine for the first 30 seconds and then they are silent and work as expected I think. I let the amp run for two hours without problems.
Now is this sound some failure and is it possible to eliminate it?
  • signal-2025-03-14-10-05-21-830.mp4
    9.8 MB
Servicing a Rotel RA-840BX4
Hello, I have an old 840bx4. It suffers from two issues. The amp clips (makes loud popping sound) at half volume mostly when playing low bass. I suppose that can attributed to the big old power capacitors (in the schematic c910 c909 10000uf 50v and 923 4700uf 50v ), which have been replaced at some point by some technician with lower valued 8200uf rubycon caps?
Moreover the amp after playing looses one of the two channels, more specifically it sounds really quiet heavily distorted and you can only make out some bass notes. But By setting the tone control to MONO both outputs sound fine, so this problems only happens on stereo and only on some inputs ( cd sounds fine while aux and tuner not, swapping the sources around make no difference so its an amp problem), one way to remedy this is by applying contact cleaner in the selector switches, then the problem goes away for a bit but then returns ( thought I might be misinterpreting the symptoms, so i wouldn't consider the above 100% true). Any advise on how i should approach this ?
I have attached the service manual
Sanity check differential amplifier for DAC
I'm in the process of upping my game by going to try and use two TDA1541s in differential mode to explore potential sonic benefits compared to a single TDA chip. I'm currently using a simple I/V resistor followed by a 6C7/6SN7GT based gain stage+cathode follower inspired by JE Labs, which doesn't sound to bad at all!
Given I have a few 6SN7GTs lying around, I wanted to see if I could use these in balanced using a differential amplifier, and after my initial attempt failed, I decided to do some more reading/simulations, with the following schematic as a result:
It seems to behave as expected, but I'm keen to hear peoples thoughts on the values of the resistors/operating points, in the current simulation the Ra is set at 47k. to note, I also have a B+ of +/- 350V available, if that results in sonic benefits I'm open to use that as well.
Also I guess there is no way of getting rid of the input capacitors, other than a transformer or different topology (the non balanced solution doesn't need these capacitors which makes it attractive, but I'm open to other schematics.
Any feedback / criticism more than welcome!
Thanks in advance - Matthew
For Sale ATC SCM-100 PSL (Full speakers or just components sale)
Hello
This might be a crazy sale, but here it goes.
One close friend have a pair of ATC-SCM100. he bought them straight to the dealer in 2002. Since he has moved, hewants to change the speakers (as he did with his house, his wife and his whole life 😛)
So, here we have 3 options:
1st option: Selling the ATC SCM-100 PSL. They are, at least, 95/100 condition. He is asking 6000€ + shipping at cost. He has original packaging: 2 boxes 108cm x 74cm x 63cm and 65kg each and one more box for the stands: 48x45x28cm and 10 kg.
Original documentation and serials included.
2nd option: Selling everything unless cabinet and terminals plate: This sale includes 2x SEAS T25CF001 tweeters, 2x ATC SM75-150S midranges, 2x ATC SB75-314SL woofers, 2 FRONT BAFFLES and 2 original crossovers + crossovers schematics. You only have to build the cabinets with the measurements I will provide.
Price for this option is 4500€ + shipping.
3rd Option: Do you want to build a pair of SCM-200?????
I can provide the 2nd option adding another pair of ATC SB75-314SC woofers
This pair of is ATC SB75-314SC, Not SL, but they measure and behave exactly the same. Some better an more linear roll off in the SL but it is just a resonance peak more than 12dB below crossover point. I can provide measurements and pictures. They have new surrounds and they are in very good condition.
Price for this option would be 5000€ (4700€ if you doesn’t want to get the SCM100 crossovers). It will be included the same things than 2nd option (with or without crossovers) +
a pair of ATC SB75-314SC
Prices does not include shipping (at cost) not PP fees in any option
More detailed pictures will be sent to interested people if needed.
https://ibb.co/JRvn07tW][/url]
https://ibb.co/nsMD447x][/url]
https://ibb.co/v6RZ8kfH][/url]
https://ibb.co/7d0xVfg0][/url]
https://ibb.co/8nBSsL4x][/url]
ATC SM75-150S Super (Serials hidden for safety reasons):
https://ibb.co/0jfR3VRd][/url]
https://ibb.co/zVnT0P9v][/url]
https://ibb.co/CpVJH0rS][/url]
https://ibb.co/FLhRKDqr][/url]
https://ibb.co/k22Y1z4k][/url]
https://ibb.co/VWS2CNMw][/url]
https://ibb.co/yF5LkB6H][/url]
Original crossover:
https://ibb.co/twxMFt8r][/url]
My pair of additional ATC SB75-314SC (serials hidden for safety reasons):
https://ibb.co/PzFWh6Lb][/url]
https://ibb.co/4RGcLY5p][/url]
https://ibb.co/xKsYtZK2][/url]
https://ibb.co/pBSDrLns][/url]
https://ibb.co/5XDZvywZ][/url]
https://ibb.co/DDWPFfrr][/url]
https://ibb.co/gZQCKx0k][/url]
https://ibb.co/6cc6j4xC][/url]
https://ibb.co/M5S1bHhz][/url]
https://ibb.co/k234P7Mt][/url]
https://ibb.co/zhYQjyKf][/url]
https://ibb.co/TV1ZCPf][/url]
https://ibb.co/Y4RdJ1LW][/url]
Identifying KCS Cinema Speaker Drivers
Hi Everyone,
I luckily managed to pick up a number of old KCS speakers from a cinema being upgraded. All seem to be in great working condition, but I'm now trying to find some information about the drivers beyond the very basic datasheets that KCS themselves supply. I figure these are likely OEM drivers that KCS orders for themselves, but I'm hoping that someone has measured them previously or knows what they are copies of (if they are copies of another manufacturers).
These speakers also 10-15yrs old, so that doesn't help.
I have a number of:
S-801 Compression driver
S-1535 15” woofer
S-1846 18” subwoofer driver
G-10K 10" woofers
TR-02 1" compression horns
The whole speaker units themselves have the following model numbers:
6x C-115 PL F (horn & 15" main speakers)
14x SR-10-A (1" comp driver + 10" woofer surrounds)
4x C-118-A Subwoofers (18" subwoofers)
I know it's a long shot that anyone would know what these are, but I figured it couldn't hurt to ask.
I've sent KCS themselves an email, but alas no reply.
I'll be getting a DATS system at some point, but I don't have one yet.
Have a good weekend!
As a bonus, here is a very rudimentary measurement of one of the C-118 PL F mains. Raw Compression driver vs Whole system with 15" + crossover network.
Reactions: GM
Eclipse 36401
Hey all Im working on an eclipse amp and having trouble finding the problem. Powers on, no sound. Verified DC voltage on output @ 42v with variations in the wave form, not sure if thats normal as Im still learning and I know the O-scope is cheap garbage. I checked the NPN and PNP both are good but needed to be soldered back in the board for some reason they were both lose. I don't see anything visibly burned.
Modifying the Marantz, DP870, Dolby Digital Processor to add an S/PDIF output (not as simple as I thought it would be)
Hi everyone.
