IanCanada or??
I currently don't have any DAC in my system and all the streaming goes via the PS5 console. Pulling the audio signal off of the HDMI out cable via splitter and feeding it into the preamp. Most of you will agree it's very far from the ideal setup lol.
As I'm always leaning towards DIY solutions, I came accross IanCanada stuff, and ofcourse, the million dollar question pops. Is it worth it?
For the flagship DAC with all the transport and needed bits and bobs, it adds up to about $800 USD. Then the PSU, chassis, raspberry pi board and we're arround $1500.
The cool thing I see with the whole thing is the "platform flexibility", as everything is running on the raspberry pi and me being an IT guy (linux prefered), everything looks even more apealing.
The part I'm strugling to find more info about is how does it compare to other DACs in the same price range, around $1.5k?
Is it worth the money, from the audio perspective?
Or should I go with some brand name DAC, or even a Wiim Ultra which apparently everyone love so much, and just call it a day?
It would be a fun project to build something like that, but not sure if it's worth the money. I plan to use it mostly as a streamer, as it's main purpose is anyway.
Please let me know your thoughts and comments, and please suggest some alternatives if possible. As allways, much appreciated and thank you!
Cheers!
Speakers (Altec 604?) inside built-in cabinets?
Hey everyone,
I moved back into my childhood home recently and I'm also getting back into audio after being away from it for a few years. My late father made some built-in cabinets with a fireplace in the living room as seen in the attached photo. Since my old man built them I don't want to alter them too much, but the cabinets and the position of the couch, which really can't go anywhere else, make speaker placement difficult.
As you can see in the photo, there are two large cupboards on both ends of the built-ins. The space inside is about 38" wide, 35" high, and 20" deep. So I've been wondering if I could put some speakers inside those cabinets, rather than on the floor in front like I'm doing now. I have a pair of JBL L166s now that I may experiment with, but I'm wondering if something even bigger might make better use of the space available.
I have a chance to buy some Altec Lansing 604-8k speakers in 620 cabinets at a reasonable price and I'm wondering if they might work. The 620 cabinets are too tall, but they would fit if I remove some trim around the cupboard doors. I'm also a pretty good woodworker and could easily build some smaller cabinets that would slide into the space available. I could replace the doors with custom grills too.
Does this sound like a good idea, or am I crazy for even thinking about it?
Any feedback would be much appreciated.
Thanks,
Andy
A
How to connect QUAD 33 to 2×303s (Vintage)
Hello everyone, I've recently bought the quad 33 and 2 of the 303 power amplifiers. Since the 303 do not have an on/off switch do thay permanently stay on?
Thay are connected via a 4pin din into 33 which is then split into 2 4pin din for each 303. Power is a 3pin din into the 33. One 303 has a 3pin din power and the other has a kettle lead 3pin power cable. Is this correct.
Advice needed on how to connect/use as mono blocks.
Tube preamplifier diodes replacement
Hello guys
I have a tube pre witch is i think an mu stage cathode follower. It uses 1 x 12au7 and 1x 12at7 each channel. Its a complete dual mono design with 2 independent PSU in a separate box. In the psu for EACH CHANNEL we have 2 separate toroidal one for high voltages and one for the low voltages. The voltages are a b+ 217v at 120 mA , a 12v at 1A all DC regulated and 6.3v AC. The b+ is regulated by an ECL82 tube thats why we have the 6.3v ac for the heaters of ECL82 to operate.
My question is...
At the b+ we have 4 diodes IN4007 and then the ecl82 for regulation with the caps resistors an all the needed parts for the application.
At the filaments section we have 4 diodes IN4004 then a 7812 regulator and all again the needed parts as above. The filaments are in series 12v dc
The 6.3 is ac direct to the ECL82
Can i safely replace all the 8 diodes in each channel psu with the VISAY uf4007 or i am going to start a nuclear disaster 💣here?
Value of old paper capacitor by color codes?
I'd like to replace this old capacitor, but before clipping it out to measure it, could anyone help me figure out the value by the color code?
One problem is that I don't know which end of the capacitor has the 'first' color band. Does it start with green? Or does it start with blue?
Is the thicker green band the voltage indicator? If so, I guess that means 600V (DC).
After that, I get:
Grey = 8
Orange = 3
White = 9
And for tolerance,
Blue = 6%
That doesn't make sense to me. I must be reading this wrong. Can anyone help me understand how the manufacturers color coded these old capacitors? Thanks...
Fully balanced MC phono preamplifier thoughts
Dears,
This is sub-thread of my turntable post: https://www.diyaudio.com/community/...eded-with-motor-and-drive.412984/post-7687982
It seems appropriate to open new one just for the preamplifier.
Since I'm waiting for motor parts to start significant upgrade of this 22 y.o. thing, I will revisit the preamp too.
So far I was using this design with 2 x SSM2017 in first stage and 2 different second stages, description is here: https://www.diyaudio.com/community/...eded-with-motor-and-drive.412984/post-7688045
For the new version, I have 3 personal preferences that I would like to respect:
  • Fully differential, I see great benefit and improvement from dropping ground of the signal path. Even still I'm using GND for referencing output voltage, but in new design I'm considering bootstrapping that with very low noise amplifier.
  • Passive RIAA EQ
  • As high as possible first gain stage, 60db (1000 V/V) seems just fine with my 0,34 mV nominal output cartridge. I do use higher PS voltage to allow for more output possibility; now +-18, next +-20V. This leaves second stage to deal with only about 20db gain.
Right now I'm making upgraded PCB with same concept, SSM2017 remain as input, second stage upgraded to OPA828.
SSm2017 specifies 0.012% THD+N at gain of 1000, I probably get it bit better as 2 amps in differential configuration will cancel some distortion. However not the best in class THD, nevertheless doubt if it is hear-able. Nevertheless SSM2017 as ancient as it is, is still unbeatable on noise performance.
Here is PCB work in progress:
Alternatives (in my thoughts) for the first stage :
2nd option is to keep configuration but to upgrade SSM2017 with better INA like AD8429 for instance, as used here https://www.diyaudio.com/community/threads/chipomatic-balanced-input-riaa.331009/post-5627780 (but this is single ended output)
3rd option is classic differential receiver (same as my second stage now) , but that would call for 4 x AD797 and cost of over 70 Euro, I see no other opamp that would fit this purpose.
4th option is to use this ancient schematics and replace each AD797 with it in above schematics. Probably that is as far as low noise is possible.
Matched low noise dual transistors are rare today, but there are many dual JFET's that would do just fine here. Of course some more modern opamp would be used instead of OP27. However, this design for stereo would call for 12 dual matched low noise transistors, quite heavy on wallet.
Or, 5th idea, this very fine simple circuit from John Broskie's site. Looks very tempting even the gain will be max 40db (x100), so second stage will need to deal with another 40db, but that is not major issue if below circuit is quiet enough.
I'm sure that each of these options will work just nicely (when fully developed), but what would be the best?
Any comments, thoughts, ideas?
Polk PSW10 drawing inward on hits
Hello thread goers, i need some help figuring out why my subwoofer is drawing inwards during and after hits of bass. If there is a part where the sub hits and holds a frequency between 30-60hz, the sub kinda recedes into the enclosure. not sure if it’s an optical illusion or if it’s supposed to happen but i just wanted an answer. thanks
video of it happening
How to calculate heating of Diodes
Hello everyone,
I have 4 diodes creating a full wave bridge, and am replacing some old diodes that I have been told look they are getting a little hot.
They work for a DC heater on 211 valves. The heater is at 10.5AC and 10V, 3.25A after rectification.
Is there any way to look at Diode specification sheets and determine temp performance, they are DO-247 format.
Rich
Your best record pre rack
Hi there! I would create my own record rack and I'm interested in what hardware you need for pre-processing sound when recording. I'll include some of your suggestions in my record rack. The basis is naturally clear: a preamp and an equalizer. In my case, they will most likely be the API 500 series and an equalizer based on the Calrec Pq1549. But I would like to learn about the other components from you) I look forward to your suggestions. Yours, Matthews.
#26 pre amp
Hi All,
I am in the process of completing Phaeton RC 26 preamp published on http://www.vt52.com/ site (Jim de Kort) as my latest DIY project. But still I am little puzzled with few things with my current project. Hope someone could provide an expert advice to me to figure out those.
One thing I am confused with is the hum coming out from B+. I figure out it is something to do with the grounding however. Lately I found out that if I ground the filament negative with B+ negative with 470uf capacitor, the hum is almost disappearing. But not sure whether this method is right or safe because what I did was sheer coincidental . Need advice on this. I used separate power rail using a SMPS for filament and both filaments were connected serially with 3V supply. Only connection for B+ negative from this rail is 470uf negative to negative (capacitor + to filament's negative and capacitor - to B+ negative).
