Go Back   Home > Forums > Blogs
Old
Zen headphone amp.
Posted 9th October 2009 at 09:00 AM by Mr. Unknown
Originally Posted by Mr. Unknown View Post
Hi tortello,
I'm going to build a Zen headamp but my knowlegde is ... not good . So I need a help to mod zen headphone amp( Zout, gain,...) . I use 100 ohm headphone( yamha yh-2, orthodynamic) anh do you have a pcb orcad file?. I also to mod the pcb.
I will using a adaptor 24v-1a, it's enough current!!!
Thanks you.
Posted in Uncategorized
Views 1543 Comments 0 Mr. Unknown is offline
Old
NS LM3875TF gainclone amp
Posted 8th October 2009 at 09:57 AM by androidDIY
SIMPLE......why not try the NS LM3875TF GAINCLONE AMP?
I have heard the Sanken and NS LM3875 before,the sound quality is not bad and even could be compared with Hi-End/Expensive amplifiers.
The Peter Daniel's work is really beautiful,I hope I could learn more from his design.
Better components
Better design
Optimized Grounding
and others?
https://www.audiosector.com/chassis_patek2_amp.shtml
Posted in Audio Life
Views 9034 Comments 0 androidDIY is offline
Old
Try
Posted 8th October 2009 at 09:30 AM by androidDIY
Updated 10th October 2009 at 03:33 PM by androidDIY
TRY
Views 1124 Comments 0 androidDIY is offline
Old
Korean Drama - Beethoven Virus
Posted 8th October 2009 at 09:19 AM by androidDIY
'Korean Drama - Beethoven Virus' , it's not talking about the computer virus,the story describe how a good conductor change the faith of a poor/amateur orchestra.
The writer of this drama has good knowledge about the classical music.It's just like the difference between Toscanini and Carlos Kleiber.
The actress has a good look too.
貝多芬病毒,一部類似交響情人夢的韓劇。
目前看到第五集,還不錯,有一些想法:
1.跟交響情人夢比較起來,演出的逼真度差一點,某些演員的動作還是有些生硬。
不過,台灣肯定是拍不出這種感覺,至少過去都是如此。
2.故事比較沒有交響情人夢的卡通趣味,衝突性比較高。不過,交響情人夢本來就是漫畫/動畫改編的。
貝多芬病毒對於指揮的著墨比較深,會讓人對指揮的角色有更深的體會與了解。(因為很多人都覺得奇怪,指揮要 幹嘛?演出時,樂團成員也沒幾個人在看啊......其實關鍵還是在於練團的過程與音樂的詮釋 角度。)
一共有18集,一邊工作一邊看之中......
NOTE - 因為韓劇看得少,所以演員不太熟悉啦,女星只認識李英愛與金喜善,都結婚了。(宇居的金喜善-胖福,也結婚了,所以新來的朋友不要想太多。)
Posted in Funny Stuff
Views 1631 Comments 0 androidDIY is offline
Old
SPU Synergy GM - How about this one?
Posted 8th October 2009 at 09:11 AM by androidDIY
I am looking for a MC catridge.For higher budget, SPU Synergy GM is a good choice.
SPU Synergy GM
The SPU Synergy GM modernizes the classic SPU design with a number of optimizations designed for optimum compatibility and sonic purity. The SPU Synergy features a wood-based housing and has a revised generator system which allows for a maximum output of 500µV, relaxing the requirement for high gain transformer or active preamplification systems. While still making use of a highly polished Nude Elliptical stylus, the stylus tip mass has been reduced significantly, resulting in reduced VTF and higher tracking ability.
Technical data
Output voltage at 1000 Hz, 5cm/sec. 500 µV
Channel balance at 1 kHz <1> 23 dB
Channel separation at 15 kHz > 15 dB
Frequency range at - 3dB 20-30.000 Hz
Frequency response...
Views 1866 Comments 0 androidDIY is offline
Old
波多野結衣 VS. Chiling Lin
Posted 8th October 2009 at 09:08 AM by androidDIY
Updated 8th October 2009 at 09:25 AM by androidDIY
She look very similiar to an Super Model in Taiwan,Chiling Lin.
Views 6169 Comments 0 androidDIY is offline
Old
Try
Posted 8th October 2009 at 09:04 AM by androidDIY
Updated 10th October 2009 at 03:35 PM by androidDIY
TRY
Views 728 Comments 0 androidDIY is offline
Old
Sony HA-T10 MC Step Up transformer
Posted 8th October 2009 at 08:59 AM by androidDIY
When I was young,I like to build the MC pre-preamplfier for myself.But the hum/noise reduction is always a very big problem.
After using several excellent input transformers like Jensen,Lundahl and UTC,I should change my concept.
I will prefer using MC step up transformer in my system.Sony HA-T10 is very cheap is easy to find in Japan.I will ask my friends to find some for me and start the way.
Yes,I will try Jensen and Lundahl later.
Another question is - where is my MC catridge?
Description
The Sony HA-T10 is a high quality super-mini step-up transformer, which can be used with moving coil cartridges in the impedance range from 3 to 40 ohms.
The optional RK-125 connecting cord is available to connect the HAT10 to the main amplifier to nullify hum.
Specifications
Matching cartridge impedance: 3 to 40 ohms...
Views 4853 Comments 1 androidDIY is offline
Old
Try
Posted 8th October 2009 at 08:23 AM by androidDIY
Updated 10th October 2009 at 03:34 PM by androidDIY
TRY
Views 659 Comments 0 androidDIY is offline
Old
Try the 1st blog post
Posted 8th October 2009 at 08:16 AM by androidDIY
Updated 8th October 2009 at 08:39 AM by androidDIY
TRY THE 1ST BLOG POST - JUST TRY
I found an website yesterday.The owner seems to be a professional reporter who wrote lots articles associated with the Japan Adult Video.
It's really interesting,I never thought the Japan Adult Video could be analyzed like that.
Here is the link - https://avno1.com/
相信在十月一定有不少人在期待天海つばさ(天海翼)這位新人吧?畢竟在Ideapocket舖天蓋地的宣傳 之下,大家都想知道這個「アイドル顔負けの超美少女」(臉蛋不輸偶像的超美少女)的新人究竟是不是真貨;而 在寫真照片公布之後,更有人拿她和ideapocket之前培養出的超級彗星初美りおん(初美Rion)相 比,可見這位天海つばさ(天海翼)是讓眾人多麼期待。
Does this sysem support Chinsee?
OK,It works!
I could use this as my blog.....
Views 877 Comments 0 androidDIY is offline
Copyright ©1999-2017 diyAudio