This is my 2nd post on diyaudio.com and hopefully I won’t sound like an idiot for what I am about to write (also, I hope I posted this inquiry in the correct forum since I know it doesn’t quite align with most of what you guys converse about).
I have been working on a project for the last three months to modify this Dolby Digital Processor from 1995 in such a way to add an S/PDIF output to serve as a means to obtain not only the demodulated AC3-RF signal but to also work as a digital switcher so that I can also utilize the optical and coaxial inputs to pass through DTS and PCM. (The processor currently only passes 6 channel analog which is a huge limitation if I want to integrate it into today’s modern gear.)
Anyway, long story short, I thought that I could utilize an I2S to S/PIDF converter board such as the one here to get a workable S/PDIF output…….
https://www.ebay.com/itm/386604200311?_skw=i2s+to+spdif&itmmeta=01JN5067X2PMW4F7DV7DA7M5KV&hash=item5a0367f177:g:uAIAAOSwsKdgAXll&itmprp=enc:AQAKAAAA4FkggFvd1GGDu0w3yXCmi1fALmE6yxdLqJDr+FxxmIRNN3BFoTKCIqMF8fPiOm1WLJbKW5FE3N9jFb55n5C+tmsmy4n/Xvjnq6KCWSLOzjSrg2f9Yt7o9PmfdFTYaPhvym4kfbue+7rfm5svLSvdT5DNyTtsqbWlsIg/LRtWAUbjpV6OuIahxvw3G1TCs7paS1KJJyaJ51KGCgjaauZPE7qODzHXWExpuieM9DwiCrXFW7TBkSmJWvat8J9GMj+pZK7fU/keVSqVGa0KqYzatRXn8UGKxygc8u81wdQlC8kC|tkp:BFBM4P6YoKll
My plan was to integrate this board with the DP-870’s Digital Audio Interface IC which is set-up like this within the processor……
…. And I went ahead and soldered wires that would intercept the following pins on the Sanyo, LC8904Q…..
So after much testing, I soon realized that I was going about it the wrong way. My belief (I’m sure someone can confirm this with me) is that my plan didn’t work because there is no I2S data on this Sanyo chip but instead it works in the EIAJ data format. I continued to study how the Zoran chip and the three Phlips D/A Converters interfaced w/ the Sanyo chip and hoping there might be some I2S conversion along the way. However, after reading some postings here about the utilization of the Philips TDA-1305T in CD players, it appears that EIAJ is definitely all that this processor runs on.
Moving on, I have thought about other options to make this work (as an FYI, there is no dedicated S/PDIF output pin on the Sanyo chip; first thing I looked for).
I could build an EIAJ to I2S converter board to make the Sanyo chip compatible w/ my I2S to S/PDIF board and I did notice that member “CM” has a schematic for it. However, as simple as it looks, it’s a lot work that will take some time for me to build and I would prefer something more off the shelf. Also, I’m not even sure it would work .
Another possibility I thought of was tapping pin 1 (DOUT/V) of the Sanyo chip but it is defined as an “EIAJ data and validity flag output”. I’ve searched on the web for a device that could read EIAJ and provide conversion to I2S or S/PDIF but nothing of the sort appears to exist.
So now…. I ask this community.
How do you think I should approach this mod or is this mod really just a pipe dream that wouldn’t even work? Any advice would be greatly appreciated.
FS: Tubizator SRPP V2 board I/V for TDA1541A
I have for sale a NEW TUBIZATOR V2 SRPP I/V board for TDA1541A DAC (or others if you change de I/V resistors values).
As you may know it is ready for use 6N2P-EV, ECC88, 6922, 7850...
Populated with all premium parts according to the BOM list.
You only need to add your favourite coupling capacitors and let the board burn around 150 hours or so!
Price: 100 euros + 5 euros for shipping inside EU.
Thank you!
PS: Tubes are not included, just for pics. I also have a Ei encapsulated transformer for it: (Primary 115-115 (230)VAC, Secondary: 150VAC + 9VAC).
Hello everyone!
My name is Lucas, and I'm an audio enthusiast passionate about high-quality sound. I’ve always appreciated deep, well-defined bass and a balanced sound for both music and movies. Currently, I'm working on a few DIY projects, including building Hi-Fi bookshelf speakers and designing a speaker system that can rival the Bowers & Wilkins 607 S2 —but at a more affordable cost.
Here in my country hi-fi speakers are very expensive. So I found an alternative. I will build my set of hi-fi speakers since i cant afford to buy them! Im Looking forward to tips, suggestions, and great discussions!
Thank you to let me in your DiyAudio club
I am 67 years old, living in Montreal, Quebec, Canada and i just a few week ago decide to listing to my old vinyl record with my QUAD 33 an QUAD 303. My QUAD has not been use for the past 20 years. They were bought in 1977 with a hard working summer job. They still work very well, except of the control balance that only give sound on the right channel.
i have to find a new control balance mechanism and may be find some post that would help me find the part and repair
thank you in advance for your help
Jean Derome
GainWire NGNFB SMD ultimate pre/phone amp
This is GW preamp with no global NFB used, in SMD technic and increased output power to drive even low impedance hedphones.
It is dual mono, used separate power supplay per channel.
Output amplifier uses CFP with mosfet transistors and it's powered by capacitanse multiplier incorporating overcurrent and DC offset protection.
Gain block is a current conveyor and it's powered with shunt regulator one per channel.
Damir
Good Quality 2.5mm TRS Plugs?
I'm looking for a source of decent quality 2.5mm TRS plugs to make a new headphone cable, preferably from a UK or EU supplier so postage isn't astronomical. I can get them cheaply at Ali Express but no idea of quality; I'd like gold plated and insulation that doesn't melt under soldering at least. Does anyone know of such a thing?
P.S I want to change the cables for practicality, current set is just a bit too short and needs an adaptor at the amp end - I have no illusions that this will 'improve' the sound...
Oxytocin
I'm not going to introduce myself as a loudspeakers expert... This project was a long trial and error procedure. I have them fully functional for a while so I don't seem to get motivated to finalize some details regarding aesthetics. Starting this thread might help to overcome procrastination...
So here you are, open baffles -H frame for the bass- 4 way, 5 drivers together with a rear firing tweeter. Vintage alnico, rare but inexpensive. Even for the 15" Tesla woofers, I was lucky enough to find the last pair forgotten on the self of a local store. 270 euro pick up.😛 Total project budget around 700 euro complete! Sensitivity is 94dB/W/m. Dimensions H/W/D 150/55/55 cm.
It all started from the famous Lampizator P17 aka "Endorphin". Simple and impressive within its limitations. It is well described here: Greencones What Troels Gravesen missed by using his OB9 model for the bass was a huge peak at 100-120Hz because of the deep U shape design. My efforts to cure all these issues resulted to a loudspeaker that has very little to do with the original design, thus the funny nickname. From endorphin, the essence of joy to oxytocin, the essence of maturity. OK, I could find a better name...
It is unlikely anyone to have these drivers at hand to build it but this thread is mostly about inspiration and amusement. I'll describe how I built them. I didn't use any calculations or simulations. I decided crossover points roughly by the drivers' size and then measuring frequency response on and off axis together with impedance to avoid any fatal mistake. I can tell I enjoyed it very much!