Second thing I am puzzle with is the bias supply. Should I use separate 12 V supply for bias for 26 tube or should I use voltage divider to get the bias supply? Where exactly should I connect the bias voltage in this schematic?
Greatly appreciate if someone could clarify these for me.
Added as requested by djn -
Jim de Kort's site
Kevin Kennedy's PF article
Keven Kennedy's Schematic PDF
Where to begin? At the beginning of this thread
Coolzero 1
revintage 1
revintage 2
mach1 sneaks in a 12B4A schematic
Richard's double-fisted 156C choke load
coolzero's hum avoidance diagram
coolzero 2
revintage 3
andyjevans's 10Y preamp
regal's 26 driving 71A
Rod Coleman's DHT linestage
Rod Coleman's DHT linestage with power supply
andyjevans 26 with AZ1 rectifier
coolzero 4
mogliaa's 26 testbed
Original Burnedfingers
euro21
mogliaa's 01A
mogliaa's 26 source follower
dhtrob's 26
andyjevans still can't find the rotate 90° command
Rod Coleman's 26 with a filament-on-filament bias with IDHT output
euro21
mogliaa version 2
Nightpuma's 26
dhtrob 2 (now with grilled pencils)
H.Michi
andyjevans 26 with VR tubes.
andyjevans 26 with VR tubes and CCS
For Sale Salas DCG-3 preamplifier (full kit)
I have for sale 1 complete full kit for new builder. Sales only as a whole, all together.
My offered kit includes:
1, Salas DCG-3 circuit board
2, DCG3 full kit from Tea
3, DCSTB circuit board
4, Salas Mezmerize input selector circuit board
5, LKA AC Power Controler circuit board + ATina
6, GammaAluminium KA200x60 black heatsink
7, TS100VA AUDIO GRADE (240AC, 4x18V)
8, AC connector Schurter 4304.4001
9, On Semi PF5102 (low IDSS measured) 4pcs
I paid 320€ for these parts, I offer 15% discount --- 270€ + shipping. I only send within the EU
Paypal or Wire transfer.
SBAcosutics membrane/diaphragm question
Hi to Everyone,
i have a very serious question regarding the type of "fabric" membrane of SBAcoustics, such as TW29D or TW29R of the SATORI series against the basic series for example SB29SDAC or SB29RDAC because at first sight they seem identical and if it were so it would be a kind of bluff.
The scan-speak instead uses a type of "fabric" membrane for the discovery series and another for the top series, it is very obvious visually.
Also it even seems to me that the scan-speak membranes of the discovery series are very similar/identical to all the "fabric" membranes of SBAcoustics.
But how is this possible?, does anyone know anything?
Thank you very much.
Audio Innovations Alto amp overheating
I acquired an Alto amp last October, and it has run fine until now, apart from a loud buzz which was tracked down to the volume pot's earthing connection. Loosening the mounting nut stopped that. But now the right channel has started to run away, thermally. I have measured everything I can with a multimeter, comparing left and right channels, and have not managed to find any differences so far. This is unpowered, as I only get 20-30 seconds before the fuse on the left channel blows.
I have an infrared thermometer, so I can run it until it gets to about 30 degrees and then power off. The left channel barely warms. Looking at the instructions, I get half PSU voltage on R21/R22 as I should. I haven't yet checked across R21/R22 for 30mV.
I am fine building amps, but not so hot with fault finding, as I can follow a schematic without fully understanding exactly how it works. Hands better than brain! And I have all the transistors and diodes if I need to replace them. I haven't removed any components yet to fully check them.
What I need is help with understanding which components are the most likely to be causing the problem. I can replace any I need to, I can reflow solder joints, etc.
The XEN XELF Headphone Buffer
The XEN XELF Headphone & Speaker Buffer
After finsihing our DIP-8 discrete opamps, we want to have a platform to test its sonic performance.
One Last Attempt at Discrete Opamp in DIP8 Footprint
Morde has built a few of our projects and we know he has a WHAMMY.
He was kind enough to test one of the opamps for us against the OPA627, using the WHAMMY as a platform :
https://www.diyaudio.com/forums/pas...s-diy-headphone-amp-guide-28.html#post5780536
(post #1375)
But we thought we should have our own platform to test as well.
So we asked ourselves the question -- how would our own "WHAMMY" look like ?
The result is the XELF, or XEN Lateral FET Buffer.
Patrick
Reactions: lineup
Possible monitor/monkey box/coffin group project
The topic of a possible monitor/monkey box group design project using less expensive drivers has arisen in the open source monkey box thread. This is a post to gauge potential interest.
Initial spec:
  • large monitor with a height around twice the width and a depth similar to the width
  • suitable for retro monkey coffin visuals
  • clean output at standard levels (80-85 dB average) at 3-4m and down to 30-40 Hz
  • well controlled radiation pattern with a relatively narrow width compared to towers
  • flexible placement and orientation:
    • vertical on a short stand or low shelf
    • horizontal on a higher shelf or for a centre speaker
    • on/in wall
  • versions:
    • straightforward to build with bought drivers and perhaps bought waveguide
    • more complex to build with project designed and manufactured waveguides
  • replaceable midrange/tweeter assembly
  • most versions suitable for passive crossovers
  • standard range drivers and components
Working files on the project are kept here. If you wish to edit and add files please request permission and your google id will be added to the group.
A website and repository for scripts is here. If you wish to edit and add files please request permission and your github id will be added to the group.
Sudden current draw problem from DC-DC converter
Hello again, I made a little electronic gadget for my guitar pedals, let me explain my little gadget first. It's a 5volts 10k mah powerbank tied to a little dc-dc conventer that rated 1.5v & 36v 3amps
When I daisy chain it to few pedals at 9 volts which drawing like 300ma at total, it works great, problem arises when I chain it for like 5+ pedals.
If all pedals switched on, powerbank and all the leds of pedals flashes rapidly 3 times and I lose the power and powerbank turns off.
Then I tried something different, I changed my dc-dc's output to 18volts and plugged in to a power supply that designed for pedals, samething happened again all leds including power supply's flashed rapidly but weaker for 3 times then powerbank shutdown itself again...
My question is how can I make this setup to engage and keep my power supply running, because I have no problem powering and cranking my Yamaha Thr10c amp. It has a power adapter that rated 15v 3A. Somehow I just can't draw enough power for 9V 1A or just the power supply itself which is like 18V 200ma without anything attached.
Any help would be great !
Edit: changed my question
The very free speaker! - Mount any number of drivers in any position I like, with any wiring method I like, without worrying about design theories!
This is an enclosure that can be played with and tested in various ways (model : DDVP-1303-WHIM).
Recommended drivers are MarkAudio CHP90 mica, CHR90, Alpair10.3, and MAOP10.
In this case, I mounted the three CHP90 at A, C, and E in the drawing and parallel wired them.
It would be interesting to mount them in positions other than A-G, or to mount a tweeter on the upper side of A and a woofer on the lower side plate.
Reactions: tansand
For Sale Papst outer rotor capstan motor
The motor was meant to be used in professional studio tape recorders.
It has dual bronze sleeve bearings and a hard chrome plated capstan, long enough for one inch tape.
The capstan diameter measures .4775 inches which suggests 600 RPM for a tape speed of 15"per second. The second speed may be 1200 RPM.
The motor runs on 115VAC-60 Hz and it requires two capacitors, one for each speed.
To make sure it runs, I'll buy the two capacitors and include them in the sale.
I don't think the motor was ever used because there is no hint of tape oxide having rubbed off on the capstan. I think it was a sample motor from Papst to the Scully Recording Instruments Company.
As yet, I'll have to figure out the wire connections.
Thanks,
Ralf
Revox G36 Tube tape recorder
I have a Revox G36 tube tape recorder in a solid wood case, that I was gifted over 25 years ago in used condition. It has since sat around without any use at all. I am downsizing, and would like to send this off to a DIY that will either restore or use as a parts unit. All tubes in it, AFAIK (I did not remove them). I did not even plug this unit into the wall to see if it works. Local pickup in Bethesda MD only, as the unit is HEAVY.
Here's the catch: instead of asking for money, I want this to go to someone who will donate $ of an appropriate amount to DIY Audio Store to help increase their capitalization. The money should go directly from the successful "bidder" to DIY Audio Store. When the Store informs me that the agreed upon donation has been received, you will be free to pick it up! I'm doing it this way because the last time I gave a PS Audio IV power supply and preamp to a DIY Audio reader before they sent the contribution, they stiffed me and DIY Audio by not sending the contribution )if you want more details, please PM me).
Looking forward to getting this to someone who has better use for it AND helping DIY Audio Store.
