Sure, if I were asked to design a phono preamp today I'd go for the 6N2P-Ev too.
I currently use it to drive a pair of 2A3s in an amp.
Back in the early nineties I used E283CCs as error amps in voltage regs and ECC808s, C3As and E80CCs in an MC/MM phono preamp too.
Gone are the days....
Just saying these E283CCs are not just your regular run off the mill valve, they're masterpieces of technology.
Cherish them ,
Today changed for E283CC, you are right are very good. Thanks for the advice.
Felipe
I started to learn English with this free app https://www.duolingo.com/
It should be going well straight to the Itch 47K input. Any thought vs "affordable" MC like 103R? The SUT cost and non replaceable stylus costlier change must be factored in for any MC though. Are there generic stylus copies that can perform satisfactory near the 35E original quality?
Just arrrived the Shure I need more time to listen but first impressions is also better SQ than Denon DL103R + Jensen JT-44K-DX MC Step-up.
But I'm not sure If I optimized well the RC secondary: used 6K8 + 200pF as Jensen advice but lately measured with scope & test showed only resistor was necessary because when connected the capacitor the square wave was ringing http://www.diyaudio.com/forums/analogue-source/290983-jensen-jt-44k-dx-mc-step-up-loading-doubt-6.html
- Analogue Source
- Valve Itch phono