Reactions: vassilis1984
Duratex or other options?
Hi everyone:
I'm building an open baffle system, and the construction is mostly done on the MTM section. Let's assume I have next to zero painting/finishing skills. I am looking for a black, durable finish. It feels like everyone immediately recommends Duratex. I like the idea of the durability, but I have a few questions.
First, the photos I see online make Duratex look a little glossy. How glossy is it in real life?
Next, is there a way to reduce the textured finish and any glossiness to an absolute minimum? Someone told me I could spray paint over it, but that seems like a risky idea.
Are there other options that are approximately as durable? What about the European Warnex product?
EF3 drive and pre-driver configuration. Which one is better and why?
Hi! I have a question about this.
There is Class A drive. There is Class AB drive, where the emitter resistor of the driver and pre-driver is connected to the output.
There are also drivers where a B-E resistor is used. What are the differences?
Which one is more stable?
Which one provides better sound quality?
uPA74V replacement (diff pair IC)
I'm working on a Tandberg TPA-3026 and am having a hard time getting the offset stable. So I need to replace the diff pair ICs I think, they are uPA74V. The thread below shows some information on them and one post suggests replacing them with discrete transistors. I've done this many times in similar cases. But there is one extra pin here. It is labelled "sub" in the datasheet. Does anyone know what it does? I tried replacing the part without connecting that pin and the amp just goes DC. The pin seems to connect to ground.
The schematic doesn't show it, it just shows the IC as 2 NPN transistors.
https://www.diyaudio.com/community/threads/upa75v-and-upa74v-data.67817/
Full schematic here https://elektrotanya.com/tandberg_tpa-3026a_audiophile_pa_1986_sch.pdf/download.html
ONKYO TA-2570 cassette deck restoration & mods
I got this one from eBay for 170 Euro incl. post about two years ago. I have done some work on it since then. Thought to report here for cassette deck lovers in case someone else has this model and looks for information.
My findings:
The capstan belt it came with was random and narrow, off-riding the pulley. Back tension belt was missing. Found a melted blob behind a flywheel. Should have been its remains. 251mm L (9.9") or 80mm Diam. capstan motor belt of 5-6mm width seems right. PRB FRW9.7 246mm worked bit better than FRW9.6 244mm. Back tension belt is 25mm Diam. square section, about 1mm wide.
After cleaning, lubing, new left pinch roller standard practices, mechanical alignment was done with M300 gauge, Sony Mirror Cassette, TEAC Torque cassette.
Measured bias freq ~110kHz
Input to output loop distortion (source) at +5dB red level (2V RMS) with original Q221 2SD655F mute transistors of 5V VEBO was 0.15%. I replaced them with 2SD1302S 12V VEBO and got 0.12%
REC/PB ref match at REC CAL level panel pots +0.6dB for RTM FOX C60 Type1. Chosen because new production with a spec sheet.
REC CAL level panel pots range +5/-3dB
Positive notches +1dB each
Negative first two notches -1dB next two -0.5dB last one ineffective
The REC/PB heads combo should be Canon M&X Permalloy
Clutch and reel motors still alright
Capstan motor gave acceptable but higher than spec W&F. Replaced with Dual Speed externally adjustable Matsushita motor but the driver circuitry didn't like it, there was a slow oscillation on the 12V motor line in sync with a high W&F sine wave like pattern. Still very good speed stability. A single speed dubious looking Mabuchi EG-530AD-2B came handy resulting to 0.035% WRMS W&F (A.N.T. speed tape). Onkyo service manual Spec is 0.04% WRMS.
Finally found an MMI-6S series Matsushita NOS motor to replace the new production possibly fake Mabuchi. Which was fine for W&F but running rather hot, also showing bit much of a speed drift cycle over time. The NOS one weighs heavier, runs cooler, fixing the pitch at its back trim is far better predictable. Stays there.
Remote control Onkyo RC-125T was missing. I found one later. A similar Onkyo deck remote was also tried but incompatible.
Test Tapes used:
ABEX, Sony, TEAC, A.N.T. Audio, Hanspeter Roth, FixYourAudio
All service manual adjustment steps successful (manual found in hi-fi engine)
Bias & level internal oscillator test signal adjusted. Tape bias trim by Auto Accubias (micro controller).
I desoldered all NJM4558 & BA15218 from audio signal positions and installed sockets.
Mod op-amps current config:
Q215 NJM5532D Line Amp*
Q217 NE5532 Out Buffer
Q301 uPC4570 HP Amp
Q151 NE5532 In Buffer
Q401 uPC4570 Rec Amp
Q403 BA15218 Rec Head drive Amp
Q201 TC4066BP CMOS switch replaced with MAXIM MAX4066A
*The high slew rate ADA4625-2 tested stable for Q215 as well
Red dots on the annotated schematic are signal path caps replaced with Nichicon FG or ELNA Silmic II and a WIMA. To refresh them. All removed Nichicon VX(M) caps proved good on the LCR though. Factory differences found in the deck vs the schematic like extra coupling cap after the input buffer and a jumper instead of coupling cap to the headphone output also noted. The DIN input is useless nowadays. Its socket's push contacts changing between DIN/RCA routes I bypassed.
Bulb behind cassette came burned out. Replaced with a white LED and limiting resistor. Running it at 20mA is not subtle but I can see the remaining tape run and heads dirt state better in the dark.
The sine swept -20dB, -10dB, 0dB responses with a used TDK-D tape are not valid below 100 Hz due to a new sound interface with AC coupling low frequency contour on its front inputs that I didn't make a correction file for it yet. Sweep levels are actual to 0dB front panel meters reference (its a 200nWB/m ANSI deck). The deck was almost flat down to 30Hz with my old card and various tapes at -20dB with pink noise both in REW & ARTA nonetheless.
The FFT distortion graph is the input & output electronics loop when source is selected on the monitor button. Measured at "0dB" i.e. Dolby level which is 1.1V RMS output for this deck.
Sound is very good. Was good originally (a well regarded deck in its time) but took a substantial lift after the restoration and mods.
TI's Tina
I just wanted to mention there may be no better way to learn analog electronics than to use a simulator like TI's Tina. One needs to know the basics first like ohm's law and to have a general knowledge of how devices work, but thereafter, the analysis tools a simulator offers will up your knowledge by decades.
I've been a circuit designer by profession for years, even well before the existence of simulation and now I don't know how I could be efficient without it.
  • Thank You
Reactions: tomchr and GM
Fishman Loudbox Artist 240 V two 120 V conversion Update
Hello everyone!
I am currently trying to convert this Fishman Loudbox Artist from 240 V to 120 V. So far I have removed the jumper on the power circuit from the 240 V section to the 120 V section.
Does anyone know if I need to change any wiring on the transformer or if I am OK to go ahead and send power to the amplifier?
Does anyone have a schematic specific to the Loudbox Artist?
Has anyone successfully converted theirs from 120 V to 240 V? Or vice versa, as I am trying to do?
On my old Fishman Loudbox 100, there was simply a switch on the back that could run voltages from different grids depending on where you were in the world. This is why I am thinking I do not need to rewire the transformer!