Reactions: pcjoe123 and JRKO
Single Ended: the pentode retaliation
As a side thread from the original one for the Push-Pull ( Shunt Cascode Driver meets UNSET for Push-Pull ), I post here a preliminary version of a pentode-driving-a-pentode single ended amp with a DF of 8.6 (Zout is 0.93 Ohm considering 0.2 Ohm of secondary winding) without any gnfb, and capable of 30Wrms with 1.34% THD.
attachment.php
The driver is a pentode CCS loaded with a-g1 feedback, whilst the output is a pentode with a-g1 feedback plus the same amount of UL.
I've used this transformer as reference: TTG-KT88SE - Tube output UL transformer [3kOhm] KT88 / 300B SE - Shop Toroidy.pl
I can get 0.089% THD at 1 Wrms:
Code:
Harmonic	Frequency	 Fourier 	Normalized	 Phase  	Normalized
 Number 	  [Hz]   	Component	 Component	[degree]	Phase [deg]
    1   	1.000e+03	3.959e+00	1.000e+00	 -179.97°	    0.00°
    2   	2.000e+03	3.508e-03	8.861e-04	  -91.90°	   88.07°
    3   	3.000e+03	3.851e-04	9.727e-05	 -179.56°	    0.42°
    4   	4.000e+03	2.383e-05	6.019e-06	   13.08°	  193.05°
    5   	5.000e+03	1.936e-05	4.890e-06	   -0.11°	  179.86°
    6   	6.000e+03	1.483e-05	3.747e-06	   -0.20°	  179.77°
    7   	7.000e+03	1.271e-05	3.211e-06	   -0.19°	  179.78°
    8   	8.000e+03	1.113e-05	2.812e-06	   -0.17°	  179.81°
    9   	9.000e+03	9.894e-06	2.499e-06	   -0.15°	  179.83°
   10   	1.000e+04	8.905e-06	2.249e-06	   -0.13°	  179.84°
Total Harmonic Distortion: 0.089152%(0.089155%)
The driver is swinging 70Vpp at 0.015% THD:
Code:
    1   	1.000e+03	3.477e+01	1.000e+00	    0.06°	    0.00°
    2   	2.000e+03	5.256e-03	1.512e-04	  -92.08°	  -92.14°
    3   	3.000e+03	6.492e-04	1.867e-05	    2.58°	    2.52°
    4   	4.000e+03	1.213e-04	3.487e-06	  171.70°	  171.64°
    5   	5.000e+03	9.866e-05	2.838e-06	 -179.89°	 -179.95°
    6   	6.000e+03	8.013e-05	2.305e-06	 -179.91°	 -179.97°
    7   	7.000e+03	6.867e-05	1.975e-06	 -179.98°	 -180.05°
    8   	8.000e+03	6.009e-05	1.728e-06	 -179.99°	 -180.05°
    9   	9.000e+03	5.342e-05	1.536e-06	 -179.99°	 -180.05°
   10   	1.000e+04	4.808e-05	1.383e-06	 -179.99°	 -180.05°
Total Harmonic Distortion: 0.015242%(0.015248%)
I can get 0.32% THD at 10 Wrms:
Code:
    1   	1.000e+03	1.240e+01	1.000e+00	 -179.97°	    0.00°
    2   	2.000e+03	3.662e-02	2.953e-03	  -92.57°	   87.40°
    3   	3.000e+03	1.550e-02	1.250e-03	 -179.47°	    0.51°
    4   	4.000e+03	5.075e-04	4.092e-05	   65.70°	  245.67°
    5   	5.000e+03	7.392e-04	5.961e-05	    1.79°	  181.76°
    6   	6.000e+03	4.516e-05	3.642e-06	   30.00°	  209.97°
    7   	7.000e+03	6.843e-06	5.518e-07	  -29.56°	  150.41°
    8   	8.000e+03	4.013e-05	3.236e-06	   -5.76°	  174.22°
    9   	9.000e+03	3.700e-05	2.983e-06	   -0.23°	  179.75°
   10   	1.000e+04	3.099e-05	2.499e-06	    0.04°	  180.01°
Total Harmonic Distortion: 0.320767%(0.320768%)
The driver is swinging 220Vpp at 0.06% THD:
Code:
    1   	1.000e+03	1.092e+02	1.000e+00	    0.06°	    0.00°
    2   	2.000e+03	5.965e-02	5.462e-04	  -90.23°	  -90.29°
    3   	3.000e+03	2.869e-02	2.627e-04	    2.11°	    2.05°
    4   	4.000e+03	2.370e-03	2.170e-05	   97.59°	   97.53°
    5   	5.000e+03	1.253e-03	1.147e-05	 -177.33°	 -177.39°
    6   	6.000e+03	2.699e-04	2.471e-06	 -150.75°	 -150.81°
    7   	7.000e+03	1.610e-04	1.475e-06	  178.82°	  178.75°
    8   	8.000e+03	1.725e-04	1.580e-06	  178.06°	  178.00°
    9   	9.000e+03	1.551e-04	1.420e-06	 -179.91°	 -179.97°
   10   	1.000e+04	1.384e-04	1.267e-06	 -179.90°	 -179.97°
Total Harmonic Distortion: 0.060661%(0.060662%)
I can get 0.57% THD at 20 Wrms:
Code:
    1   	1.000e+03	1.793e+01	1.000e+00	 -179.98°	    0.00°
    2   	2.000e+03	7.889e-02	4.399e-03	  -93.30°	   86.68°
    3   	3.000e+03	6.615e-02	3.689e-03	 -179.21°	    0.76°
    4   	4.000e+03	1.129e-03	6.297e-05	    2.38°	  182.36°
    5   	5.000e+03	7.964e-03	4.440e-04	    2.39°	  182.36°
    6   	6.000e+03	8.856e-04	4.938e-05	  100.30°	  280.27°
    7   	7.000e+03	1.101e-03	6.139e-05	 -175.67°	    4.31°
    8   	8.000e+03	2.349e-04	1.310e-05	  -63.35°	  116.63°
    9   	9.000e+03	2.290e-04	1.277e-05	    3.30°	  183.28°
   10   	1.000e+04	5.244e-05	2.924e-06	   38.57°	  218.55°
Total Harmonic Distortion: 0.575872%(0.575872%)
The driver is swinging 320Vpp at 0.12% THD:
Code:
    1   	1.000e+03	1.587e+02	1.000e+00	    0.06°	    0.00°
    2   	2.000e+03	1.582e-01	9.970e-04	  -90.08°	  -90.14°
    3   	3.000e+03	1.109e-01	6.988e-04	    2.11°	    2.05°
    4   	4.000e+03	1.605e-02	1.012e-04	   90.48°	   90.42°
    5   	5.000e+03	9.257e-03	5.834e-05	 -176.41°	 -176.47°
    6   	6.000e+03	1.999e-03	1.260e-05	 -101.79°	 -101.85°
    7   	7.000e+03	5.240e-04	3.302e-06	   10.34°	   10.28°
    8   	8.000e+03	2.831e-04	1.785e-06	  136.14°	  136.08°
    9   	9.000e+03	2.713e-04	1.710e-06	 -176.22°	 -176.28°
   10   	1.000e+04	1.879e-04	1.184e-06	 -174.49°	 -174.55°
Total Harmonic Distortion: 0.122318%(0.122318%)
I can get 1.34% THD at 30 Wrms:
Code:
    1   	1.000e+03	2.211e+01	1.000e+00	 -179.98°	    0.00°
    2   	2.000e+03	5.387e-02	2.436e-03	 -100.01°	   79.97°
    3   	3.000e+03	2.631e-01	1.190e-02	 -179.54°	    0.44°
    4   	4.000e+03	5.724e-02	2.589e-03	  -87.39°	   92.59°
    5   	5.000e+03	8.979e-02	4.061e-03	   -0.36°	  179.62°
    6   	6.000e+03	4.086e-02	1.848e-03	   88.38°	  268.36°
    7   	7.000e+03	4.102e-02	1.855e-03	  176.90°	  356.88°
    8   	8.000e+03	2.481e-02	1.122e-03	  -95.10°	   84.88°
    9   	9.000e+03	2.127e-02	9.618e-04	   -6.34°	  173.63°
   10   	1.000e+04	1.379e-02	6.236e-04	   81.49°	  261.47°
Total Harmonic Distortion: 1.342064%(1.344007%)
The driver is swinging 400Vpp at 0.23% THD:
Code:
    1   	1.000e+03	1.980e+02	1.000e+00	    0.06°	    0.00°
    2   	2.000e+03	3.429e-01	1.732e-03	  -90.26°	  -90.32°
    3   	3.000e+03	2.900e-01	1.465e-03	    2.37°	    2.31°
    4   	4.000e+03	6.541e-02	3.304e-04	   88.28°	   88.22°
    5   	5.000e+03	4.225e-02	2.134e-04	 -174.48°	 -174.54°
    6   	6.000e+03	1.313e-02	6.633e-05	  -97.64°	  -97.70°
    7   	7.000e+03	6.336e-03	3.200e-05	   15.17°	   15.12°
    8   	8.000e+03	2.241e-03	1.132e-05	   78.78°	   78.72°
    9   	9.000e+03	1.403e-03	7.084e-06	 -148.60°	 -148.65°
   10   	1.000e+04	6.102e-04	3.082e-06	 -145.97°	 -146.03°
Total Harmonic Distortion: 0.230306%(0.230306%)
Dipping My Toe Into Class A
Greetings from the Multi Way group.
