Repairing Rotel RA-840BX3 and looking for trustworthy transistor source
- By 12Bass
- 2 Replies
Hey Everyone,
I'm looking for the following transistors to repair my RA-840BX3:
Q621 - 2SD600K
Q623 - 2SD600K
Q625 - 2SB631K
Q631 - 2SB817E
Does anyone know of a trustworthy online source? Looks like some of them are now obsolete. Would prefer to order them all from the same supplier, in Canada or USA if possible.
When I purchased the amp (used), the power resistors on the driver transistors were all open due to overheating, so I fabricated some higher wattage replacements. However, when trying to adjust the bias I accidentally shorted the left channel. I've run my multimeter diode checker on all of the transistors on that side and only the above seem to have failed. Once I replace these transistors, I'm planning on doing a dim-bulb test to check if everything is working correctly. If all goes well, I won't require further assistance...
Thanks!
Q621 - 2SD600K
Q623 - 2SD600K
Q625 - 2SB631K
Q631 - 2SB817E
Thanks!