Crossover! The construction
I have all the necessary components to build my long-awaited box, doubted by many here (and rightly so).
I'm in the construction part now and would like to start building the crossover.
Do you, my friends, happen to have photos or manuals on how I can do this knowing that it will be a 3-way box construction?
I have no doubts about the values of components and such, but about the construction itself and the fear of building it and making some noise or some problem, I don't know...
What would be the best way to build it?
B&C - i am disappoint!
i am in the process of designing two "end game" systems in parallel - one horn based and one array based - when the designs are finalized i will compare them in terms of price and performance to see which technology / approach makes more sense
one thing i am finding out with both of them is i can't find a single driver from B&C that i can use - they all fall short
B&C reminds me of Toyota - we all want Toyota reliability but you can never get a Toyota specced how you want it - it is always missing something that is a deal breaker for example no All Wheel Drive - or they make you choose between AWD and Hybrid or between Hybrid and Turbo etc. Why do i have to choose ? With other companies like BMW you can get Turbo Hybrid AWD no problem - why can't Toyota do it ?
B&C is like that ...
some of the features that are often missing on B&C drivers that are fairly standard on drivers from better brands:
  • Vented Pole Piece in Neo Woofers
  • Under Spider Venting
  • Inside / Outside Voice Coils
  • Basket designs that don't all look like a wheel from a Golf Cart
Ok i get it - B&C is a workhorse brand. it doesn't make flashy toys like Beyma, Faital and 18 Sound ... but why Made in Italy then ? If you're a budget brand then make stuff in China like LaVoce or in Brazil like Selenium or in Indonesia like SB Acoustics or for that matter in Mexico like JBL
who buys "Made in Italy" looking for value in a boring product ?
i don't get how that company is successful ...
look at Beyma LEX woofers or NTLW woofers from 18 Sound and ask yourself why B&C doesn't have anything cool like that ? ok B&C owns 18 Sound so in a way they do, but not under their own brand.
B&C = Lame Boring drivers that just do the job and nothing more. Their "innovation" is a joke. Their Coax is just a worse version of BMS and WTF is this:
https://audioxpress.com/article/test-bench-b-c-speakers-1-dh450-8-compression-driver
they are actually proud of this product ...
here is its smaller brother in Joseph Crowe's hand:
this isn't innovation. this is just cheapness. i don't need whatever that is made in Italy. or at all.
who asked for a Mercedes Smart Car of compression drivers ?
to be made in Italy ...
How to apply Harman curve in a 3-way DSP?
I am doing a passive to active conversion, 3-way using a Hypex Fusion amp with DSP and while I am doing the box building I am also looking ahead into how I will set it up.
One thing I am not sure about is how to I apply a gentle slope to the overall response, e.g. Harman curve. For example, if I wanted to apply a 0.5dB (or another tilt) per octave roll off from 200Hz upwards to 20kHs.
Crossover points will be, say, 300Hz and 3kHz.
I need to use the overall EQ function (not per channel), right?.
But is there a way, in Hypex Filter Design, to apply a slope of a certain tilt to everything above a certain frequency?
How much does replacing surrounds affect performance?
I replaced the rotten, deteriorated surrounds foam surrounds in a subwoofer with rubber. 2 x 8" drivers in a 22 litre cabinet? I didn't expect a room-shaker but the results are disappointing.
Any ideas, tweaks?
Anthem PVA7 quite in several channels
any one ever repaired this amp? the low voltage section?
I have 6 quiet channels, that are same med reduced output , not distortion just same level output
1 channels is normal level louder than the rest,
visual inspection there is a small chip in the low voltage section of the power supply board that has the marking :
CHN
LM358N
k3Y751
some resistors around this chip, and one leg of this chip have solder joints that look a bit overheated.
Considering buying this chip and replacing. Thoughts?
DSD DAC is an architecturally better DAC than R2R
As shown in the picture below, DSD DAC has the opportunity to achieve higher resolution and faster settling time than R2R DAC, so DSD DAC is a better DAC than R2R Dac in terms of architecture.
After years of research and development, a DSD fully balanced DAC was finally developed. Under the R2R architecture, he uses the ratio of 2R/R, a weighted output decoder. Under the DSD architecture, the resistance is directly output. In other words, the R2R DAC draws a line according to a single point, which has relatively large distortion, and there is no good way to test the impedance brought by the switch, so the accuracy will be greatly affected. In contrast, DSD DAC is connected to a line according to multiple points, so the accuracy of DSD DAC is much higher than that of R2R DAC. Specifically, in a DSD DAC, a fully balanced channel has 64 resistors, which is equivalent to 64 bits or 64 points, while single-ended has 32 bits. R2R DAC is 24bits at most, but many have only 16bits. Therefore, the single-ended resolution of DSD DAC has surpassed any R2R DAC. Based on the above-mentioned differences in architecture, DSD DAC has the opportunity to surpass R2R DAC, and with unparalleled advantages in details, momentum, etc., DSD DAC is the truly best DAC architecture, not R2R DAC. Of course, the final hearing effect of DSD DAC is still limited by the quality of resistance and power supply. Therefore, under the same DSD DAC architecture, the quality of resistance and power supply is used to distinguish.
In order to pursue the ultimate performance, the flagship model of A&C’s DSD DAC, in terms of resistance selection, we choose the American RA non-inductive fever resistance. There are ordinary and pure silver resistors to choose from. The sound of pure silver resistors is more delicate, loose and soft, with Extravagance. In terms of digital processing, the decoder adopts the 4th generation JUN-level digital processor. The processor is modified to a fever-level processor customized according to the requirements of the JUN level. It has powerful computing capabilities and can compute DSD signals up to 120MHz. At present, most DSD signals do not exceed 15MHz, so there is a great possibility for later upgrades. In addition to strong computing performance, the most important thing is to perform FIFO processing on the DSD signal, and to reshape the input data to output a square wave waveform close to the theory, so that the time distortion is reduced to a minimum. A&C's DSD DAC can output a strong current, up to 30ma. Currently, there are fewer manufacturers concerned about this concept. The digital signal also has requirements for the circuit. It is like adding the previous stage to the system. The output large current can easily drive the decoding chip behind, so that the sound will be more natural and transparent, and the output signal has ultra-low jitter. Distortion is further reduced.
In the I/V part, A&C's DSD DAC uses a non-negative feedback design, which has better sound processing. Common I/Vs are designed with feedback, which will compress the sound and reduce the details, but the design is simple. The output of IV uses the American JENSEN output transformer to make the sound more musical. You should have a deep understanding of the output that has been used well.
Reactions: decramer
NAD c 326bee (The problem with the quiet current)
Please someone experienced for help.... I have a problem with the quiescent current on one channel... With the VR 103 trimmer (I checked it and it's fine).. I can get a maximum of 0.9mV... I also changed the zener diodes d122 and d123 but there is no result. Otherwise, I made a complete replacement of the capacitors and the device worked... it plays but I can't regulate the quiescent current on one channel... The voltages are present and ok... Does anyone have any ideas?
Yamaha CX-1000 SW701
Hello everyone!