I have spent all my DIY audio time so far making loudspeakers. Mostly I make 3 ways but will probably make a 4 way next with some high end drivers.
I thought I'd pop in here and ask some questions about amplifiers. My experience with them is limited. I am considering dipping my toe into a cheaper class A or tube amplifier to see if this is worth pursueing for me. I can hear a difference between amplifier but so far it has been subtle. The difference between amplifiers seems to pale in comparison to the difference between loudspeakers. This is, quite likely, because I am always using cheaper amplifiers and there may not be a big difference between them.
I have been looking at building and Aleph first watt for some time but I want to know how great a difference a good amplifier makes before I drop a good chunk of money and time doing it right.
All my cheap amplifiers:
I use AIYIMA T9 pros in my office and my pool room
I use a Fosi MT20 for my kitchen
I use a Nobsound Mono for my bedroom 3 way.
The best amplifier I currently have is my Wiim. I use that for my 3 way towers in my living room. Nice to only need one remote for the TV since the Wiim has HDMI.
I want to make a huge jump rather than a small one. I have had my eyes on one of these cheaper EL34 tube amplifiers or a cheaper class A rated. The class A would have 20w. The EL34 maybe 6w.
I listen at much lower levels than most people I think. I measured it and 95% of my listening is done at 55-75 db. My speakers are not the most sensitive. Its usually the woofers that hold me back but I vary between 83-89db on the woofers. Everything else is padded down to meet the woofer. I believe small wattage still might be ok for me.
I will likely start with the class in my office with my 3 way desktop monitors. I will use my audio interface as the DAC and preamp.
I am very open to any other suggestion you have. The EL34 and the class A keep me around $200 just to try this which I consider to be very reasonable for what is, to me, currently and experiment. I don't think I want to spend $1000 right now for something I am not confident I want or need.
I have watched many review videos and read a lot of threads. These two cheap amps seems to be the biggest bang for my buck. Far and away from the quality that I am sure most of you are used to. Open to other amplifiers to try out.
EL34
https://www.aliexpress.us/item/3256...yv4l43Px&utparam-url=scene:search|query_from:
Class A
https://www.aliexpress.us/item/3256...LjE3NDEyNzQyNDIuNDIuMC4w&gatewayAdapt=glo2usa
3 way Floor stander crossover advice
Hi to all,
A newbie here. This is my second speaker build project - the first one being a Parts Express 2 way Usher 701 kit 12 years ago. I am now retired and want to push the boat out both in terms of final result and my learning curve. I tend to aim high knowing I will make mistakes so this time I am aiming for a pair of 3 way floor standers. My set up is:
Room 12ft x 17 ft with speakers to be set up on one of the short sides. Two leather couches and floor to ceiling heavy curtains on opposite short side. Harwood floor.
Amp = Marantz PM 8006
Streamer = Audiolab 6000N with Tidal
Turntable = Rega Planar P1
Building the enclosure should be ok - I have a lot of woodworking experience and necessary tools etc. . My main concern is the crossover. I am new to this so I seek forgiveness in advance for any 'obvious' gaffs. I attach a document with details of drivers and enclosure that I have come up with so far. Am I on the right track at all or way off the mark? Any constructive comments would be welcome. I have not purchased anything yet except a measuring mic for testing when the time comes. Thank you in advance.
Attachments​
Weekend of Sound 2025
If anyone is near Berlin we are doing an event in a few weeks.
There will be a lot of different cabs to listen to.
There will also be some talks. I am doing one about measuring speakers in not the best conditions and getting ok results.
I was hoping to finish a MEH project to show there but fell very behind on it haha
https://facebook.com/events/s/weekend-of-sound-2025/1784542422282003/
Reactions: icebear3000
Iron Pre SE populated
Well it ended up that I had to choose a project. Since I have already built 4 of these, I decided to go with a different project so that I could make brand new mistakes.
Give me a bit to get some photos. I bet that $200 is a really good price and then shipping will be extra. I have to say, these are the best sounding kits that I have ever built. A close second is probably one from Glass Ware Audio, but being tube it is a kind of apples to oranges comparison. Anyway, lets see a show of interest here, and I will get on the ball with more info.
Amp Camp Amp Kit 1.6/1.8
In an attempt to keep things on topic and not clutter up the general ACA thread with order questions or specific about the 1.6 and 1.8 kits, this is a thread dedicated to specific questions about the Amp Camp Amp V1.6 kit from the diyAudio store.
For general questions about the Amp Camp Amp, not specific to this particular version of the kit, please post here:
V1.8 builders - please note below the slight but important wiring changes between V1.6 and V1.8 and use the V1.8 wiring diagram.
Build Guides
For questions specifically about the 1.5 kit, please post here:
Long shot request: ESS 10 inch woofer impedance trace or .zma file. Anyone got it?
I have a pair of OB's of my own design that will be featured in a future post. They consist of a pair of ESS 10's per side accompanied with one GRS 8" planar driver per side with a miniDSP HD for crossover duties. After a year of playing around with different X/O configurations I'm pretty sure a passive X/O should be fairly easy to implement. I'm currently running a 12dB low pass and 6dB high pass X/O with just a bit of EQ provided by the Wiim pro plus I'm using as a preamp (Don't knock it till you try it).
L12/2 Version 5
L12/2 version 5
Many hours later, we have a provisional circuit. Still need checking, we don't want to publish an inaccurate circuit. Don't worry about testing. It's more of an instability rather than an oscillation. Not the kind that draws amps. A major influence on use is C2 a 100pf cap. If reduced to 47pf, the board becomes much more stable. Please don't start modifying your boards. The problem has not yet been solved we are still working on it. I welcome input from anyone that is actively working on this problem. I wonder if LJM knows?? He should be the one to sort it really. More as available. The layout on this board is dreadful.
Reactions: luca0072
GRS 8PR-8 8" woofers (18 units, new)
Change of plans, just not going to work in our full time RV so need a new home.
18) GRS 8PR-8 8" woofers $159 plus shipping, OBO
NIB except one box opened to look at it, none every hooked up.
Willing to work out a deal on the shipping cost if possible.
Also interested in trades but I do not need much at this time.
I was going to order some Mark Audio MA200 drivers but might be interested in another model of MA drivers m in trade, part trade, etc
as I am building the Frugel-Horn Jain large version.
Thanks,
Rick
Show your transformer work (gallery)
Let's create this thread with the same purpose as the tube photo gallery thread, but about transformers. We can show off pictures, measurements, explanations, etc, mostly for fun and potential sharing of knowledge.
I'm starting with my most recent project of freshly wound coils, that are specially made for SE high Rp output stages with Rp ranging from 10k to 24k in series primaries and 2,5k to 6k with paralleled primaries.
More information about Gryphon audio equipment
Greetings all,
I was here for long time as a reader but recently I have purchased Gryphon audio system and I would like to know more about them.
System is composed of Preamp and a power amplifier.
1- Gryphon LE limited edition 91 of 100
2- Gryphon DM 100 limited edition.
I did some research but. I couldn’t find detailed reviews. Since these seem to be old models. Please if you know any information about the models like when was manufactured or specifics design criteria it would be great. By the way the system sounds fabulous in my room.
Thanks 🙏
Ahmed
Japanese 100V First Watt amps - run at 240V
I purchased a pair of SIT1 mono's from Japan, which are currently en-route to myself in Europe. I realize only now that Japan runs on 100V and not 120V.
I was planning to adjust from 120V to 240V via wiring the dual primary transformer in series.
I guess, with these Japanese amps, I won't be able to do so... WHOOPS!! Live and learn 🙂.
I suppose I need to replace with appropriate transformers? If anyone has the original AnTek part number that would be appreciated.
Note I reached out to First Watt directly some time ago with a similar question but did not get a response, therefore asking here.
Simulation of a 3-way speaker with a cardioid pattern
Hello everyone, I am trying to run simulations in Vituix, with the aim of creating a 3-way speaker with a cardioid pattern. I started by tracing the speakers from the manufacturers' websites, then applied the low-frequency loading and baffle diffraction using the various tools that Vituix offers. My goal is to replicate the speaker to see if I can achieve reliable simulations with what I have designed and measured.
I will post a couple of graphs to share the simulation results and perhaps get suggestions for improving the whole setup.
The speaker will be a stand-mounted design, with dimensions of approximately 40/45cm in height, 35cm in depth, and 20cm in width. The tweeter and midwoofer will be placed on the front panel axis, while the two subwoofers will be positioned on the two side panels.
