My boards arrived in perfect condition... Thanks Oliver !!
Mine as well, thanks
Have much fun!
Regards,
Oliver
Some doubts
Hi Oliver,
I'm building the PCB board and I have three doubts.
1.- Is there a link bridge at the top, below the external B+? Or is it optional that link?
2.- Is there an error in the heater part regarding an electrolytic 16v 10mf but the silkscreen states 16v 22mf? In the BOM there are two 10mf but not 22mf...
3.- May I use a 6N1 tube instead of 6N2?
Regards,
Jorge Castellano
Hi Oliver,
Regards,
Jorge Castellano
Hi Oliver,
Regards,
Jorge Castellano
Hi Jorge,
to your questions:
1. You must only omit this link, if you want to use ext. B+ for each tube separate.
2. In the V3.1 BOM you have two Elna Silmic II 10µ/16V and one 22µ/16V.
Did you have the right BOM?
3. All resistor values are focused for the 6N2P/12AX7/ECC83. If you want to use other tubes, you must look to the technical data and tune the values.
Best
Oliver
How much is a board?
I'm writing from my phone and can't find the answer atm.
Thinking about adding one of these boards to my Red Baron 5.0 pre-order.
You will find all informations HERE.
- Group Buys
- Tube-I-zator Professional PCB
