Differential to Single-Ended and Balanced Output Op-Amp Circuit
I am looking to output both balanced and single ended from a differential mono DAC (AK4499EXEQ) output after en I/V conversion while degrading quality as little as possible. I want to use an op-amp based circuit to do this, however, information on keeping both outputs is hard to find. Having one or the other is much easier to find documentation on. If you have any book recommendations or schematics to share, please do!
If you have single ended output, use it as is and add differential line driver for balanced output.
If opposite, than use differential line receiver.
Chips like ssm214x will do, there are newer ones too. These will hardly degrade quality and are one chip solutions.
If you are not familiar just pay attention that differential line driver is lowish input resistance, can't be used after filter but directly after opamp..