I'm currently restoring Yamaha CX-1000. But i made one big mistake.
Disassembled SW701 (Rec. out switch), cleaned...and forgot default position of the movable part. Now it's working strangely. Was unable to find any photo on the internet. Does have manual, but i have trouble decipher output code table.
Maybe someone will be able to help me? Almost restored this nice preamp (all that left is to repair SW701 and replace motor in motorized volume control).
With all respect,
Alex.
Yamaha PC-2002M channel level issue
Hello! I Have an issue with my Yamaha PC-2002M amp and hope some of you guys can help!
For the past few weeks, I've been experiencing an issue with my the amp, which I use to drive my Tannoy SRM 10b speakers—my main monitoring setup. The amp is set to 1, and volume is controlled via my mixing desk.
Every now and then, channel B drops precisely by 5dB (this is also visible on the meter). To compensate, I have to set the volume on the channel to 6 to maintain a balanced sound. Sometimes, it may return to normal out of blue, requiring me to reset it back to 1, same setting like the channel A. Sometimes it gets to normal the next day when turning the amp on again. It also happened once that, when listening at higher volumes, the level returned to normal on its own.
Does anyone have an idea what might be causing this or know of a possible fix? Taking it to a technician requires making an appointment, but the issue is inconsistent—it depends on whether the amp is acting up at that moment or not.
Thanks!
Need replacement tweeter similar to Dynaudio D28AF/8 ohm
I need to replace a damaged D28AF tweeters (movers, ugh!).
I will replace both tweeters, and option to buy more of the same tweeters for a center channel and surround speakers.
These tweeters are paired with Dynaudio 17W75 in a sealed 18-liter enclosure, with an 18db low pass and a 12db high pass Madisound crossover at 2500Hz.
I really enjoy the linear frequency response, imaging, off axis sound and sound stage with this setup. In my experience, piano music is the true test of quality, and these Dynaudio tweeters are beautiful.
Any suggestions are very appreciated.
OB impulse response measurements - helped by absorbing the rear wave?
I built a pair of SLOBs a while ago (and have since changed the drivers to a pair of Lii Audio Fast 8s) - and have been playing around with Dirac on my miniDSP SHD.
I was running the Pass ACN with values suitable for the SLOBs but have since recreated the curves digitally in the SHD via biquads and am using the SHD as the crossover.
When taking measurements, would there be any benefit to cover the rears of the drivers so that only the front wave is used for correction?
My thinking being that OBs do have issues with bass, but otherwise with an appropriate baffle, not really an issue. By blocking the rear wave, would my impulse measurements and corrections then be more accurate?
I was thinking a cardboard box a bit larger than each driver with some mineral wool inside loosely covering each driver - absorbing the sound from the rear but not affecting the response in the way a sealed box would, or at least not much.
This would just be for measurement, then I'd get back my regular sweet sweet OB ambiance once done measuring and take them off.
I've never seen this discussed, so figured I'd ask before spending a chunk of time on some arts and crafts.
Thanks for any wisdom-
Pete
Outdoor Subwoofer enclosure + horn extender concept to test
Hey Everyone in the DIY world!
I had the idea to build a low roofed shed at a small outdoor wooded venue where I throw edm events. The dancefloor space is roughly 40x40 with a wooden platform at one end. I will upload a picture if I can find one that shows the space well. I have drawn a few diagrams to help the visual learners such as myself on here. Last event we threw in the fall resulted in a neighbor noticing their windows shaking about 2000' away from where I have my space (new windows may solve the issue). My set up last year was 2 Keystone Subs by Welter Systems with B&C18SW115-4 powered by XTi 6002 and 2 Yamaha DB12 PA tops. I figured my problem was the long throw capabilities of the keystone subs, and close property line. This is a rough diagram of the layout from last year.
My initial thought was to learn a lot more about sound processing and see if I could figure out a cardioid set up on the opposite side of the dance floor. The property line on the other side is much further from any structures with more trees and hills to disperse the sound. I have never been to a club or venue with rear arrays so Im assuming this is unusual and I should move the dj table leaving the platform as a viewing space. This idea is represented in this next drawing.
The area I feel most experienced in the DIY speaker building processes is in the woodworking side of things and less so in the engineering/numbers side of things. I have help from a friend with my speaker set up and DSP settings, but its not my area of comfort yet. With that in mind I was already thinking of building a low shed to put my speakers and amps in during events to keep them dry and less dusty. I was wondering if anyone cared to chime in on the idea of building a horn extension into my low shed using the roof, doors and ground. If I were to enclose my two existing subs into a low shed would that help direct the sound more than a cardioid set up with 3 subwoofers? Would the tolerances have to be super tight or would just putting them in a box make a difference? Below is a diagram of this concept.
Would putting a cardioid setup in a shed make it useless because there is a barrier blocking the sounds from emanating from the back of the shed. If I made rockwool insulated panels for the shed would it help block the sound from my neighbors in any appreciable way?
I know this is a lot of questions and I am pretty green in the technical side of things. I do have an excavator and can move dirt and build a lot within reason to make this a unique outdoor sound experience as my system grows. Please feel free to point me elsewhere or explore your imagination and help me make this happen.
Thanks everyone!! Y'all are the best
New here from Belgium ! Hoping to find and share some useful information on audio equipment mostly vintage but also streaming equipment
Hi, long shot maybe ... but I just finished repairing my TA-2600. Replaced the 2 belts. As of my usual habit .. I have 2 spare parts left over 😎... They must be from somewhere around/on the tape desk mechanism. I consulted the exploded views but can't seem to locate them. Anyone has an idea ? Btw .. The deck is working perfectly without them !
  • Locked
i hate youtube
the bastards save space by recompressing old videos with the result being that all music videos that aren't recent sound like AM radio
those morons also aren't bright enough to differentiate between videos and music ... this from a company that is investing into AI
are artists supposed to reupload music videos every year so that there are 20 versions of every video each with its own comments links etc ?
the scary thought is the average person is even stupider than the ones that work for Google - luckily i don't often have to deal with average people.
i used to do cardio by biking on a trail that goes around Google and i swear all their employees looked like they have been dropped on the head a few too many times.
and Spotify is not much better. it set my playback quality to "low" by default even though i am on 400 mbit connection and premium plan. pretty sure i have set it to "very high" several times before. i think every time it installs update or i switch devices it keeps resetting to "low"
but at least with Spotify you can change it back in the settings. with YouTube they just keep sucking life out of old music videos and there is nothing you can do to stop those rat bastards.
Reactions: asuslover
Elektor Archive on USB. Anyone have one of these that could check for an issue with the index?
I have the official Elektor Archive on a USB drive and am having issues with the main index page. A large chunk of the files (which curiously are those dated from 01/01/2000 (lol, millennium bug) report as not available. All the files are present and correct and all open normally if you drill down and find them manually on the drive.
When hovering over each title on the index I see anything with a 'US' (presumably as in USA) will not open. All the ones that open correctly have EN and not US in the file path. I tried remaining one as a test, but it doesn't work.
All titles open OK if opened from the root of the folder.
I'm asking Elektor over this but wondered if anyone else had come across this.
