After changed the resistors and added HF RIAA capacitor the sound has changed, before I used:
R2 Kiwame 2W
R3 Takman carbon film 1/4W
R8 Caddock MK-132V
R9 Kiwame 2W
R10 Kiwame 2W
R11 Kiwame 2W
Now I use:
R2 Mills 5W
R3 Mills 5W
R8 Amtrans 0.75W
R9 Mills 5W
R10 Mills 5W
R11 Mills 5W
Now with the 2 dBs more the phono pre is more powerful, it seems the sound with the Kiwame was more clear but also more edge, I don't know if the difference is only the resistors because as you know I added the HC capacitance, now the sound is more round & warm & a lot of more dense like if was more information or harmonics, also is more punch.
What do you think?
R2 Kiwame 2W
R8 Caddock MK-132V
R9 Kiwame 2W
R10 Kiwame 2W
R11 Kiwame 2W
Now I use:
R2 Mills 5W
R3 Mills 5W
R8 Amtrans 0.75W
R9 Mills 5W
R10 Mills 5W
R11 Mills 5W
What do you think?
Shibata
4 times greater contact than elliptical
R2 Kiwame 2W
R8 Caddock MK-132V
R9 Kiwame 2W
R10 Kiwame 2W
R11 Kiwame 2W
Now I use:
R2 Mills 5W
R3 Mills 5W
R8 Amtrans 0.75W
R9 Mills 5W
R10 Mills 5W
R11 Mills 5W
What do you think?
Seems to me more like a Shure sound. But if you will feel like exploring sure golden compromise see with tedious HF little capacitance manipulation too.
There is also the maximum capacitance load of 400-500pF
I have actually 220pF Ekos cable + 60-70pF input capacitance of Itch = 290pF maximum, still margin to play with the input capacitance load.
What do you try first Salas the input capacitance or the RIAA HF capacitance?
Both are doing the same thing equally on top and bottom sections which are one stage combined
I have only 2 Shinkoh
- Analogue Source
- Valve Itch phono