The crossover will be active, and the goal of the project, in addition to evaluating the quality of the simulation, will be to attempt to simulate an active cardioid system using the two side subwoofers.
Many thanks
Stefano
  • Thank You
Reactions: krivium and GM
bookshelf horn speaker for small room
After finishing my last speaker build i became interested in horn speakers. Especially the subject: horns/waveguides controlling early reflections in small rooms.
The Goal of the design is to provide good sound in a small room by lowering the amplitude of the early reflections, especially floor and ceiling reflections. Also, provide ample bass extension while limiting speaker size (Buchardt Audio S400).
The effect of early reflections is quite hard to deal with in small rooms, caused by the lack of flexibility in layout and space for room treatment.
I would love to hear your $0.02 on horn selection, LF driver selection etc. don't hold back!
March 14, 2025:
HF driver will be celestion cdx1-1747.
Currently working on the effect of the baffle on extending directivity to lower frequencies.
Evaluating directivity of RS180-8 on a baffle to match directivity with the HF driver.
Original text
For the HF i came up with the following combo:
Peerless XT25TG30-4 mounted on a no name constant directivity horn form Aliexpress. It measures 160mm x 160mm and has a depth of about 100mm.
After modeling the combo in AKABAK (without LEM, haven't figured it out) the following results are pretty good, IMO, for a 10 euro horn.
I already received the horns in the mail. Pretty thick material and a nice finish on the front. The flange to the driver is not that good. Its bumpy but fixable.
PS: the lines on the graphs are steps of 10 degrees. for the delay spectrum the color steps are in 5 dB.
Would this combo be any good and what would you use?
Wharfedale Triton crossover
I recently purchased some Wharfedale Triton speakers off eBay, with the intention of refurbishing them as a learning exercise. Essentially a practice pair of speakers, to learn how to clean the grille cloth, rewire and re-cap, that kind of thing. They came with a captive speaker cable that was terminated with a two pin DIN plug. Without thinking, I just chopped those off, as the little amplifier I use to test things only takes bare wire. I naively assumed that there would be some +ve / -ve type marking on the crossover circuit board inside, which it turns out there isn’t.
Here's the speakers in question:
A top view of the crossover, note that two of the inductors are missing any indication of value:
A mirrored view of the bottom of the crossover after I'd de-soldered all the leads:
I took some photos and attempted to try and understand the circuit, so I could determine the correct pins to wire up to some proper terminal posts. I started on a whiteboard, then tried to convert that into a “proper” circuit diagram. I’m new to all of this kind of thing, and am not sure that I’ve used all the correct symbols and terminology on the diagram; I would welcome some feedback on that.
My whiteboard circuit:
And the resulting circuit diagram:
Could someone please confirm whether my circuit diagram is accurate…? Specifically, I would like to verify that I have correctly identified the positive and negative input terminals on the circuit board. That would be the right most tab being the positive input, and the one to it's left, being the negative input.
Bob.
Inkel MA-920 help
I just got this amp in very good condition. I liked its sound but I hear some noise when I close to the speakers (102dB sensivity) on both channels, even though amp specified as 105dB S/N ratio. I don't hear any noise from my Kenwood KM-106 amp (120dB S/N specified) with same speakers. Is this expected from such a big amp even though reasonable specs? or should I worried with something?
What is the purpose of the SVR114 pot? Is it for adjusting the DC offset which is around 10-15 mV on both channels.
Can I omit C108 NP dc blocking cap, (if the opamp offset is low) since there is another one (C110) next to it ?
Regarding the topology and the schematic, is there anything that can be improved? Any comments and suggestions?
Thanks in advance.
Reactions: hpavictor
UltraAnalog D20400 DATA ! I have it all !!
Yes, I finally have the application notes!
And the DEMO 1 eval board paperwork and of course the original datasheet which is readily available but this time in much better quality.
Where did I get them from? I asked Daniel Weiss if he had them after discovering his BW102 studio mastering processor used some in the 20bit DAC module.
So a BIG thankyou to Daniel Weiss! A very friendly and helpful man.. even though he's also a very busy man too.
I've uploaded them to PDFcast.org so they will be searchable on there in the future and here are the download links:
UltraAnalog D20400 Application Note AP02 (pdf)
UltraAnalog DEMO 20 bit ADC - DAC Evaluation Board Datasheet (pdf)
UltraAnalog D20400 20 bit DAC Datasheet (pdf)
Have fun with those people.. I will.
Keep a look out for D20400s in old 20bit pro equipment like Philip Drake broadcast gear, Weiss BW102 mastering processor 20 bit DAC modules - there will be others.
China 500w amp cutting out
I have been trying to get 2 china 500w amp boards to run in full bridge mode with a single supply of 160 volts.
Currently the grounds are connected between the 2 I will try floating each on its own as I can but I don't think that will fix the problem...any ideas? I'm thinking the ground is being modulated on the VAA VSS side causing a shutdown....this happen at fairly low volume.
Hi all!
Hello,
just signed up here, I've been reading and following some threads here for a while and really value the communities' input. I'm currently on a mission to revive my dad's NAD stuff (mainly an amp and CD player) which have failed and have been sitting in my mom's basement for years.
Next to that, I'm interested in building a set of speakers for my living room.
I have experience tinkering with and fixing stuff, sometimes with limited success, but I'm confident to give it a try. In the past, I've built transmission line speakers, a portable bluetooth speaker, a guitar tube amp (from a build kit), and fixed up some nice old studio headphones.
Looking forward to the discussions,
Cheers from the Netherlands, Felix
Experimental Distortion Matrix
Guitar Distortion Matrix
Here’s a circuit that provides a variety of distortion sounds for the electric guitar. The passive diode matrix should be driven by an active device, such as a volume-boosting stomp-box or guitar preamp, while the output can go to any kind of guitar-amp or other such active device. The design is based on the distortion circuit in a project called the “Mod Box” that appeared in Electronics Now magazine in 1997 (May issue, p. 45). And while the article is old, the circuit I designed based on it remains perfectly valid.
The preferred sounds, emphasizing even-order harmonics, with either the Fuzz, Buzz, or Overdrive settings is to activate only one diode oriented in a given direction but two in the other direction. It does not matter which directions are chosen for the combination as long as there’s an imbalance. Of course, any setting provides distortion. The germanium diodes, in the Fuzz setting, are said to give the most pleasing distortion, similar to that of a vacuum-tube clipping, while the silicone diodes give a harder sound, with the LEDs the brightest.
Because of significant loss of input signal level to achieve the distortion effect, some kind of active device, such as a stomp-box with extra gain, is needed on the input. Or, to turn this into an active project, battery-powered solutions are shown below. Use the preamp to drive the matrix and put the buffer between the matrix output and the input of an amplifier or other active device. And I recommend keeping the input/output jacks as shown, to allow for the greatest versatility, even if everything is put in one enclosure. For the +9V DC supply, connect the negative end of a transistor battery to ground so the positive end is the supply. And one battery will serve both circuits.
EOF
AIYIMA YM91R20-2F-ZXJ-L1 (3", full range)
AIYIMA YM91R20-2F-ZXJ-L1 (3", full range) installed in HB-07F-ML (double bass reflex).
It is a low-priced product, but it has a die-cast basket and neodymium magnet.
The sound quality is better than the price. Cost performance is high.
Login to view embedded media
Pass XP-12 with FW F5
well today I moved aside a processor I've been using as a preamp with my F5
In went a 6SN7 buffer, noice! The dynamics suffered a bit in comparison but lower mids & bass were better resolved, tighter and deeper. The upper extremes were cleaner
I use to run a 300cx with a Pass Labs X1 pre, that was oh' so' yummy! Very little of my music collection sounded off, and this is the direction I want for my F5
Whats peoples thoughts on a Pass Labs XP-12 with an F5?
Has anyone used a Pass Labs preamp on their F5, if so I'd appreciate your findings please?
I'd rather buy a preamp as I already have another DIY project in the works.. 3 way 4 driver speakers for which I bought the drivers 15 years ago, Scan Speak & Focal
Thanks AL
waveguide for xt25 for crossing at 1 khz
I am working on a build from a slavaging a 22liter slanted baffle speaker cabinet, with driver xt25 and mw19p (or mw19tx)
I know this build is done to death and can reference troel‘s desgin however I want to spice it up having crossover frequency at around 1khz, to minimize the woofer directivty problem so the tweeter needs a waveguide. does any onknow the smallest waveguide i could use ? i am hopping something like a 4 inch waveguide or an elliptcal wavrguide to modify the exisiting 3 inch dome opening in the cabinet
Need some help decorating my music room
Hello, I have a interest and nostalgia for vintage hifi from the 80s and 90s, I don't have all the space in the world but a small room of 2 x3 meters. You have to make the best of what you have, right? But need some tips and ideas on how I can decorate this room?