In image #1 you can see the file path in the lower left of the screen when hovering over a title. It is the ones with US in that do not open.
  • Locked
disturbing trend ...
i am sure you noticed that modern music has more bass than old music - this is in part because compact disc can produce lower frequencies than analog sources like vinyl and in part because class D amps can push more power into the subs than before ...
but that is not disturbing, that's good !
what is actually disturbing is modern music has less highs ... or are you just going deaf ? well it's both !
what used to bee "boom tss boom tss" is now is now just boom boom boom boom ... no "tss"
i used to think people got tired of the fatiguing sound of "tss" and it fell out of favor ...
but then i read an article about line arrays where the author suggested having a talk with your mix engineer to reduce the amount of HF because arrays struggle to reproduce it ...
what if HF in music is going down for the same reason bass is going up - because modern tech ( arrays ) prefers it that way ...
well it's disturbing for you ( or should be ) but not for me. if i am going to build arrays it actually works in my favor !
i thought i went deaf because i couldn't hear any highs in music then i listen to an old school metal track like this:
Login to view embedded media
( except not on YouTube where it is compressed the living **** out of )
and there is highs everywhere, so actually music is losing highs faster than i am losing my hearing.
they don't make music like this ( with highs ) anymore. not even metal. now it's just bass.
GB: Round #12; Fo-Felix AC Filter
Back due to demand! Again!
Please note that it can take a few months to get everything. Supply chain issues have made it take longer. Some have wanted different parts for that reason but the popular opinion still remains on preferring the very nice quality ones originally included.
5x20mm fuse option added for Euro buyers
So over the years people have asked about the old version, made by someone else.
It's probably time for an updated one. This one is a bit different. You may notice it does not have following capacitors after the choke. I have tried both ways, and my preference is without the following X2 capacitors. Also the capacitors prior to the choke are not varied in size because overall capacitance is more important - and they won't randomly resonate with each other.
The other major change is the addition of bypass resistors for the chokes. These don't ruin the filtration, but they do a good job of quieting the chokes that can get excited by different combinations of things on the mains.
Gen1 w/comoco's
Here's how it is different in settling time from the original.
Here's a comparison between resonances.
*2oz copper PCB (1oz is standard)
*Weco 983ZD terminals, copper alloy and can accept 2 wires for daisy chain. These are also safer, particularly if you use solid core wire that otherwise likes to make cold solder joints you can't see.
*X2 rated capacitors for safety, 4x 0.47uf. They are alternated for CFC (capacitor field cancellation).
*Discharge resistor for X2 capacitors
Coilcraft Comoco choke w/fuse or Bourns 8120/8121-RC choke w/o fuse & 15/16A/20A() max sockets
*Fuse clips are beryllium copper 3AG & 5x20mm options
*120/230v operation (parts & pcb)
*Mounting holes are sized to work nicely with M3 screws and standoff kits
*Size: 2.25x4.25in
The Weco 983ZD are preferred terminals, but not always available as individual sale. For this reason I'm going to include them in the price of PCB, so that I can meet min order requirements for them and save everyone the shipping.
Price: $14ea ($10 per filter board, $2 per Weco, 2 needed per board)
Shipping: $11 US, priority USPS box
$20 CAD
$22 General international padded envelope (prices may vary due to a crazy world)
If ordering over 4x boards there may be an additional $10, depending on destination.
Need 32 filter board commitments to order.
sebbtp 12
birdbox 6
danbmellow 4
MtlJazz 6
skunark 4
jedibones 6
clsidxxl 4
jam econo 4
ElliotA 12
utownsquash 6
ItsAllInMyHead 6
rickmcinnis 6
Differential to Single-Ended and Balanced Output Op-Amp Circuit
I am looking to output both balanced and single ended from a differential mono DAC (AK4499EXEQ) output after en I/V conversion while degrading quality as little as possible. I want to use an op-amp based circuit to do this, however, information on keeping both outputs is hard to find. Having one or the other is much easier to find documentation on. If you have any book recommendations or schematics to share, please do!
Problem with HF on Amplifier Output Signal
The circuit is the front end of the Pass A-40 with a CFP output stage. Powering up with VR1 all the way up, all the voltages match per the LTSpice sketch. However, once I touch the output with the signal generator positive (or any metallic object) the bias current jumps 500mA. The output sine wave is thick and zooming in shows a 4Vp-p 4MHz clean sine wave.
Apart from being fat, the output sine wave is normal as the level and frequency is changed. This is the same with any changes to the bias.
Rearranging Q7, Q8, Q9, Q10 to form an EF output stage (with a 150R between Q9e and Q10e) does not change things. However, removing the drivers and connecting Q7b and Q8b directly to the VAS results in a clean sign wave and square wave with no ringing for any bias current. The output is normal with input voltage and frequency changes up until the negative clips at about 10Vp.
I tried base stoppers 4.7 to 10R for all the output transistors. I changed Q5 from a KSA992 to a BD140. I tried KSA1220 and KSC2690 for Q9 and Q10.
The pcb is 100mm square with 4 layers -- signal top & bottom, power on 2 and ground on 3. Output and drivers connected by wires to the pcb, Q7, Q8 on heatsinks with a fan. The grounds from the board to the power supply common goes through a 10R resistor bypassed with a 0.68u Wima. The PS common is lifted from earth, the scope probe ground is not used and the only path to earth is the signal generator negative.
I pretty sure my test setup (3CH PS and signal generator, both Instek) are not the problem because I have built the Hiraga 30W Class A and there were no issues with proper grounding, etc. Appreciate any help or insights as to what I think should be a simple design.
Modulus-86: Composite amplifier achieving <0.0004 % THD+N.
Links to Modulus-86 build videos on YouTube: Post #2499.
matt_garman went through the Modulus-86 Build Thread and compiled a list of build pictures. You can find his list here: Modulus-86 Build Thread - Post #4463. A nice and compact Modulus-86 build is shown here: Modulus-86 Build Thread - Post #5213.
Getting all the holes in the right spots on the chassis can be a challenge for many. Here's my suggested method: Modulus-86 Build Thread - Post #5215.
Update 10 OCT 2021: Rev. 3.0 released. This revision represents the first major design revision since Rev. 2.0, which was launched in 2015. You can read more about Rev. 3.0 here: Post #2480
Update 16 MAY 2019: Tweaks to the CM cap connections to the THAT1200. The Modulus-86 boards are now made in Canada.
Update 30 DEC 2018: I completely forgot to add Rev. 2.3 to this revision history. That's remarkable as Rev. 2.3 was released nine months ago. 😱 TI finally decided to kill the LME49710, thus Rev. 2.3 uses one of the opamps in the dual LME49720, which is still in current production. The unused opamp is connected as a buffer with its input grounded. Rev. 2.3 uses all current production parts. You can find the product description and measurements here: Neurochrome :: Modulus-86
Update 10 SEP 2017: Modulus-86 is now in Rev. 2.2. TI brought back the DIP version of the LME49710. In Rev. 2.2 I switched back to the DIP version of the IC as some builders found the TO-99 version harder to work with. This reduced the BOM cost by a few bucks too. In addition to this change, the DC servo was updated to reflect the lessons learned from the development of the Modulus-286 while shaving a little more off the BOM cost. The Modulus-86 Rev. 2.2 provides the same stellar performance as Rev. 2.1. To order PCBs, please visit the Modulus-86 Rev. 2.2 product page: Neurochrome :: Modulus-86 Rev. 2.2.
