Valve Itch phono
diyAudio Chief Moderator
Joined 2002
Don't worry I will left the red LED. Attached pic with other vinyl pearl.
I like this music too. I have it in different recording than yours. But also very nice
Joined 2009
I had only roughly calculated it. This is a very low transfer capacitance tube we use here. Should be in the 60pF to 70pF range at our about 85x gain including strays.
Mine MM cartridge recommends 200pF including phono cable to the Itch, have I to substract the 60pF to 70pF range at our about 85x gain including strays?
For example target 200pF
Phono cable 180pF
Itch 60-70pF
I don't need add any capacitance more, right?
Joined 2002
Target 200pF means better have 130-150pF cable so the 6N2P Miller adds to about 200pF total. If 180+60=240pF is still tolerable you leave the cable as it is. If you will not hear treble resonance like too much highs and sibilance, is an indication its alright.
