UCD 25 watts to 1200 watts using 2 mosfets
detex 3kw smps
how is the amp and how many voltage +/-? also what fets are you using for outputs.
Hi Steven
greetings i use FDA69N25 mosfets for my IRS3000 dc volts 95+/-
with FDA59N30 i use 125 dc volts +/- the dclass amp at side of detex smps has 6 pairs @ 90 volts dc its for .5 OHM LOAD
warm regards
andrew;)
class d kit test
Testing my class d amp with my new speakers i made at home
warm regards
andrew:D
  • iraud russia tlo 72 and lm 311.zip
  • Iraudamp 1.zip
  • forum.cxem.net 100_2_.pdf
  • forum.cxem.net 100_26.PDF
  • iraud russia.zip
hi workhorse i drafted the pcb based on this forum., is this layout o.k it is ucd .:confused:
:scratch1: just wondering are the below layouts up to the standard:confused:
  • ucd 25 watts to 1200 watts using 2 mosfets pg 272 Amplificador Classe-D  pg 74 components irs4k5.jpg
  • ucd 25 watts to 1200 watts using 2 mosfets pg366 1148845_202438549917588_1666567237_n.jpg