Update 14 APR 2016: Modulus-86 Rev. 2.1 is now available for purchase. The main updates are: Changed LME49710 footprint to TO-99 to address Texas Instruments' decision to discontinue the DIP version. Slight improvement in THD near clipping. Complete rewrite of the chapters on power supply and heat sink dimensioning in the design documentation. See the release announcement in Post #2115.
Update 24 FEB 2015: Modulus-86 Rev. 2.0 is now available offering improved performance. See Post #838.
This spring I set out to design the Mother of All LM3886 Amplifiers. An amplifier so good that it would knock your socks off. But also an amplifier that someone with decent soldering skills could build if provided a well-designed circuit board. This design effort took a while and led to an interesting investigation of the capabilities of the LM3886. It also led me to produce an LM3886 design guide: Taming the LM3886 Chip Amplifier, which I will keep adding material to as it becomes available.
The Modulus-86 is my latest amplifier design. It is a composite amplifier using an LME49710 precision opamp to control an LM3886 power amp. The performance of the resulting composite amp, both in terms of measured performance and in terms of sound quality, is dominated by the performance of the LME49710. Hence, the performance of the Modulus-86 is absolutely stellar. One of the many benefits of the composite topology is that the power supply rejection is very high. This means the Modulus-86 performs as well on a real power supply (I tested with a toroidal transformer, rectifier, and 2x22000 uF) as it does on a regulated, $1200, lab supply (I used an Agilent E3632A). The excellent supply rejection is also one of the main contributors to the stellar sound quality of this amp.
In addition to the LME49710, an OPA2277 precision opamp is used for the DC servo. The use of a DC servo avoids the use of large capacitors in the main signal path.
The input to the amplifier is provided by a THAT1200 differential receiver. This makes it possible to use the XLR connections commonly found in pro audio. The THAT1200 provides performance rivaling that of an input transformer. When using differential connections, this minimizes the induction of hum and EMI, resulting in dead quiet during quiet passages in the music. The differential input can also be configured for use with the single-ended RCA connectors commonly used on prosumer audio gear.
The key features of the Modulus-86 are:
  • 65 W (4 Ω) and 40 W output power (8 Ω) using a Power-86 with the recommended power transformer.
  • Ideally suited for multi-channel amplification.
  • Ultra-low 0.000061 % THD (1 W, 8 Ω, 1 kHz).
  • Ultra-low 0.000067 % THD (40 W, 8 Ω, 1 kHz).
  • Ultra-low 0.00038 % THD+N (40 W, 8 Ω, 1 kHz).
  • Ultra-low 0.000067 % THD (65 W, 4 Ω, 1 kHz).
  • Ultra-low 0.00041 % THD+N (65 W, 4 Ω, 1 kHz).
  • Ultra-low 0.00069 % IMD (40 W, 8 Ω, SMPTE 60 Hz + 7 kHz @ 4:1).
  • 0.065 Hz ~ 85 kHz bandwidth.
  • 14 V/µs slew rate (fully symmetric).
  • 84 kHz full-power bandwidth.
  • 33 µV RMS output noise (20 Hz - 20 kHz, A-weighted).
  • 42 µV RMS output noise (20 Hz - 20 kHz, unweighted).
  • Differential input with 90 dB CMRR eliminating ground loops in the signal path.
  • Phenomenal power supply rejection ensuring consistent, high performance even using unregulated power supplies.
  • Elaborate use of planes and copper pours to maximize circuit performance by minimizing supply and ground impedances.
  • Low-inductance signal ground connects to power ground at one point only for maximum performance.
  • On-board Zobel and Thiele networks for maximum stability even with capacitive loads.
  • On-board EMI/RFI input filter and ESD protection.
  • On-board low noise voltage regulators for the driver op-amp and DC servo.
  • Power and output terminal blocks accept wire sizes up to AWG 10 (5.2 mm2).
  • All leaded. Easy to solder. 90 × 70 mm board footprint.
The THD+N is constant versus frequency throughout the majority of the audio range. The THD+N does rise slightly towards the high end as the loop gain of the amplifier rolls off. At normal listening levels (<1 W), the THD+N is perfectly flat versus frequency, resulting in incredible sound quality.
The differential input makes it super easy to use multiple boards in a bridge, parallel, or bridge/parallel configuration. All that is required to turn a stereo amp into a mono, bridged amp is that two wires are swapped. No component substitutions necessary.
The Modulus-86 has a gain of +20 dB (10x) for better gain structure in the end system. Should a higher gain be desired, the amp can be configured for +26 dB (20x) by changing a resistor. The circuit support the use of the THAT1203 and THAT1206 for gains of +17 dB (7x) and +14 dB (5x), respectively, should lower gains be desired for further optimization of the gain structure.
"But, but ... how does it sound?", I hear you ask. It sounds fantastic! The first time I turned on the Modulus-86 and started the music, I went “WOW!” before even making it to my listening chair. It was immediately obvious that this amp was something special. What struck me was the level of clarity of the reproduction and the deep quiet during quiet passages in the music. Talk about a huge dynamic range! I have played a few instruments in my life – including the trumpet and a brief stint with a drum set. It is especially important to me that metallic instruments (brass wind and cymbal for example) sound metallic and natural. This is an area that challenges many amplifiers and where the Modulus-86 really shines. The midrange is open and natural. The bass is precise and tight. What can I say? I really like it… The detail reproduced from Dire Straits, “Brothers in Arms” and “On Every Street”, for example, is out of this world. I am certain the incredible sonic performance is due to the stellar supply rejection and flat THD+N vs. frequency of the Modulus-86.
For those interested in more background information on composite amplifiers, I suggest reading the article, "Composite Audio Power Amplifiers" in Electronics Now, Nov. 1992 (pp. 38-44). This DIY Audio thread contains a few pictures from the article: composite amplifiers
For the impact of layout on the performance of an LM3886, I suggest looking at this DIY Audio Thread: http://www.diyaudio.com/forums/chip-amps/252436-lm3886-pcb-vs-point-point-data.html
Finally, for a more complete picture, I'll direct you to my Taming the LM3886 page: Neurochrome.com : : Audio : Taming the LM3886 Chip Amplifier
Thanks,
~Tom
Carlsbro Scorpion resistor confirmation
I've got a Carlsbro Scorpion amp and early version which is the same as a Hornet 45 apparently and there doesn't seem to be a schematic for this.
Anyway there has been two replacement resistors installed as they both burnt out so am looking for confirmation that they are the correct value, the ones in question are R32 and R31.
Does anyone have any original that can help me out?
WTB stepped attenuator
Awhile back member Adason had a near-giveaway of dual stepped attenuators like the ones shown in the picture below (these two are from Adason). Unfortunately, these two particular attenuators don't have matched values, they differ at steps 1, 3, 6, 9 and 12. also, they step backwards meaning the highest resistance occurs at the far-clockwise position, which is fine by me. Anyway!
