| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#111 |
It's true that the interface is not exactly state of the art, but on the other hand it would be hard to find digital playback that would beat a QA550 via I2S into Patrick's 9022 at anything like the price. And a 32GB SD card that will store about 50 CD's can be bought now for little over £30.
#112 |
Yes, you are probably right.
I've seen the QA550 and it looks like a very solid piece of kit. I had a quick listen through headphones but not for any length of time. I suppose one of my issues is that I have SPDIF sources, and no laptop/PC source (other than headphones). So to go down the PC route, well, I'd really have to buy a laptop....... Tomorrow is a day for sorting out the charger and a chassis of sorts that the DAC can live in. EUVL: have you given the DAC a name? |
#113 |
But the QA550 is not PC Audio. In fact that is the whole point of the QA550. It (including Koon's Ultimate Source, EC Design's Lossless SD Player, ...) allows you to retrieve data from a SD card directly without an asynchronous data interface like USB, or ethernet, or .... So you do not need to run a PC to play music. You only need a PC to rip CDs into WAV files so that you can then copy them onto the SD card. Once that is done you don't need the PC anymore. So certainly no need for a laptop. Patrick |
#114 |
Yes we have a name, but we are preparing for a hobby website to document all our stuff. So it will be announce there. ![]() Patrick |
#115 |
As I mentioned, I decided to do a little bit more work on housing the DAC. So here are a few pics. I need to add a little bit of acrylic for the front face .....
EUVL, its a pity I cannot wire as neatly as you can etch and build! |
#116 |
Still very nice.
![]() Looking forward to your further comparisons, Patrick |
#117 |
Wood, may I ask where you source the batteries from? Also, what scheme do you use for charging etc.?
Patrick, looking forward to seeing your website go live.
#118 |
Will take a while. Too much to do at work, and getting the F5X thing going.
Patrick |
#119 |
Today I got to listen a bit more. I moved to my second room. This one has a different set up. Again, I used a shigaclone, with DCB1 preamp, EL84 tubecad triode amp (one of the best sounding amps I have heard) into Sachiko horns and 2 x REL subs.
The comparison was between the EUVL DAC and my buffalo Mk1. This buffalo has full salas shunt supplies, with discrete couterpoint I/V stages and all the tricks and mods that were added on over time. In short, very good sounding. The sound from both DACs was actually very similar, however I do think that the bass in particular was a bit tighter from the EUVL DAC. Treble.... well, maybe cleaner, maybe not. I certainly wouldn't be able to blind tell the difference. However, the forward presentation of vocals (or any centrestage instrument) made the EUVL dac a very nice and engaging listen. The Buffalo by comparison, still offered very similar resolution, but sounded more relaxed. I want to go back and tease out this presentation thing. I can't decide if its that the soundstage is deeper with the EUVL dac, or just different. If it came down to it and I could only keep one? I think I might just side with the EUVL dac. No heat, very simple power supply, no additional output stages to worry about, easy to house and case up, and of course cost..... I reckon I have about 700 euro buried in the buffalo over time. Thats not cheap! But the sound.... its engaging, detailed without being harsh or edgy, very clean and yet easy to listen to over long periods. A winner I would say. Next up: comparison with the Pass D1 clone...... Fran |
#120 |
![]() Patrick |
| Balanced jfet buffer for Vout DAC? | jonners | Solid State | 7 | 22nd October 2010 07:57 AM |
| where to connect + wire for Vout? | jarthel | Power Supplies | 2 | 27th March 2007 04:49 AM |
| Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 V | Groundloops | Power Supplies | 14 | 16th February 2007 01:13 PM |
| help in adjusting Vout in the power supply of the "Brute force in a line stage" by Er | jarthel | Tubes / Valves | 9 | 30th May 2006 07:47 AM |