I have a thought about replacing the white shelf with one that is a little deeper to have the hi-fi on display is it a stupid idea? But all thoughts and ideas are welcome with thanks
Quiet PA amps
I use my PA system as my home HI-FI and so have an interest in any PA amps that are close to silent. Also in many situations even in PA very noisy fans can be audible for some music genres. I thought it might be informative to share a list of amps that are both powerful and do not make excessive noise. An amplifier can be classified as quiet as long as the fan noise is not audible from 2m away during light usage. I'm not very keen on modifying amplifier cooling unless airflow capability is retained.
Not Quiet:
Behringer Inuke
Cloud VTX series.
Ecler pam 1400 power amplifier
Powersoft Duecanali 5204
Powersoft X4 (Can hit 80dB/1m, so noisy it could even be a problem for some PA use)
Crown XTI series.
QSC RMX
Peavey IPR1600
MC2 amps (not sure on specific models)
Classic crown Macrotec MA5002VZ ETC. (Macro-Tech 3600VZ notable mention)
BSS EPC780
Crown I-tech 5000
Nady XA-900
Gisen K21x4 (and probably Soundgear Saturn 16 as it looks identical)
Not a total racket:
Powersoft Duecanali 1604
Samson S2000 2*650W@8 ohms 2*1000W@4 ohms, 2000W bridge
MC2 MC series
Crest CLh5000 (2*1470 watts 4 ohms (tested to far more on single channel))
Crest CA9 (the CA2, CA4 and CA6 should be about the same in this regard)
QSC Powerlight 2 series.
MC2 Txxxx series
Quiet fan:
Peavey CS800s
Yamaha Triple E series of amps(P, PC-1N, XP) E.G Yamaha PC9501N ~2*1500W 4 ohm
Yamaha P7000s (fan does not spin normaly, 2*1100W 4ohm - conservative rating)
Lab Gruppen E-series (2*200W 2/4/8/16 ohm)
Carver PM700 240W@8 ohms 325W@4 ohms (fan inside unit)
Samson SX-2800, 2*700W@8 ohms, 2*1000W@ 4 ohms, 2000W bridge
QSC USA 700, 2*240W @ 8 ohms, 450W@ 4 ohms, Bridged 900W
IMG STAGELINE: STA-2000D/STA1000D (fan does not turn on in normal use upto ~85C?) (upto 4*500W, 4ohm)
Speaker Power SP2-12000-DP (2*6000W, 2ohms)
Crown XLS DriveCore 2 Series (up to 2*775, 4Ω (XLS2502 )) (fan does not turn on in normal use, multiple reports)
Dynacord SL Series (up to 2*1200W @ 4Ω (SL 2400))
Crown CTS4200 (4*260W 4ohm), (fans don't spin on my unit at idle - others report differently there may be firmware differences)
the t.amp TSA 4-300 4*550W (4ohm)
lab Gruppen C series (passive under low load)
Crown CDi1000 (2*968W 4ohm, fan does not spin under light load however once fan spins its quite noisy)
QSC EX800 does not run its fan until it gets hot (2*325W into 4ohm)
MC2 Delta 20 (4*350W 4 ohms - unit can have internal link changed to force fan to run at low speed but may thermal power limit as a result)
Powersoft Mezzo 6 series (up to 2*300W 4 ohms)
the t.amp Quadro 500 DSP (4x 500 W at 4 Ohm, 4x 250 W at 8 Ohm)
Fanless:
Extron XPA amplifiers (upto 400w per channel, 800w bridge - lots of models, PSU has slight hum in my second hand XPA 1002)
Apart audio champ 2, 2*(180W 4 ohm, 120W 8 ohm)
Apart audio PA2120, 2*(120W 2/4/8 ohm, Small amount of mains transformer mechanical hum audible in silent room)
Stewart world 600 (2*190W 4 ohm)
Stewart world 1.2 (2*350W 4ohm)
Behringer A500 (~2*200W 4ohm)
Behringer A800 (2*250W 4ohm)
Crown K1/K2 (upto 2*1250W 2 ohm)
QSC 3500 (2*560W 4ohm, 2*700W 2ohm, possible transformer hum)
Samson Servo 550 (2*275W 4 ohms, 1*550 watts into 8 ohms (bridged mono mode) , runs hot when pushed)
3e Audio EAUMT-0140-2-A (TPA3251 based) (2*128W 4ohm)
Powersoft Mezzo 3 series (upto 2*160 W 4 ohms)
QSC SPA series (upto 1*400w into 4/8ohms in 1/2 rack space)
Reactions: stoneeh and mrk7
Electrocompaniet EC-3 and ECMC-1, schematics wanted
Dear all,
I am looking for schematics from mentioned Preamp and Step-up board. Main pre is working OK, with Line inputs, but phono one have problem. Since ECMC-1 is a step-up board, I cannot check it either. I contacted mother company but they told me it is not in their policy to share such service information...
I would appreciate if someone has drawings (is OK in scan or photo) to help me out to repair it.
Best regards,
John
Tear down my three-way driver selection
Background: I've successfully built a passive small 2-way paired with a DIY under-bed subwoofer. Next project (with no particular hurry or deadline) is a pair of 3 way bookshelves inspired by Troels' Bookshelf-3WC. Really just borrowing the driver alignment. Would like to make the cabinets sealed rather than ported but if I need to port to get down to ~40hz I will. Speakers will be on a literal bookshelf surrounded by books.
This will be a hybrid active/passive, active DSPed crossover for the woofer to mid/tweeter, and passive between those. Aiming to cross over between woofer and mid at <200, and to the tweeter over 7k. System will be for casual listening in a library, aiming for a wide listening area rather than a sweet spot, and will not be played loud.
So far these are the drivers I'm looking at. But this is where my expertise flags so really let me have it.
Woofer: Dayton RS225P-8A
Mid: TB WS-2143
Tweeter: Dayton ND25FA-4
The woofer I've used before in the bedroom sub and like it well enough there, and in this application isn't having to take on the midrange.
Threshold FET One Series II E/series version
Today I purchased a beautiful Threshold setup locally, including an S/300 Series II amp and a FET One Series II. Both units have a sticker that indicates they've been factory updated to the e/series STASIS topology. I bought them from a local audio dealer who bought them from the original owner.
The preamp has jacks for the MC inputs, but the MM input is blocked off. Inside the preamp, the circuit board looks very different from other photos of FET Ones I've seen. Mine is more similar to a FET Nine I've seen a photo of, with little daughterboards attached to the main board, which presumably host the preamp circuits. The phono preamp boards have a DIP switch nestled between them, which, if it's similar to the FET Nine, allows different impedance and capacitance settings to be selected. But I haven't managed to find a manual for this particular mod of this preamp. Do any Threshold experts here have any insight to the switch positions for the FET One Series II with e/series mod?
I've attached a couple of photos of my unit. Thanks for any help!
Long time Lurker, first time poster!
I have been doing off-and on DIY audio projects since the 2000s. First one was and IB subwoofer cut into my attic in ~2005 with 4 Dayton audio subwoofers. Later on built a 7.3 home theater system with modified Econowaves built into a baffle wall.
Did nothing for years. Recently built a pair of desktop speakers with the Mark Audio Pluvia and some pieces of firewood. Next projects I am planning are some 18" subs and TAD 2404 clones, and some 15" OB speakers.
Reactions: birdbox
Advent Maestro speaker question
I've got a pair of Advent Maestro speakers that were given to me today. They are in good condition and the woofers were refoamed a few years ago.
I already ordered new caps for the crossover.
Two things I've noticed.
1. The speaker wire terminals on both speakers has separated from the terminal cup with the crossover on it at the bottom. What should I use to secure it back down?
2. I've read where the woofer doesn't play high enough causing a hole in the frequency response near the crossover point of the woofer and midrange which is 900Hz. Listening to them, I believe I actually hear that, but will wait until the film caps come in and are installed to see if that fixes it. If I still hear the issue, what is the best way to eliminate the issue? Normally I'd just use a different inductor value for the woofer, but the inductor is part of the dish where the fuse, speaker terminals and other crossover components are and I'd have to add an inductor which would require mounting it somewhere in the cabinet.
What I should do is disconnect a midrange and test it using my DATS V3 speaker tester so I can see what the impedance of it is as in order for the 14uF cap value to be correct the midrange impedance would have to be 12.5 ohms provided the specs I found are correct. That's not exactly possible though given the speakers are at work now.
Specs of the speaker.
https://audio-database.com/ADVENT/speaker/a-1012.html
Also I will run these with a powered sub.
The response is +/- 3dB 42-23kHz
I currently have the powered sub crossover set to 40Hz, but am not that happy with it.
I can put two 160uF electrolytic caps in parallel to make a 320uF cap which based on the rated 6 ohms impedance of the speaker will give me a high pass of 82Hz.