I would like to use two matched attenuators in a Balanced Iron Pre project. If anyone who picked up an attenuator identical to either one of these from Adason has one for sale, or wants to swap with me to create a matched pair, please let me know. Thank you!
red resistor values at those steps: 2R3, 2k, 20k, 200k, 2M
brown (Dale) resistor values at those steps: 0R5, 2k5, 25k, 250k, 2M5
remaining values written on the paper
Really sucky room - which choice for TV speakers, of the too many speakers I have?
Just a bad room. Cavities, one open end to the left, the right side wall is going to be too close. I've gotten the room calmed down reasonably well, but can't escape from the basic geometry. I can get the main speakers of the moment (Wharfedale P10) into a nice place for listening (marked with tape on the floor, L & R not oriented the same, but they sound rather transparent and clear that way), but when regular life takes over they have to move back. They also make for too wide a sound stage for the TV (I didn't expect) and don't like late-night low volume. I'm perturbed.
Rather than trying all the speakers, perhaps the experienced will have ideas. At most about 14" to the wall behind the TV.
Current options:
3" transmission line. These sounded OK before, clean, but small.
3.5" open back - suspect these won't work, they take a lot of EQ
Polk RT55 3 way (2 6" and a tweeter). They have an odd bass sensation, but perhaps I could do something. No port in back. They sounded better before with pillows behind them. They're really too big for the location.
Wharfedale P10. I'm tempted to nearly plug the rear-facing ports. Can this work? Or maybe dense pillows behind. Seems unkind.
Antique DCM Time Piece. These are small transmission lines that sound rather nice, but the drivers and old and cheap, really do well in there, but replacing the drivers might be an option. I'm not sure of everything inside, and substantial surgery would be required. They're mint, so I'm a bit reluctant.
Antique 6" Open Back with tweeters, bad drivers, small baffles, sound oddly almost OK, except the drivers are truly sucky old Radio Shack units on their last legs. I'm puzzled that they sound OK as far as back reflections.
New options:
I can make something. Considering 4" more or less MarkAudio or similar full range in something. Pensil. TABAQ. Folded Voigt. Not having heard all these designs, hard to tell which might be least sensitive to poor location.
I might just be whining. Oddly, my 3.5" open back with a sub and EQ sound the best, my desktops. There's nothing behind them for a long way. Insanely crisp and clean, transparent soundstage, feels like about 18" depth from just at the monitor and back. Kind of spooky. That's what I want in the main area of the room!
Thanks for sympathy and suggestions.
BOSS CE-4800D Parts or (Schematic)?
Guys greetings, I have a power to repair, customer says it was attempted after it first died but it seems they attempted the repair. However the parts doesn’t seems to be appropriate based on their arrangement. Can someone suggest power supply FETs and audio output FETs or a full or partial schematic? They had IRF540N in the PS and a mixture of P75N05 mixed batch in the output.
Infinity Kappa 6.2i series II crossover and woofer driver
HI!
I am helping my friend with Infinity Kappa 6.2i series II speakers. I was wondering if there is a need to replace non polar capacitors with a newer ones? Usually electrolytic capacitors get dry during age. Woofer cap is 146uF and 100V. Midrange has 47uF, 26uF and 36uF non polar caps. Speakers were built in between 1992-1996.
For me woofer sound really boomy and do not go lower frequencies. The woofer winds have been glued by last owner and the midrange has been replaced with an new another no name driver.
If someone knows how to get best of these speakers working with crossovers caps or changing woofer for better one please let me know. 🙂
Sonic Frontiers Line-1 Main PCB Kit - Signature Edition
Sonic Frontiers Line-1 Main PCB - Signature Edition
For Sale this gourgeous Sonic Frontiers Line 1 Main PCB, with supply, Tube preamp with balanced designed from input to output.
This is the heart of the original Line-1 preamp, and it is the Signature edition version with tons of upgrade, Vishay VTA-56 and Caddock resistors at key location, Holcos resistors for the rest,
Upgrade bypass MultiCap Capacitor, upgrade rectifier diodes, etc... It was the original Signature upgrade done at the factory. I got this PCB from a former Sonic Frontiers employee years ago.
I made the also the optional Headroom Headphone amplifier, with crossfeed. This PCB uses now NE5532 opamp, OPA2604 shown on picture were reused years ago in other projects.
This preamp has no output coupling capacitors, it uses servo. It would be safer to have a DC detector circuit to and mute the output.
This preamp was controlled by a processor, and needs just a few addition to make it fully functionnal.
This is how I was planning to make it work:
-Input selection done by a rear PCB with relays and rotary switch selector on front. I made the PCB, it is functionnal, all the remaining parts are included. It also includes the Mute relay
-Start up HV relay control and Mute relay control. I made a timer controller PCB, with leds driver, to start the HV after 40sec delay, and then un-mute the output. A front toggle switch is use to control the Munte-Un-Mute. The Multiple Led driver circuit shows the delays, Mute, etc. These leds can be installed on the front as well.
-The original Volume was done by two PGA2311 chips. I have the detailled schematic of this section, two options:
1) use two stereo potentiometers on the front, and control the volume this way, don't use the on-board volume chips.
2) The are plenty of Arduino controller using PGA2311 chips on the net, make your own controller and use the on-board Volume chips. I have the code, and PCB design for one if interested...
I was planning to make a controller but never got there, the simpler solution of two stereo pots can be implemented rapidly and the preamp will be fully fonctionnal
-Front Power On toggle switch to add.
-DC offset detect board to shut down output if the DC detect signal needs to short the output (MUTE) - just in case the output servo ever fails (never done)
So to resume the only parts remaining to complete this preamp are:
-Chassis
-Front Power-On and Mute Toggle switches
-Front headphone connector.
-Front dual stereo Volume pots
-Knobs.
This is a great preamp, and a great project almost completed. I have all the schematics, detailled Parts List, Silkscreen and schematics of the PCB I made.
So it is easy to complete by an experienced user. The Main PCB was tested and it is fully functionnal.
Too many projects, not enough time to do all them, sorry this one as to go as well...
I have the brand new set of 6 tubes available (EH6822) at an extra costs, tubes are new, used only for the preamp testing.
Kit includes:
-Line 1 Main PCB with supply, complete, fucntionnal, missing two volume chips, Signature Upgrade
-Rear input realys selection and Mute PCB, with front rotary switch, all parts, connectors, switchs,etc included.
-Headroom Headphone Amplifier PCB (with NE5532 op-amp, not with the opamp shown on the picture...)
-Mute and HV Delay with LED control PCB
-All documentation, schematics, BOM
Optional 6 tubes for the preamp Electro Harmonix 6922EH, brand new (31U$ each at Parts Connexion)
Asking 500U$ for the kit + Shipping + Paypal 3.5% fee (Just in parts, this PCB is worth way more than that...)
possible to buy the 6 tubes set as well for an extra 125U$ (more than 215U$ if you buy them...)
Thanks for looking
SB
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,758
Members
7,887,164
Messages
Filter
Forum Statistics
Threads
406,169
Messages
7,887,164
Members
507,758
Latest member
Cindy
