Go Back   Home > Forums > Blogs > dvb projekt
Rate this Entry
Pedja Rogicīs Discrete Diamond Non-Feedback I/V Stage - Out of production
Posted 17th May 2011 at 04:15 PM by dvb projekt
Updated 14th June 2013 at 09:46 AM by dvb projekt
For all of you who want an alternative non-tube I/V stage,
Pedja Rogic was so kind and permit me to make a pcb with his circuit.
To get a smaller pcb, i made two connectors for the needed big 10ĩF caps.
The PCB will have the following data:
Material: FR4 - 2mm
Layers: 2
Board size: 110x95 mm
Surface finish: Immersion Gold
Copper weight: 70ĩm
Soldermask: Both sides - green
Silkscreen: Legend on top
Out of production
Views 4408 Comments 5
Total Comments 5
Comments
  1. Old Comment
    Hallo Oliver I like to have 1 Pedra Rogic DDNF i/v and
    (if it become's real a I/V PSU).
    Groet Antonioo
    permalink
    Posted 18th May 2011 at 09:26 AM by antonioo antonioo is offline
  2. Old Comment
    Add me to the list - thanks!
    Ryelands
    permalink
    Posted 18th May 2011 at 04:54 PM by Ryelands Ryelands is offline
  3. Old Comment
    Oliver , after reading again, i don't now if i need 1 or 2
    i/v for double dac???
    Antonioo
    permalink
    Posted 19th May 2011 at 09:05 AM by antonioo antonioo is offline
  4. Old Comment
    dvb projekt's Avatar
    Antonioo
    Antonioo,
    if you want to use two TDA1541A DAC modules parallel, you need only one of the DDNF I/V module.
    Just change the R I/Vīs from 1K5 to 750R (see BOM).
    permalink
    Posted 19th May 2011 at 09:08 AM by dvb projekt dvb projekt is offline
  5. Old Comment
    No tubes!!! Who would want that.
    Greg
    permalink
    Posted 22nd May 2011 at 11:48 AM by headrott headrott is offline
Copyright Đ1999-2017 diyAudio