I might try that tomorrow with the caps between the + speaker lead and + speaker terminal. If it sounds better then I may install the caps between the + speaker lead and woofer inductor (when i install the film caps) so that I don't run the risk of the caps affecting the midrange and treble.
EDIT:
Here's the crossover schematic I found.
However the response graph I found seems to suggest there is no hole in the frequency response.
Another realization of Bob Cordell's THD Analyzer
Hi all,
I started the adventure to build Bob's THD Analyzer.
I made new PCB for my implementation.
They are: one for Sine Generator and Output Attenuator with the connector for the switch capacitors range board.
The cap sw PCB for Sine Gen, and Filter range (two equal for both).
One for Filter, Amp and Freq Detect.
One for Output Filter with connector for the Meter
One (little) for Meter circuits. Mount AD536AH for RMS conversion
One for Input Attenuator/Amplifier
I still have not decided how to switch the resistance of the frequency, probably Optofet or Photoresistors but they latter have serious problems of thermal drift.
....le first photos
Hafler Iris Preamp remote control issues
I have a Hafler Iris Preamp, which I love. Probably will need a re-cap soon, but working well right now. Managed to find an Iris remote on eBay. Yes, my Iris preamp has the receiver board.
However, when batteries are put in the remote itself, the red tally light simply keeps on flashing (about 2x/second) and there is no response from the preamp to any button pushes on the remote. I believe the rcvr board in the preamp is functional, as apparently if there are issues with it the preamp won't come out of muting.
I've tried IR detection using the camera on my iPhone and there's no apparent flash from the remote. I've confirmed that I do see flashes from a known functioning remote.
Any ideas on where to start? I'm also asking on AudioKarma, as well as checking in on D. Hedin's thread here on making your own Iris remote in case mine can't be revived.
Thanks in advance!
Waldemar
Directivity study- polar maps of HF, MF and LF drivers in cabinets
I've posted a small study comparing High, Medium and Low Frequency drivers in a variety of cabinets.
It's on another forum that allows me to edit/amend as more data becomes available.
First up, some pretty colors:
Edit: Feb 2025- Speaker colours explained;
SPEAKER 3...
Normalised:
SPEAKER 3:
3 way speaker with twin 12” woofers in 13.75" wide, MT cabinet 9.5" wide with 6” midrange + 1” ring radiator offset from centre, no roundovers,
2.83V input applied:
Reference:
SPEAKER 2:
Normalised:
SPEAKER 2:
3-way speaker with 8” woofer in 21cm wide cabinet with 1" roundover, and 5”/1” coaxial driver,
2.83V input applied.
Reference:
Now, if you're not sure of how what these colors/shapes mean, then this directivity study is for you!
It's aimed at bringing you along the journey of speaker designs which have with smooth frequency responses in many directions.
If you are familiar with seeing a single on-axis (or a few off-axis ) measurements for loudspeakers, please have a look at this study to observe how off-axis measurements varying over a larger span eg. up to 360° horizontally and vertically may add value to your designs, and how the use of non-normalized polar maps may assist.
My study incorporates-
1.High Frequency devices includes dome tweeters, ring radiators, ribbon tweeters, compression drivers, in cabinets with and without round-overs, with or without waveguides/horns, or even without cabinets (nude).
Start at the top for a background/explanation
Jump straight to posts for non-normalised polar maps (horizontal 0 to +/- 90 ° minimum; 0 to +/- 180 ° horizontally and vertically where/when available):
All drivers highlighted in bold type are by fellow DIYers who kindly offered their data for our perusal / interpretation.
A model of a theoretical 3/4" flat piston tweeter on a 5 1/8" wide baffle with large 1.5" round-over
SB Acoustics SB19ST-C00-04 a 3/4" soft dome tweeter on a 5 1/8" wide baffle with 1" round-over
SB Acoustics SB29SDAC on a 8" wide baffle (coming soon)
Scan-Speak D2604/8330-00: 1" soft dome on a 8.5" wide cabinet, offset 1/2" from center line
Scan-Speak R2604/8330-00: 1" ring radiator in same cabinet, again offset 1/2" from center line
Fountek NeoCD3.0 a 8x60mm ribbon tweeter on a 8.75" wide cabinet with 10mm round-over courtesy @DcibeL
Fountek NeoCD3.0 on a 11.5" wide cabinet with 3/4" round-over courtesy Curt Campbell and @jholtz
Fountek NeoCD3.5H a ribbon tweeter & integrated horn on a 8.5" wide cabinet with 3/4" round-over, courtesy Göran @gornir
Fountek NeoCD3.5H nude (not mounted on any cabinet), courtesy @Juhazi
B&W HF00963 in tapered tube hard dome tweeter in a minimal baffle/tapered cylinder, courtesy @PKAudio
Tymphany DFM-2535R00-08 attached to a SB Acoustics H225 and H250 constant directivity horns, both nude
Tweeter of SICA 5-5-C-15-CP coaxial driver, mounted in 7" circular frame with 1/2" round-over, courtesy @vineethkumar01
Tweeter for SB Acoustics SB17CAC / SB17NBAC coaxial prototype courtesy @5th element
Tymphany XT25BG60-04 in Visaton WG148R waveguide, mounted on 11" wide baffle with 1.5" round-over
Various tweeters in courtesy @augerpro's waveguides mounted in real cabinets, with or without round-overs (including SB26CDC in 6.5" elliptical waveguide, Peerless OT19NC00-04 in 8" elliptical waveguide, horizontal measurements), Donate!
SB Acoustics SB26ADC in a customized 8" waveguide for 60° beamwidth from 1K to 12KHz. courtesy @fluid
tweeter from KEF R series (non-META) coaxial, mounted in a cabinet with 1.5" round-overs
tweeter from KEF Blade Meta/Reference Meta, mounted in cabinet with 1.5" round-overs vs no round-over (awaiting cabinets)
2. Medium Frequency devices includes cones and domes, typically covering 3-400Hz to 3-4KHz
B&W 5" FST midrange in 8.75" wide cabinet with r10mm round-over, courtesy @DcibeL
Larger 6" FST midrange in 9.5" wide cabinet and 8.5" spheroidal cabinet
previous generation (Kevlar) 6" FST midrange in the same 8.5" spherical cabinet
Volt VM752 3" dome midrange in 14.5" wide cabinet, offset 1 11/16" from center, courtesy @mbrennwa
Faital 4FE42 4" cone midrange in a 6" spheroidal cabinet
Purifi 5" and 6.5" drivers on same width baffle (completed, awaiting publication)
Purifi 6.5" aluminium vs fibre cone
3. Low Frequency devices includes woofers and/or subwoofers, typically covering 3-400Hz and below:
KEF LS60 's dual 5.25" woofers, side firing, in dual opposed configuration, rear ported courtesy @bikinpunk
KEF Blade 2 Meta's quad 6.5" woofers, in dual opposed configuration, 2 on each side panel, with rear firing ports courtesy @bikinpunk
KEF R11 Meta, quad 6.5" woofers, all 4 on front panel, with rear firing ports courtesy www.audiosciencereview.com
Thanks again to all those involved who kindly supplied their measurements.
If you find anything that you feel is a misrepresentation of your data, please let me know.
All constructive comments welcome, as well as suggestions for better readability. It's a lot of graphs, I know.
PS. If a link is currently unavailable; then it is currently being updated/edited. Try again in 24 hours. Thanks for your patience.
Speaker 1...
A Cheap thermal IR camera for troubleshooting power amplifiers
I've been working on an old power amplifier (SAE MK3CM) that has a problem with one channel. It works OK for a short time and then the positive side of the output waveform starts to clip, somewhere around 5V. Most of the voltages measure reasonably close to what the SM says they should, but one clue is my nose. I can smell something getting hot. So I decided to make myself a thermal IR camera to determine what's getting hot w/o burning myself or potentially connecting my body to up to 150V (the supply rails are +/- 75V).
I found a relatively inexpensive IR camera that has a 32 x 24 pixel array, the MLX90640. Sparkfun and Adafruit will sell you a board with one on it for about $70 -- and that doesn't include the display and Arduino-ish board needed to process and display the thermal image. However, I already had a Teensy 4.0 and a 320 x 240 TFT display so I just bought the camera chip from Digikey. The camera only has 4 pins -- Vcc, ground, SDA and SCL -- so I just soldered it down to a piece of perfboard.
Adafruit has some example programs for their version so I downloaded them and modified one for my particular display (it has about 4X the number of pixels than the one they use). And it works surprisingly well. So I cobbled together a setup to view the component side of my power amplifier and did find significant differences between the two channels. So here are a few photos showing my admittedly crude setup:
The above photo shows the display. The camera is attached to the tripod using a "C" clamp with some scrap 3D printing failure I had lying around. The amp is shown in the lower right side.
Above you can see the Teensy 4.0 and a better shot of the camera. The camera chip actually is on the bottom side of the board, because I installed it upside-down....oops...
