| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#131 |
I downloaded the Microcap 9 free evaluation version. It looks a lot better than the version 6 demo I had !
However Mextram self-heating model is only available in the professional version... argh. |
#132 |
Hi Grey and A.M.
I'll send the article to you, probably tomorrow. Cheers,
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) |
#133 |
Instead of doing Spice, yesterday I bought a book on transistor theory: 'The Bipolar Junction Transistor' Vol3 By Gerold W Neudeck from the modular series on solid state devices, Addison Westley Publishing, once used at a course at Purdue, just to get back to understanding how transistors REALLY WORK.
I hope to cast further aspersion on Spice models in the near future by reading this text. vampire2: |
#134 |
Hi John,
That would be illuminating. cheers, Ashok.
AM |
#135 | |
Very good point and approach, Andy. I've also seen lots of cases where the phase margin went south under certain voltage or current conditions. Bob |
#136 | |
Hi John, I think I remember that series of books. Maybe six fairly small volumes. I think I had the series in one of my courses in college. You're right that SPICE models are certainly not perfect, but the simulation results can still be very valuable. Bob |
#137 | |
I had Professor Neudeck for a course in transistor circuit design, EE255 at Purdue, around 1976 or so, when he wasn't all that much older than I was. He was a great guy, and also sometimes quite entertaining. ------- Simulations, and also hand calculations, obviously depend on how good the models are, for the usefulness of their results. But, given that the models are not perfect, the usefulness of simulations depends at least as much on the assumptions of the person doing them. Bob Pease's famous "issues" with the use of Spice seem to have more to do with some people's idiotic "blind faith" assumptions about the models and simulation results, than with simulation per se. One of the main reasons we have "engineering" is to try to be able to design things and then "know" that a design will work, before it is built. That's usually an imperfect process, of course (sometimes "by design"), and often requires iteration, after prototypes are built. However, the basic idea implies that we should consider using whatever design tools are available and helpful, incuding computerized tools, of which Spice is but one. Of course, our brains are our most-important tools. If they are not used properly, tools like Spice can be worse than un-helpful. Bottom line: Blame the user, not the tool. - Tom Gootee http://www.fullnet.com/~tomg/index.html - |
#138 |
You must come to understand that I have been professionally involved with circuit simulation since 1966. That is a long time! I just don't DEPEND on Spice for my circuit designs. It's OK, and it gets better all the time. Still, I don't need it to make a successful product. Neither did the designers who made the ua741 possible.
#139 | |
Hi Edmund, I must have missed a post you made (maybe it was not in this thread). I don't want to get into semantics between sophisticated and real sophisticated, but I think my definition above was adequate, and of course I think that the MOSFET power amplifier with error correction that I did 25 years ago lies in that realm. It achieved 6 ppm (0.0006%) at 20 kHz THD in a 200 khz measurement bandwidth. With regard to Halcro, are you referring to Halcro's stated performance or actual performance? I've seen no evidence that they meet their stated performance (even after Stereophile reviewed the DM38 again), but I allow for the fact that properly measuring performance in the range that they state can be difficult. Forgive me if I missed a post, but have you actually built and measured an amplifier that does 1 ppm or below ( e.g., <120 dB) across the full spectrum from 20 Hz to 20 kHz on both THD and CCIF IM at any power from 1 watt to full power? If so, that is very impressive, and please refresh my memory and/or tell us more. Simulations don't count. Although I am a firm believer in SPICE, I have always been reluctant to depend on it for estimates of distortion achievable in practice. Cheers, Bob |
#140 | |||||
Hi Bob, Yes, probably you did. In my post#1552, I was just a little bit joking, as somebody was referring to "sophisticated" amplifiers, which shows quite a lot of distortion. Therefore I stated: "Real sophistication starts at thd<1ppm, not at 0.02% or 0.25% in case of tubes." Quote:
![]() 6ppm? NO, 7 ppm, according my simulation. ![]() Quote:
![]() Quote:
But I have designed amp's on paper with a thd (at 20kHz) around 20ppb. If some body give me the money and facilities to build such thing, I should really love it.Quote:
Anyhow, my latest design shows, a thd (20kHz) of 20ppb. Maybe my sim is one order of magnitude wrong, that still leaves a 0.2ppm of distortion. Cheers, Edmond. edit: if you are really interested in my design, I'll send you the schematic (confidentially, of course).
| Need help with Spice simulation | overmind | Everything Else | 4 | 23rd December 2002 04:58 PM |
