detex 3kw smps
how is the amp and how many voltage +/-? also what fets are you using for outputs.
Hi Steven
greetings i use FDA69N25 mosfets for my IRS3000 dc volts 95+/-
with FDA59N30 i use 125 dc volts +/- the dclass amp at side of detex smps has 6 pairs @ 90 volts dc its for .5 OHM LOAD
warm regards
andrew
Hi Steven
warm regards
andrew
hi all any idea if this will work? Class-D amplifier for the subwoofer and not only on motives Iraudamp - Power Amplifiers Class D - Forum for Electronics
irs3000 probleam boostrap diode burn
hi to all,
greetings,
irs3000 boostrap diode brun after few minuts, i will change gate driver, diode inverter,comparator,inductor but no responce same problem what i do, any one can explain how to solve this problem
hi to all,
greetings,
These are EMI infernos not Class-D amplifiers... Switching node directly lifted above the PCB to act as HF transmitter
how comes in his forum he has the measures an has made many pcbs with success?
A working class-D doesn't mean, its a success in EMI also. The type of PCB layout used in the above examples is terrible and can cause huge amount of EMI.
hi kanwar pls share a simple working class d schematic with pcb layout.
hi workhorse i drafted the pcb based on this forum., is this layout o.k it is ucd .
just wondering are the below layouts up to the standard
ucd 25 watts to 1200 watts using 2 mosfets pg 258 irs500_555.jpg103.7 KB · Views: 435
ucd 25 watts to 1200 watts using 2 mosfets pg 248 nyak_n.jpg509.9 KB · Views: 2,683
ucd 25 watts to 1200 watts using 2 mosfets pg368 DSC03404 copy.jpg227.5 KB · Views: 355
ucd 25 watts to 1200 watts using 2 mosfets pg 248 nyak_al_k.jpg144.3 KB · Views: 340
ucd 25 watts to 1200 watts using 2 mosfets pg 263 dsc07549f.jpg841.8 KB · Views: 610
ucd 25 watts to 1200 watts using 2 mosfets pg 272 Amplificador Classe-D pg 74 components irs4k5.jpg451.5 KB · Views: 713
ucd 25 watts to 1200 watts using 2 mosfets pg 128 index.php.jpeg25.3 KB · Views: 542
ucd 25 watts to 1200 watts using 2 mosfets pg366 1148845_202438549917588_1666567237_n.jpg126.9 KB · Views: 470
ucd 25 watts to 1200 watts using 2 mosfets pg364 amp-2011.jpg126.5 KB · Views: 553
ucd 25 watts to 1200 watts using 2 mosfets pg 267 Connection AUD600.jpg95.4 KB · Views: 734
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