The above image shows what the "good" side of the amp looks like, thermally speaking. The two hot spots are two cascode-connected transistors whose inputs are the front-end LTP's. In normal operation they should dissipate about 76mW.
This is a photo showing the faulty channel. At least one of the transistors -- which happens to be associated with the positive side of the output waveform -- clearly is running hotter. So I have narrowed-down my search by quite a bit. BTW, my hand, which is around 80F, only generates a yellow color so the hot spot is pretty warm.
One initially-challenging problem was figuring out just exactly WHERE those hot spots are. I tried using my finger to point at the hot spot but it was just too big. So I made a hot spot "wand". Just a 120 ohm 1/4 watt resistor taped onto the end of a wood dowel. I adjusted the power supply driving it so it doesn't overload the camera. And here's my high-tech "hot spot":
Making a Hafler IRIS remote control
I was recently gifted a Hafler IRIS pre-amp (along with a DH-200 amp). Unfortunately it does not have a remote control.
Remotes are rare and expensive. In addition one requires the internal receiver board. Cost could be $120 or more if I could find them.
I have studied the IRIS schematic and have decided to roll my own IR remote control.
My plan is as follows.
I'll be using one of these remote kits for arduino.
https://www.ebay.com/itm/373765651681
I will then interface this to an Arduino Pro micro (5v version)
I only plan to implement volume, and input selection at the first go. But I may add balance and normal/mute functionality later on.
Below is what I have figured out so far regarding the interface from the IR receiver board to the pre-amp. This connector is on the back of the display panel of the unit.
In addition there is a transparent window where the receiver phototransistor would mount near the connector.
I will mount the Arduino board on perf board and there will be an LM324 to translate the D/A output of the Arduino to create the volume/ balance 0-14v control voltages.
There will also be some 5v to 16v logic translation for the input mux and other control signals.
My first experiment will be to hook up some potentiometers and dip switches to see if I can fake the operation manually.
I will post progress in this thread. All comments and suggestions welcome.
Wish me luck...
Hafler Remote connection
Pin Name Notes
1 JAM I believe JAM is used to lock input selection when recording.
2 RMB 0-14 volts for balance setting from remote
3 RMV 0-14 volts for volume setting from remote
4 REM V/B Active high pulse to set volume, active low to select balance
5 Neg16v
6 NORM Active high pulse to select normal remote
7 MUTE Active high pulse to select mute remote
8 WARN ??
9 Pos16v
10 GROUND
11 N/C
12 I2 "C" select for Input MUX
13 I1 "B" select for Input MUX
14 I0 "A" select for Input MUX
15 I3 Believe this is pulsed high to latch the LED indicator for input and latch selection
What happen to LC Audio Technology? Acquisition by an other Company?
What happen to LC Audio Technology ? Acquisition by an other Company ?
Very interesting ideas were always realized here.
Some examples:
Millenium Amp
https://www.octave-electronics.com/lcaudio/temil.shtml
https://web.archive.org/web/20011214001242/http://www.lcaudio.com/temil.htm
https://web.archive.org/web/20011110044633/http://www.lcaudio.com/millmateng.PDF
http://www.diyaudio.ru/filestore/Millenium_-_cookbook.pdf
https://www.diyaudio.com/community/...m-xp-help-if-possible-from-lars-clause.75711/
https://www.diyaudio.com/community/threads/end-millenium-amp-opinions.167/
DC-Filter
https://www.hifisentralen.no/forumet/classifieds/lc-audio-dc-filter.106920/
Low Noise Regulator
https://www.diyaudio.com/community/threads/improving-on-lcaudio-lownoise-regulator.45451/
http://mihalcz.ingyenweb.hu/keret.cgi?/other/ulnreg.html
https://www.diyaudio.com/community/threads/ultra-low-noise-regulators.337183/
Dual Mono RIAA
http://www.audiofilo.com/esp/lcaudio/Sidewinder.htm
https://www.diyaudio.com/community/threads/lc-audio-dual-mono-riaa-light-mc-headamp.210506/
Line and RIAA Stage Upgrade with AD825 Operational Amplifier
https://www.octave-electronics.com/lcaudio/ad825.shtml
LClock XO Precision - CD Master Clock Generator
https://www.tnt-audio.com/accessories/lclock_e.html
https://www.diyaudio.com/community/threads/masterclock-help.167512/
ZAP Filter
https://www.octave-electronics.com/lcaudio/zapfilter.shtml
https://www.diyaudio.com/community/threads/zap-filter.8837/
Class-D
https://www.diyaudio.com/community/threads/new-module-by-lars-clausen.80526/
https://ing.dk/debat/hjemmebygget-hi-fi-forstaerker
Overview:
https://www.octave-electronics.com/lcaudio/lcproducts.shtml
Under some online portals and websites from suppliers is LC Audio still to find - go to
https://hifi-products.com/L-C-Audio-Technology-ApS-manufacturer-475.html
and
https://www.octave-electronics.com/newadd.shtml
but the website itself no longer exist since approximately two years - go to
Who know the currently company name for no longer exist company LC Audio Technology ?
Thank you for an information.
P.S.: Please note that this is not about this manufacturer for loudspeaker drive units:
https://audiotechnology.dk
  • ZAP filter.pdf
    ZAP filter.pdf
  • millmateng.PDF
    millmateng.PDF
  • LC audio overview.pdf
Adding a second woofer to the speaker system
I've successfully created three-way bookshelf speakers containing a 10" woofer, a 2" dome midrange, and a 1" tweeter per closed enclosure for years. The crossovers are tuned to have output response (nearly) summing flat as shown in this picture.
However, I've been using them with an active subwoofer. Now I plan to stop using subwoofer and would like to listen to low-frequency from the main speakers. I removed subwoofer and found the bass wasn't enough, though I reckon these speakers sound flat.
I still have a pair of the woofers unused so I thought to add them to the system. In other words, the bookshelf speakers will be converted to floor-standing from now on.
The problem is I cannot easily add them without mod the crossovers. And I want to increase only low-frequency region. I finally need to convert them to 3.5-way system. In fact, I tried building them 3-way by typical way of adding the second woofer and redo the whole crossovers and found the unsatisfied result when there's no upgrading in bass SPL increasing anymore. Thus, I realized the 3.5-way system may correctly fix the problem.
Here is the simulation of the 3.5-way system that I randomly generated in simulation software.
I confess I don't have knowledge about the procedure or theory for building 3.5-way system. I simply add a second woofer with twice larger inductor on it, the 14mH coil.
And this is the comparison between 3-way and 3.5-way systems.
I would like to ask whether I did it correctly? And is the result (simulation graph) acceptable? I know the more accurate version should be from real measurement not simulation result, but this is the first step of learning. So, please try to understand.
Need help designing a simple flip flop for 12V trigger
See the attached circuit circled in red. The circuit senses a signal and provides -12V for on and +12V for off, just the opposite of ICEPower modules. I am wanting to have the circuit provide +12V for on and 0V for off. A little more complicated than a simple flip flop. Any ideas? I can build a simple circuit on a breadboard and piggyback off the +-15V to power it.
Quatre QMI Gain Cell Series Amps
Hello, not sure if this is the best place to seek answers but this forum popped up as an option when searching the net for info about Quatre Gain Cell Series Amplifiers. Want to know how to approach powering them up for the first time in probably 6-10 years. One is a DG250C and the other a GC500 the internals in both look fairly clean although showing signs of possible repairs or up-grades... etc, and both look like fairly substantial pieces of gear with one (GC500) having the most enormous power transformer I’ve ever seen on any piece of music gear to date period. A friend of mine got them out of a storage room in a club where they were once used as the house dance pa system and I don’t even know if they work or not. Given the nature of the situation it would seem reckless to simply load the speaker out’s and just plug it into the wall due to the size of the capacitors and the adjacent delicate looking pc boards with small chips standing off the board.
I’m hoping that I could use these (or one of them) for an alternative s-state system in my home as I do enjoy the clarity and POWER of a good s-state amp as an alternative to several tube amp sound systems that I currently own and rotate periodically. I had to sell my last good s-state power amp about a year ago due to relocation cost and I miss it. It was a JBL/Urei 6260 power amp and I used it mostly to power my Altec Valencia’s that also had to go about a year prior. Anyway… enough sob story telling. Any advice on these amps? Things I should know? Like, how to control the levels as there aren’t any on the amps themselves?? And the safest way to test power them up would be greatly appreciated. Again i have 2 amplifiers… Quatre Gain Cell Series DG250C QMI and GC500 QMI.
Also: I'm a diy-er that probably should have been on this forum a long time ago and looking forward to sharing ideas and learning more about how to tweak, mod and make usable circuits.
Thanks!
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,774
Members
7,888,001
Messages
Filter
Forum Statistics
Threads
406,214
Messages
7,888,001
Members
507,774
Latest member
pete2000
