Mark Audio CHR-70 Application Thread
Old 14th April 2009, 02:16 AM   #61
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Lotus | MBVR for CHR-70 (1 or 2)
http://www.diyaudio.com/forums/showt...75#post1801575
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th April 2009, 03:41 AM   #62
speakrsrfun is offline speakrsrfun  Canada
speakrsrfun's Avatar
What was that?... I can't hear you I have a line array filling my ears.
Old 14th April 2009, 03:56 AM   #63
italynstylion is offline italynstylion  United States
italynstylion's Avatar
Really, 1 or 2 drivers eh?
I'm buying myself a table saw tomorrow because my birthday is next week and dammit; I'm worth it! I might just have to build these for myself.
Dave.....why do you do this to me. My girlfriend is going to hate me.
Old 14th April 2009, 04:09 AM   #64
frugal-phile(tm)
planet10's Avatar
Scott is just as guily...
dave
Old 14th April 2009, 04:20 AM   #65
dave
I'll mention it to him
Since I'll be using two drivers in those cabs, with one mounted on the side, how should I modify that internal brace? Is there something that works best or should I just get creative and go for it?
Old 14th April 2009, 04:26 AM   #66
frugal-phile(tm)
planet10's Avatar
I'd add at least a holey brace between the side driver & the main holey brace. It should be edge on to both drivers.
dave
Old 14th April 2009, 06:42 AM   #67
chrisb is offline chrisb
dave
in other words, horizontal and above or below the center of symmetry?
like my mind, this space intentionally blank
Old 14th April 2009, 07:33 AM   #68
frugal-phile(tm)
planet10's Avatar
Yes.
dave
Old 14th April 2009, 09:09 AM   #69
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Yep, one or two. Designed for one, it just happens that two (in series) also will work as there's sufficient volume. As I mentioned in the Spawn thread, it's a compact (as they go) cab. notionally designed for smaller spaces / more modest SPLs on primarily acoustic music. However, the twin units will give better power-handling -total excursion plummets; maxes out at 0.8mm 1m / 1w shared between the two drivers. I'm building a pair myself for my CHRs.
Oh yes -line the cab. 1/2in wool felt or fiberglass, top, back & one side-wall (the opposite to the one the 2nd driver is on would be the obvious candidate... )
Old 14th April 2009, 01:14 PM   #70
It certainly is compact. I'm not positive but think you can get a pair out of a single sheet of wood
Mark Audio CHR-70 Application ThreadHide this!Advertise here!
need great smd cap for audio application jsaggio Parts 1 11th September 2007 03:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 12:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 08:20 AM
